1929 Model A Ford Tudor V8 Hot Rod
Discussion in 'Cars For Sale' started by side_valve, Dec 9, 2015.
  1. side_valve
    side_valve
    Alliance Vendor
    City: Deerfield
    State: Wisconsin
    Price: 14,500
    FOR SALE - 1929 Model A Ford Tudor V8 Hot Rod
    Here's a 1929 Ford Model A built in the 1950s tradition. I've driven this car from Madison, WI to shows in St. Paul, MN, Milwaukee, WI and shows south of Chicago. This Model A features a strong and fast 1947 Ford V8 flathead with rare speed equipment, 1939 floor shift transmission and 1969 Ford Bronco rear-end. The Tudor body features modifications such as welded and smoothed body seams and a 1957 Ford wagon roof insert.
    Check out these features:
    - Dropped and drilled Magnum I-Beam axle
    - Polished Stainless Steel hairpins, batwings, spindles and tie rods.
    - Pete & Jakes coil overs on the rear
    - 1946 Ford drums and brakes front, 1969 Ford brakes rear -- both 5.5" pattern
    - Good Firestone whitewalls tires
    1947 Ford V8 Flathead engine features:
    - High Volume Melling Oil Pump
    - Ross Racing pistons
    - Custom ground Schneider cam
    - 4" Mercury crank
    - Two original Stromberg 48s with 97 tops
    - Original Thickston PM-7 high rise 2x2 intake (not a re-pop)
    - Ford Generator converted to 12 volt
    - Offenhauser Aluminum heads
    - New high volume water pumps
    Watch video here:
    PM me with questions.
  2. side_valve
    side_valve
    Alliance Vendor
  3. side_valve
    side_valve
    Alliance Vendor
  4. side_valve
    side_valve
    Alliance Vendor
  5. side_valve
    side_valve
    Alliance Vendor
  6. side_valve
    side_valve
    Alliance Vendor
  7. side_valve
    side_valve
    Alliance Vendor
  8. side_valve
    side_valve
    Alliance Vendor
  9. side_valve
    side_valve
    Alliance Vendor
  10. side_valve
    side_valve
    Alliance Vendor
  11. side_valve
    side_valve
    Alliance Vendor
    bttt NEW PRICE!
  12. side_valve
    side_valve
    Alliance Vendor
  13. side_valve
    side_valve
    Alliance Vendor
  14. side_valve
    side_valve
    Alliance Vendor
  15. side_valve
    side_valve
    Alliance Vendor
  16. side_valve
    side_valve
    Alliance Vendor
  17. side_valve
    side_valve
    Alliance Vendor
  18. side_valve
    side_valve
    Alliance Vendor
  19. side_valve
    side_valve
    Alliance Vendor
  20. side_valve
    side_valve
    Alliance Vendor
  21. side_valve
    side_valve
    Alliance Vendor
  22. side_valve
    side_valve
    Alliance Vendor
    New lower price
  23. side_valve
    side_valve
    Alliance Vendor
  24. side_valve
    side_valve
    Alliance Vendor
  25. side_valve
    side_valve
    Alliance Vendor
  26. side_valve
    side_valve
    Alliance Vendor
  27. side_valve
    side_valve
    Alliance Vendor
    BTTT New Price: $14,500 !!
  28. side_valve
    side_valve
    Alliance Vendor
  29. side_valve
    side_valve
    Alliance Vendor
