TECH: Ultimate T-5 Article
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Mar 25, 2007.
  1. Model A Mark
    Model A Mark
    from dallas
    Hey guys, I just built a world cl*** unit for my friend, and it had the the rear mount shifter, with a mechanical spedo on it.
    I put the front shift tailhousing on it, and now the speedo gear flat on the shaft is about a inch to far forward.
    Can I get a world cl*** shaft that will locate the speedo back a inch ?
    Thanks
  2. Raunchy
    Raunchy
    There's a couple of ways to do it search it and you can see pictures and details. You don't have to buy a new shaft. You shim the gear to your shaft.
  3. Raunchy
    Raunchy
  4. Kato Kings
    Kato Kings
    from Minnesota
    I make split sleeves that I tack weld onto the output shaft. The one pictured is an s10 electronic speedo output shaft. I have done them on all types of t5's to swap to an s10 mechanical speedo tail housing.
    indianbullet, gonzo and Johnboy34 like this.
  5. chrisp
    chrisp
    Whoa pretty slick.
  6. Pete
    Pete
    Is this a Chevy bolt pattern T5?
    Guy says it's a 1995 S10 T5
    I don't have a pic of the front either, but have asked him to send one....
  7. Pete
    Pete
    Think I answered my own question....
    Chevy bolt pattern would have wider bolt pattern resulting in ears... image.png
    Nailhead Jason likes this.
  8. big duece
    big duece
    from kansas
    Chevy s-10 yes, but the front is what they call "ford" pattern. GM started that in '93. Its probably a wold cl***, but need odd ball bell housing.
    need louvers ? and loudbang like this.
  9. big duece
    big duece
    from kansas
    If going to a flathead, Gary at Cornhusker's hot rods can get the correct adapter.
  10. Pete
    Pete
    It's for sale locally.... Cheap
  11. big duece
    big duece
    from kansas
    It will probably have low 1st gear since it was in a s-10 4cyl.
  12. Pete, an AMC bellhousing would make that work with a Chevy.
  13. Pete
    Pete
    Awesome, thanks for the replies and quick responses...
  14. Dino 64
    Dino 64
    from Virginia
    So I found this one on craigslist and I was wondering if this might work for my 31 coupe behind a SBC. I've read most of this post, but I'm not sure why this one would or not. It's a WC which I didn't think they made for S-10's. Is it the gearing that's not good? Running a 3.0, 9" rear. Thanks, great thread. Here's the link. http://delaware.craigslist.org/pts/5398220084.html
  15. bjinx
    bjinx
    Pete if it has a 7 1/8" input shaft and the later ford bolt pattern, there is a guy on here, named INLINE, who makes and sells T-5 adapters to all types of bell housings. His S-10 adapter comes drilled for the Chevy and the Ford bolt pattern. His prices are cheap than whats out there, quality is good, and shipping is timely. I am very happy with mine.
    Forgot to mention he has an AD in the "Parts for Sale Forum"
    loudbang and David Gersic like this.
  16. Pete
    Pete
    I'll take a look....
    Appreciate that.
  17. sling392shot
    sling392shot
  18. TexasSpeed
    TexasSpeed
    from Texas
    Adapting a S10 T5 to a 59AB flathead.. This is the Speedway kit. I put the sleeve on the shaft and the bearing slid right on just fine. I reused the stock '47 release fork and shaft but when the bearing moves back far enough, it could spin around with very little resistance from the fork. The bearing is hitting on the fork on the edge of the bearing. Has anyone else ran into this problem? Is there an aftermarket fork that will solve this issue or will I have to grind down the fork where the bearing rests on once back all the way? (pencil is pointing to problem area in second picture)
    This is the best comprehensive guide of T5 tech I've found anywhere on the internet. Thank you for compiling all of this information, Ernie! I just can't find the answer to my dilemma in here..
  19. Mike51Merc
    Mike51Merc
    Tex***peed,
    I may be wrong, but wouldn't the fork be further forward when installed against the clutch? Perhaps you need to mock it up.
    On second glance, is it possible the fork is on backwards? It's not making good contact with the pads.
  20. TexasSpeed
    TexasSpeed
    from Texas
    You're correct. The fork legs should be resting against the bearing notches but it's not. The fork is actually mounted just like it was on the original transmission. I measured both the stock '47 transmission and the Speedway adapter and the shaft is where it should be. The retaining spring pulls the bearing back far enough that the legs of the fork come off the bearing and the edge of the bearing rests against a lower part of the fork.
    This is the complete kit from Speedway so I'm not sure what's going on here. I'll be contacting Speedway soon to see what they have to say about this.
  21. Mike51Merc
    Mike51Merc
    I'm thinking that you can take up that slack with adjustments of your clutch linkage. In other words, you lengthen the linkage until the fork moves forward to touch the TO bearing.
  22. H380
    H380
    from Louisiana
    Real good info here. 1 hour each on a mustang WC t5
    #1
    #2
  23. TexasSpeed
    TexasSpeed
    from Texas
    You're correct. After consulting some of the more experienced guys in the shop and looking at the linkage.. It appears the actuating arm is far enough "forward" that the pedal when not depressed will hold the fork forward and the bearing will remain in place. I went ahead and ****oned up the transmission today.. We will see when I take it out for its test drive. :)
    Thanks!
  24. Tim G
    Tim G
    OK... I know there is a ton of info on this all over the place on the internet... maybe that is the problem... information overload!
    Can anyone give me this simple information?
    I am fitting a World cl*** S10 T5 to a 1955 235ci stovebolt with 12v flywheel and 10" clutch. I am not running an adapter/spacer between the box and bellhousing and I am using the original 235ci pressure plate and realease bearing.
    All I want to know is what 10" clutch can i use with this set up? A supplier, part number anything... I am in the UK so don't want to order the wrong one obviously.
    Thanks in advance
    Tim
  25. joel
    joel
  26. Devonrod
    Devonrod
    from london uk
    Can anyone give me the dimensions of a GM T5 front bearing/input shaft retainer, I need the OD where it fits in the bell housing and the OD on the shaft where the clutch release bearing carrier runs, and what car it is from !
    thanks
    Dave
  27. bobbytnm
    bobbytnm
    Excellent info in this thread!!
    Thanks to all
  28. yruhot
    yruhot
    Ive heard about 300 ft lbs of tourque. I got on behind my 359 crate motor in my 57 chevy pickup, Racing no but tows my 55 g***er on the car hauler and I baby it along. Got on in my modified 4 banger model A and its a blast drives like a Ot sorry,miata. I would thing on a light street rod they would do ok but you know abuse anything and it'll break. I think the world cl*** would be the way to go if you got a hotter motor. PS by the way prices seem to be going up on these things due to them getting scariness.
  29. gimpyshotrods
    gimpyshotrods
    Contrary to popular belief, these transmissions are not weak. Sure, if you are an idiot, you can break anything.
    These transmissions were rated for load by Borg Warner when they were made. Some have interpreted this to mean that this is the shock-load. It is not. These ratings are for continuous load. All day, every day.
    The lowliest of the low T5's is rated at 265lb.ft. Now remember, that is not shock load, that is continuous load.
    Are you running 265lb.-ft. at your cruise RPM?
    The reputation for being weak comes from a combination of guys getting a used one, in poor condition, and breaking it, people driving like idiots, and Fox-body Mustang guys running 500lb.-ft. of torque through one, heading out to slicks.
    If they ****ed as bad as some of you claim, they would not only not have ended up being made in over 260 versions, and installed in everything from An S10, to a Mustang, to a Camaro, to industrial equipment, over a longer than 20-year manufacturing run, they would have been ordered recalled by the government.
    Kato Kings and BradinNC like this.
  30. loudbang
    Had the stock one in an OT 5.0 mustang raced it every weekend weather permitting used M&H drag radials and launched at 3500 and Power shifted. Never a problem with it.
