Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
    Thanks Brand Apart! A/C is certainly not needed here in the flat country. No power steering either. I've set the engine back and in combination with the aluminium heads and close ratio rack, steering is not a problem.
    Have a great 2016!
  2. farmer12
    farmer12
    Sounds like a good plan Carsten. Have a great 2016!
  3. farmer12
    farmer12
    Fenders and grill mounted. Just the hood to go.
    Plung, Hogman, mgtstumpy and 9 others like this.
  4. DirtyNapkin
    DirtyNapkin
    from Napa, Ca
    Looks awesome.
    farmer12 likes this.
  5. farmer12
    farmer12
    One more side view.
    Plung, Hogman, mgtstumpy and 4 others like this.
  6. hasty
    hasty
    Looking good...
  7. WOW! Your car is looking great Eric!
  8. So close Eric, looking straight and smooth - any idea as to when they plan on spraying the black paint?
  9. farmer12
    farmer12
    Thank you gentlemen!
  10. farmer12
    farmer12
    Thanks Mike. Paint should going on this month.......but then again, it could be februari...
  11. farmer12
    farmer12
    Installed the brackets/running boards today. Final adjustments are still required in order to line them up perfectly with the body and fenders.
  12. nervs of steel you got! (patience related)
  13. farmer12
    farmer12
    Hahaha, thanks Carsten!
  14. 1959apache
    1959apache
    How's it going Eric?
  15. farmer12
    farmer12
    Progress has been slow last week.......fenders are now finally 100% correct in position.....still waiting on the hood hinges. Let's hope the next update will show a little more progress! Even my patience is slowly running out.
    Plung, Hogman, mgtstumpy and 3 others like this.
  16. farmer12
    farmer12
    Things are going a little slow at the moment Scott. Unfortunately you can't rush certain things. (apparently)
  17. charleyw
    charleyw
    "Even my patience is slowly running out."
    Hang in there, don't reach for the rattle cans yet!
  18. farmer12
    farmer12
    I still have some patience left, don't worry!
  19. OahuEli
    OahuEli
    from Hawaii
    Coming up on 6 years since you started this project. Did you ever think it might take this long? I gotta give you props on patience. I'd have said a bad word or 10 by now.
  20. milwscruffy
    milwscruffy
    Nov. 8th 2014, on the bright side you didn't say which Christmas !!! :cool:
    farmer12, Tanoki and wheelnutmarc like this.
  21. farmer12
    farmer12
    To be honest, I expected it to take a little shorter........unfortunately due to cir***stances it has taken longer. But I remain positive without saying too many bad words. You can't rush certain things.
  22. farmer12
    farmer12
    You are 100% correct.......
  23. farmer12
    farmer12
    On the bright side, I did manage to install the bench seat frames. I had to drill all the holes of the frames again, as they were covered in powder coat. Luckily I have long arms so I could reach under the car with a spanner, while tightening the bolts from the top.
    Plung, Hogman, mgtstumpy and 2 others like this.
  24. farmer12
    farmer12
  25. dirt t
    dirt t
    Still following you build. Good luck.
  26. OahuEli
    OahuEli
    from Hawaii
    Hows the car coming along Eric?
  27. SlmLrd
    SlmLrd
    from DAGO
    still following this one, can't wait till you're on the road!
  28. j hansen
    j hansen
  29. It has been a while since we heard from Eric, I'm sure we will hear from him soon... Makes you wonder why this shop is taking so long to finally shoot some gloss black on his car, with the body being so close to perfect. We'll know soon enough!
  30. dirt t
    dirt t
    I'm sure he wants closer too.
