Hot Rods Checker Board Firewalls....Let's See Some.
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Jan 24, 2016.
  1. Speed Gems
    Speed Gems
    A guy we ( my dad and I) used to go to swap meets and car shows with once told me if he ever built a Hot Rod it was going to have a checker board firewall because that's what was popular when he was a young man. I did a search and found threads on how to do a checker board firewall, What material to use to block off the squares, and even what size the squares should be, but no dedicated threads on checker board firewalls. We have a thread on white firewalls now lets see one on checker board firewalls.
  2. wild32hotrod
    wild32hotrod
    here is a shot of mine, build the car in 1998. will get some better pics later IMG_0492.JPG
  3. DDDenny
  4. el Scotto
    el Scotto
    from Tracy, CA
    kiwijeff likes this.
  5. mgtstumpy
    mgtstumpy
    Sam Foose's 48 Ford coupe circa 1977. I still have the old magazine where it was on the cover.
    Just Gary, kiwijeff and Speed Gems like this.
  6. Speed Gems
    Speed Gems
    Bump for the day shift.
  7. belair
    belair
    Here is a video on how it's done. 3:06 - 3:10 will explain it all.
  8. edcodesign
    edcodesign
    Cosmo49 and Montana1 like this.
  9. DDDenny
    Hmmm, I wonder if there is a "quilted look" version paint brush.
    Cosmo49, hipster and belair like this.
  10. HUSSEY
    HUSSEY
    So, is it applied as a vinyl graphic, where can you get it?
  11. czuch
    czuch
    from vail az
    We did a OT Suburban 3 door with a six inch stripe, with one inch squares across the front of the hood and fenders.
    Just ran the masking tape and prayed a lot. Came out good for noobs with a rattle can.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My '46 Ford pickup. The air cleaner on top of that 460 is a motorcycle gas tank, reclaimed from floating hurricane debris. The underside of the hood was laid out using a carpenters laser level, suspended from the ceiling. This was my first flames-over-checkers attempt.
    chessterd5 likes this.
  13. Montana1
    Montana1
    Here's how I did mine... Made a pattern, put it on the black firewall, made some 2 1/4" squares out of white contact paper, stuck them on to see where they would go, and painted white in between the squares, then peeled them off - WALLA!!!
    Took me 2 days!
    Cosmo49, Stogy, wraymen and 2 others like this.
  14. mgtstumpy
    mgtstumpy
    HAMBER Langy from the UK
    hipster, deadbeat and Montana1 like this.
  15. white64
    white64
    from Maine
    Well I've done three so far all using the same "technique" (lol), Painted the firewall white then covered the entire firewall with blue 2" tape ****ed side to side vertically, and over that used green 3/4" tape horizontally spaced 2" top edge to top edge, and then carefully cut through the blue tape using the top of the green tap as the guide, pulled out every other tape square (about 2 hours to tape)then sprayed it black...easy! (did a driveshaft too that no one ever saw, duh) ... '38 Plymouth, '31 AV8 (in Avatar), '40 coupe 100_0720.jpg 100_0898_00.jpg 047.JPG
    Cosmo49, Stogy, hipster and 2 others like this.
  16. HUSSEY
    HUSSEY
    Wow, that's some impressive and tedious taping!
    Cosmo49 and hipster like this.
  17. oj
    oj
    They talk to me.
  18. wheeler.t
    wheeler.t
    My dad painted this car when I was a teenager, roughly 10 years ago. The owner drives the damn wheels off of it and is one of the best "old" guys I know.
  19. Well, being I didn't know there was one Right way to do it or that there is one Right size for the square's I'll show you how I did it Wrong. Notice the only vertical line I got Correct is the one dead center. I'll get right on this and do it over the Right way. 51 Project 032.jpg 51 Project 039.jpg 51 Project 051.jpg 51 Vicky 011.jpg
    The Wizzard
  20. Montana1
    Montana1
    Nice job!!!
    I almost always find myself re-inventing the wheel. I didn't know there was a right or wrong way to do something until after I did it. LOL Invariably someone will show up in the middle of the project and straighten me out.
    I usually just roll up my sleeves and dive in (over my head) and figure it out. That's why it takes me so long.
  21. When you talk to Guys that have to read a Book to get a job done, It's easy to tell the New guys from us Old Farts. It's like the Grill in this 51. People tell me all the time "that's the way everyone did it back in the Day" I specialy like the ones that say "I had one exactly like it" I already know the Brown Stuff is past there eye balls.
    The Wizzard
  22. U-235
    U-235
    Okay Mr Pist-n-Broke, how much is that grille bar modified....? They don't seem to fit right in a 51 as I always thought ...the ends at the front of the bar cut back at a 45 or so....it looks as if I would have to add metal.. Always heard or saw an article in R & C in the fifties that you just trimmed them to fit...I wonder how many were installed back then with the cut back exposed...?
  23. fordcpe
    fordcpe
    Here are some pics of my 34 firewall
    Cosmo49, hipster and TagMan like this.
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Architect Frank Gehry will love that.
  25. white64
    white64
    from Maine
    Put on some decent music or listen to a ball game, grab a beer (just one), and start taping... the taping is sortah tedious, but! it only takes about one song (3 minutes) to add the black paint, let the paint dry then pull off the rest of the tape..TAH DA! About two cans of white gloss rustoleum and one can of black and some tape (likely the most expensive part (more 3m price gouging...grrr)) about $25 bucks total (depending on the beer count) and 2 hours of otherwise idle time and you're done.
    Wrong way? A checkerboard is still a checkerboard regardless of how you got there...!
  26. WoW,, I must really be paying the price for being a Silver Back. 1 beer and 2 hours? Hmmm, must be time to throw in the Towel.
    The Wizzard
    Cosmo49 likes this.
  27. white64
    white64
    from Maine
    LOL! Got to keep the lines straight! I can stop at one beer, two not so easy because the third is so much nicer and easier! ..and after four! who gives a **** about taping anything! BEER ***ISTANT!
  28. MengesTwinCustoms
    MengesTwinCustoms
    Here is my model t firewall
    kidcampbell71 and hipster like this.
  29. ghalperin
    ghalperin
    Has anyone done horizontal stripes?
  30. ghalperin
    ghalperin
    Sam Foose’s ‘47
