Technical *** January 2016 Banger Meet - New Year and Old Bangers ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 1, 2016.
  1. Bluto
    Bluto
    The reason I suggested a Google is that I use it often to see variations in things and lead me to other info. It's a great resource that many people don't really think about.
  2. denis4x4
    denis4x4
    from Colorado
    Here's Mazda/Courier 1.8 SOHC that I'm using in a Model ch***is with a chopped fibergl*** sedan delivery body. Transmission is an aluminum 4 speed. Image 1.jpg
  3. noboD
    noboD
    Jim, it helps if you add the word naked too, gives a different perspective.
  4. Bluto
    Bluto
    naked miata??
  5. winduptoy
    winduptoy
    Thanks for the explanation of the V-TECH I did a web query on it and it brought up a Honda VVT engine Vtec that confused me
    I thought that Mazda was a light bulb
  6. winduptoy
    winduptoy
  7. Bluto
    Bluto
    Did you buy a Miata lightbulb?
  8. 64crump
    64crump
    from Alta Loma
    You should have it (FAST magazine) by now, if not shortly, just got mine. I know they started going out last week
  9. fourd
    fourd
    from Colorado
    Lifters! Which should I use? I have double lockers in the car but a new cam is going in and I think I should change over to the wider foot single lockers or maybe re-worked Chrysler. The cam is a Breirley M24/1R, a 4 Port/Winfield grind as I understand. ImageUploadedByH.A.M.B.1453089448.195034.jpg
    An ***ortment of lifters I have. Single lockers in 2 diameters, 3 Chryslers setup for OHV and short & long Chryslers. ImageUploadedByH.A.M.B.1453089570.433088.jpg
    Cool parts from fellow hambers!
    barrnone50, G Baese and waxhead like this.
  10. G Baese
    G Baese
    Fourd- Nice to see!
  11. colinsmithson
    colinsmithson
    I personally go with the Chrysler lifters when possible then I never have any limits on future cam chooses
  12. Binger
    Binger
    from wyoming
    Pretty timing cover!!!
  13. V4F
    V4F
    from middle ca.
    if the motor is still apart , be sure to cut the lifter blocks so you can adjust valves without all the rotating & guessing .....
  14. studebakerjoe
    studebakerjoe
    What are those Chrysler lifters out of originally?
  15. winduptoy
    winduptoy
    Me Oughta' look into some if I'm not LED down the wrong path....
  16. fourd
    fourd
    from Colorado
    I thought I did that but that was 20 yeas ago. My gosh those things are a pain to adjust. The motor is in the car and I was trying to do quick cam swap. I will pull the whole thing apart now.
  17. fourd
    fourd
    from Colorado
    Chrysler flathead I have read. They are slightly larger in diameter and I have 2 types, about 5/8" longer than stock and about 1/4" longer than stock. They sure look easier to adjust. The foot is wider.
  18. BCCHOPIT
    BCCHOPIT
    Just checking in....
    The only news I have is I sold my alum. Winfield head to free up some cash to buy some some tooling for the shop.
  19. V4F
    V4F
    from middle ca.
    your always workin on something
  20. V4F
    V4F
    from middle ca.
    where can I find the rules for TROG racing ?
  21. BCCHOPIT
    BCCHOPIT
  22. V4F
    V4F
    from middle ca.
  23. Bluto
    Bluto
    Things are done here the way they have been done forever or state of the art. Today we went to a gasket company to order a one off head gasket. The cut the gaskets with a laser. Same for the rings. So no more hand cut gaskets and steel rule tooling. Now to find a custom crankshaft and connecting rod maker. Big problem is getting the correct rod bolts
  24. jim1932
    jim1932
    Probably a stupid Newbee question. If you run an A head on a B Block, what gasket do you use?
  25. orangeamcs
    orangeamcs
    A stock a head or a aftermarket head
  26. RussTee
    RussTee
    Its not a good idea to run a standard A head on a B motor there is not enough meat in the head gasket between cylinders
  27. BCCHOPIT
    BCCHOPIT
    That's a new one
  28. Just make sure the lifters clear the cam bearing bosses. I used a diameter I found posted but in my block (A) they were still a little large and would hang up on the bosses. Just check each one as you turn them down.
    BCCHOPIT likes this.
  29. Bluto
    Bluto
    Or run a DO set up :cool:
  30. I have also seen the Chrysler lifters interfering with the cam bearings (on cam).
    Part of the issue is just too large, not necessary with stock type reground cams and the foot is not concentric.
    IMHO, the Chrysler lifter is needed when cam is 1 3/4" OD and over .40 lift.
    A reground cam is much smaller base circle and the 1.1 lifter is fine.
    John
    1lowtrk likes this.
