Technical **Home Built / Homemade Parts Thread**
Discussion in 'The Hokey Ass Message Board' started by twenty8tudor, Jan 28, 2016.
  1. twenty8tudor
    twenty8tudor
    from Ohio
    I did a quick search and didn't find anything.. So figured I would try to start one..
    I have seen looked through a lot of great threads on
    homemade tools and equipment, favorite dash in a model A, show me your full fendered hotrod, favorite 32..
    Anyway I like to build as much as I can and I have learned A LOT! That brings me to the point...
    I have leaned a lot of different ways of doing things and making things while browsing around here and on other social media places..
    What i hope happens here is people can find ways to make custom parts at home in one thread.. maybe what tools they might find handy... And I would like to keep CNC stuff out due to not a lot of people having access to it at home..
    Oh and I don't wish for it to become a negative bashing other people's work thread... If you don't like the way something is done.. Show how it can be done better or safer! :)
    So anyway I'll show you mine if you show me yours haha!!!
    Put a headlight switch in the instrument panel on my 28 roadster pickup
    Bar stock of aluminum with a few steps turned it and a 1/2" hole drilled through the middle..
    Mounted it
    Little exhaust hanger out of some s**** aluminum
    Drill,tap, cut some notches, and slant the edges..
    Used a u bolt out of a cheap-o muffler clamp
  2. twenty8tudor
    twenty8tudor
    from Ohio
    Anything from the morning crowd to get this rolling?
  3. spinout
    spinout
    from Dallas, TX
    Looking forward to this thread. Gotta be tons of stuff that could go here.
  4. Most of what I own is either home built or modified to work as intended. nothing is a bolt on at my house. I sure wish that it was. LOL
    Going to watch this thread and maybe someday I'll even have something to add.
  5. ChucksCrib
    ChucksCrib
    from Uranus
    I cant post a pic. right now because my '59 1/2 ton is in winter storage but I drilled a hole through the center of two hockey pucks and use them as bushings for my Hurst, cradle style engine mounts....scored a few huge fender washers from Grainger to make the hockey puck sandwich.
  6. Stogy
    Stogy
    I posted this in another thread but hey it fits here and if anyone missed it there it is here...What is it? My 1929 Ford Sport coupe has a 1936 ford dash with no glove box. I could buy a press board aftermarket but that would be too easy ;) so I use my acquired knowledge, skills and tools and garaged it.
    I had to mod the corner due to fouling on inner gas tank.
    Tool/Material List...
    1) 1/8" (#30) Soft aviation rivets, Some hand (hammer) peened and others pneumatic "C" Squeezer with applicable 1/8" snaps/dies
    2) Pop rivets
    3) Soft Aluminum from metal store
    4) Beverly shear and tin snips
    5) Files-Round/Flat
    6) Sharpie marker
    7) Bristol board/tape/scissors for pattern
    8) Vise with round bar and square bar for forming
    9) Broken pilot aviation burnish tool for engine turning
    11) Clecos
    10) Drill Press
    12) Drill gun with #30 bits and (5/32" and 1/4" for slots
    13) Measuring Tape and 6"scale
    14) 100 degree 6 flute countersink for deburring and touch csking
    15) sand paper 240 -600 grit with aluminum polish
    16) Patience, time and some good tunes
    Now I just have to get it in :confused:
    twenty8tudor likes this.
  7. squirrel
  8. I think that we start threads like this all the time then they get buried and someone else comes along and wants to either show or see everyone's handiwork.
    I would personally like to think that for the most part we are not checkbook hot rodders, I know that this is not true but our core group at least is not entirely 1 800 hot rod.
    I got a one piece hood almost completely welded up from my A bone, it stated out like this:
    Went to this
    Then this
    and is currently a little farther along than this:
    Life is sort of in the way right now but maybe I can finish welding it and grind it out soon, like before next week soon. Its not a rotlieb or any of the other one piece hoods but out of necessity is has become what it is.
  9. Nailhead Jason
    Nailhead Jason
    Gott do some fine tuning to them but I built the motor mounts for the 259 stude in my tudors ch***is out of a 40 axle. used the rest of the axle making a drop out trans cross member, more cross members to follow...
    twenty8tudor and Stogy like this.
  10. Cool. We made a front cross member for an A roadster pickup out of the center arc from an A axle once. Old axles make good car parts of you have them. ;)
    Creative. :cool:
  11. Stogy
    Stogy
  12. Stogy
    Stogy
    ****** pics are not showing :rolleyes:
  13. Or if we are talking pie it could be Ho made. as in who's ho made it. :D
    Sorry I just couldn't resist.
    Stogy likes this.
  14. Stogy
    Stogy
  15. I guess the mods are still mad it me. :eek: :D
  16. Stogy
    Stogy
    Doubt it...could be the way your inputting them to your thread. I upload rather than drag and drop. Try edit/delete all those that don't work and re upload the same pics. Then go have some ho made pie :D. This (ho made pie) translated means a beer...
  17. twenty8tudor
    twenty8tudor
    from Ohio
    Thanks for posting stuff!! Never thought about using an axle for a crossmember. Very cool!
    Same s**** aluminum bar.. Used to make a fuel block.. Could be done easily in a drill press..
    1/8" pipe threads on all ports.. Then pipe to compression fittings
    Rolled and welded gauge panel
    UNSHINED 2 and Stogy like this.
  18. 56 Dodge Pickup
    56 Dodge Pickup
    Dash and ****** tunnel I made for my 37 Plymouth all steel Hobo Jim
  19. Dave Mc
    Dave Mc
    When I built my Phantom 33 Fordor Vicky Convertible I wanted accessible storage ( Trunk ) so I used the Rear part of the original Roof for the Rear Body Panel for the Opening and Dissected a Coupe Decklid to fit the opening , I cut the inner panel into 3 pieces and fitted the to the new opening then made an outer skin to fit. our pic`s 028.jpg our pic`s 040.jpg our pic`s 041.jpg our pic`s 044.jpg IMG_0209.JPG
    Hnstray likes this.
  20. vintage6t
    vintage6t
    from CT
    Work in progress. Parking/brake/signal lights to hang off the back of a 54 F100 I'm working on. Housing made from cylinder caps, guts from an old set of trailer lights, lenses from motorcycle turn signals.
    1454106189474.jpg 1454106231424.jpg 1454106244106.jpg .
    brEad likes this.
  21. Dapostman
    Dapostman
    My son and I am building a thirty’s speedster, probably over 80 percent so far is hand fabricated, the problem, the ch***is rails that are ***led are from a 1974 Postal Jeep so I would have to get special dispensation from Ryan to post the build, I can probably post some sub ***embly pics but then again it’s not a traditional build.
  22. twenty8tudor
    twenty8tudor
    from Ohio
    Had some fuel issues with trying to gravity freeing the stock tank.. So making a small 5.5 gal tank to go underneath and use an inline pump out of it..
    Start
    Little lathe work on some round stock
    Bungs for the fittings is what the round stock turned into
    Ran some pieces through the mill to fit them inside.. Forgot to take into account over lapping pieces..
    Makes for a nicer fit then trying to grind it down with a grinder
    Time to weld
    And now we have a tank to pressure check today..
    Hnstray likes this.
  23. 19Fordy
    19Fordy
    IMG_7330.JPG This is a one piece coil bracket support that bolts to the 49-53 Ford/Merc water pump. By remounting the stock 49-53 coil, it gives both your stock and aluminum heads a “clean, uncluttered” look as the stock coil no longer is bolted to the head. This is especially useful when installing early heads on the 49-53 Ford/Merc engine. Your stock 49-53 Ford/Merc coil bracket bolts to this support with two ¼-20 machine screws. This MIG welded bracket is of sturdy construction and is made of ¼ inch cold rolled steel. The bracket comes with a protective coat of red Rustoleum enamel which you can repaint to match the color of your engine. I'll make one for you if you want.
  24. bobbytnm
    bobbytnm
    Good stuff here
  25. jaxx
    jaxx
    Mopar tail lights - convex lens for my hand built 22 dodge rpu -hand made hood - ja**
  26. UNSHINED 2
    UNSHINED 2
    20161016_103203.jpg 20161016_094637.jpg I think you can tell what part this is.
    For when you don't have a plasma cutter and are out of gas in the torch.....
    Max Gearhead likes this.
  27. Max Gearhead
    Max Gearhead
    from Wisconsin
  28. twenty8tudor
    twenty8tudor
    from Ohio
    Needed to stiffen up the steering on a 32 I picked up so cut this out of some s**** box tubing
