Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. Falcon61wagon
    Falcon61wagon
    from Indiana
    Are the bell houSing the same on the 67 c4 and 3.03?
  2. Falcon61wagon
    Falcon61wagon
    from Indiana
    So that would be a no
  3. gimpyshotrods
    gimpyshotrods
    No.
  4. Gammz
    Gammz
    from Lincoln Ne
    my c-4 is a 1968.
  5. Bigcheese327
    Bigcheese327
    You have any do***entation on that? I don't doubt you, it's just something I've always wondered about and I collect that kind of thing for future reference.
  6. gimpyshotrods
    gimpyshotrods
    Just the word of a line worker at the San Jose/Milpitas ***embly plant.
  7. Gammz
    Gammz
    from Lincoln Ne
    MY Ranchero was built in San Jose!!!!!!! Awesome!
  8. gimpyshotrods
    gimpyshotrods
    My Falcon was built there too. It got really far (50 miles).
  9. Falcon61wagon
    Falcon61wagon
    from Indiana
    Is it possible to use the oem air cleaner with a Weber 32/36?
  10. gimpyshotrods
    gimpyshotrods
    Yes, if you trim it.
  11. redzula
    redzula
    What gimpy said. Although I'm pretty sure clasicinlines.com has a round filter base that fits the 32/36. At the very least it would be easy to cut a round hole in your base and weld in their base to yours.
  12. gimpyshotrods
    gimpyshotrods
    Except that it would not be a round hole. It's a diamond-shaped hole.
  13. Falcon61wagon
    Falcon61wagon
    from Indiana
    Why not cut that diamond hole into the bottom of the air cleaner?
  14. redzula
    redzula
  15. gimpyshotrods
    gimpyshotrods
    Nope. Cl***icInlines.com is a zombie website. The owner died, and they are out-of-business.
    If you want that, you will have to look elsewhere.
    I just took a gasket, centered it over the original round hole, traced it, and then trimmed out the excess with snips.
  16. redzula
    redzula
    Really? I just bought my distributor kit, and weber carb kit like a year ago. That's crazy.
  17. gimpyshotrods
    gimpyshotrods
  18. redzula
    redzula
    That it does.
  19. woodbutcher
    woodbutcher
    :D RedzulaGo to fordsix.com. and pm does10s.He might be able to help.
    Good luck.Have fun.Be safe.
    Leo
    Falcon61wagon likes this.
  20. AndrewnTX
    AndrewnTX
    from Plano, TX
  21. mcnally351
    mcnally351
    from boston
    ^^^ love that blue coupe.
  22. Gammz
    Gammz
    from Lincoln Ne
    My 1964 Falcon Ranchero.
  23. oldgrezmonke
    oldgrezmonke
    from Jackson TN
  24. woodbutcher
    woodbutcher
    :D Hi OGM.Thanks for the hot link to Does 10`s.
    Leo
  25. MUNCIE
    MUNCIE
    from Houston
    Just curious what is the widest tire that anyone is running without any mods on the rear of they're 64-65 Falcons? Currently I have 15's in the front (Runners) and a 215/70/14 in the rear on my 64. I've noticed with a shorter tire (Original 195/75/14's) my gears really woke up. Have plans to move up to 3.55's in a month or so, and then probably switch to 15x7's on the rear after the install. Just wanted to run a wider tire on the 14's for the time being.
  26. Gammz
    Gammz
    from Lincoln Ne
    I'm running 215/65/15 on a 15x7 wheel.
    MUNCIE likes this.
  27. Falcon61wagon
    Falcon61wagon
    from Indiana
    I'm putting the front end suspension back together on my 61. I'm using 65 Mustang arms and I've a few questions.
    1. Which hole do I elongate on the strut rod?
    2. Do I use the original steering stop? 3. If so, Which hole do I elongate on the steering stop?
    4. Should I use a steering stop from a 63?
    5.Can I switch to a 63 strut rod?
  28. gimpyshotrods
    gimpyshotrods
    1. Both, equally.
    2. You can, but you would have to elongate those holes, same way.
    3. Same as above.
    4. It would save you slotting effort and time.
    5. No, and even if you could, you shouldn't. Your current strut rods are adjustable. Later ones are not.
    6. Do a Shelby Drop while you are interested n there. Google it. It's almost free.
    7. If you have the scratch, install lower control arm adjusters. Then you can get a performance alignment, instead of an old lady car alignment.
    Traditional?
    MrModelT likes this.
  29. gimpyshotrods
    gimpyshotrods
    Oh and:
    8. I forgot what 8 was for.
    9. A 1" anti-sway bar that was supposed to be for a '65 Mustang.
    You won't believe it's the same car.
    Traditional?
  30. Falcon61wagon
    Falcon61wagon
    from Indiana
    I read somewhere that the 63 were adjustable.
    I did the drop.
    I'll check the LCA adjuster thing out.
    8. Your guess is as good as mine.
    I found out tonight on ttfn. That the early perches were greaseable bronze bushings. I guess I'll be taking off the aftermarket one and cleaning up the old one .
