Projects Anyone know of a place that makes (novelty) custom CA yellow plates?
Discussion in 'The Hokey Ass Message Board' started by Duesey, Jan 29, 2016.
  1. Duesey
    Duesey
    I'm trying to get a set of custom made 1955 California yellow plates with a specific tag--for novelty purposes only. Anyone know of a place or person that could do this? Thanks much!
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
  3. verde742
    verde742
    I think you can get the actual plates from DOV California.
  4. ratrod0
    ratrod0
    I think the place is called movie plates, or movie tags there in California
  5. Duesey
    Duesey
    Licenseplates.tv had every state but California. ******.
  6. coilover
    coilover
    from Texas
    Here's how we have made "Wall Art" plates. Spray a real plate with mold release (PAM) and cover with three inches of plaster of Paris. Give the unharmed real plate back to the owner. Pour a hard setting epoxy like 3M Panel Bond or Marine-Tex into the P.O.P. female mold and lay a rigid backing on while still wet. Drill alignment pins before separating. Now sand twice the thickness of your metal off the letters/numbers to give clearance for pressing into the mold. Place a slightly oversize blank plate in the mold, we use dead soft copper, and press plate down into the female mold with the male. We make sure the back side of the pop is flat and parallel and also "toughen" it up with a coat of POR 15. Break some--damn right; perfect--hell no, but surprisingly nice enough when in bar lit room and ten feet away. A real wood worker could make the male/female out of hardwood and make sure enough nice ones for use on soft aluminum/copper.
  7. dirt t
    dirt t
    There's a fellow that I met at the Pomona swap meet that will make you any year or type plate.
    I have a 1923 Arizona plate on my "C" cab that's rough he would reproduce it for $ 175.00
  8. Special Ed
    Special Ed
    They used to make 'em for California too, but had to cease and desist a few years back ...
  9. Duesey
    Duesey
    You don't happen to have his contact information, do you?
  10. winduptoy
    winduptoy
  11. flyboy89
    flyboy89
    from So. Cal.
    YOM 1955 plates were not yellow. They were black with yellow numbers/letters. "55 plates were also longer. Yellow plates were "56 through "62.
  12. Chrisbcritter
    Chrisbcritter
    They also had to drop Texas and Florida.
  13. Jalopy Joker
    Jalopy Joker
    there was a guy at the Turlock Swap meet today from Southern Calif that does plastic & metal - maybe someone going tomorrow can get info.
  14. rpm56
    rpm56
