Projects Awesome 1949 Ford club coupe shoe box build lot of pics!
Discussion in 'Traditional Customs' started by xrosczech, Feb 1, 2016.
  1. xrosczech
    xrosczech
    So here goes my build of this fine 49 club coupe. I bought it from an older fellow down here is SoCal who accepted the fact that at age 75 he wouldn't be able to build it. He brought it down from Colorado but it originally came from the territory of Alaska and gave me copies of the original ***le, pretty cool.. Only request he had is not to chop it, so no chop here. This box is all original, never repainted, personally I dig cars wearing their original threads sort of speak so no paint here either. Some hate the work patina so i'll say naturally weather exterior, all real rot will be fixed, and to boot it will be ford powered (the drive train was gone).
    Photo Jul 21, 4 15 00 PM.jpg Photo Jul 21, 4 15 05 PM.jpg Photo Jul 21, 4 15 17 PM.jpg
    Hnstray, bali-rod and droppedstepside like this.
  2. Jalopy Joker
    Jalopy Joker
    Wow, what a traveling project - so, no chop - how about a little sectioning?-Ha!
  3. EBW
    EBW
    Great start and sounds like you have your project lined out. Look forward to watching your progress.
  4. xrosczech
    xrosczech
    So picked up and then at my place. Also this 63 fairlane donated its drivetrain to the box (SBF, C4 and 8 inch rear) Photo Jul 22, 2 53 36 PM.jpg Photo Jul 22, 6 46 10 PM.jpg Photo Jun 25, 3 43 23 PM.jpg
  5. NewGuyOldFord
    NewGuyOldFord
    Shame for the fairlane. Love the wheels on it though. Seems like a fun project. Another power plant for the fairlane in the works I hope. BART.
    Hnstray likes this.
  6. xrosczech
    xrosczech
    The fairlane was sold to a guy that was making a thunderbolt clone, it already had the whole fibergl*** front kit, getting a 429 or 460 I believe.
  7. Finnrodder
    Finnrodder
    from Finland
    I think its a good choice to keep the top non-chopped.Those coupes rarely look good when they are chopped.Good luck with the build!
    56don, xrosczech and i.rant like this.
  8. xrosczech
    xrosczech
    Photo Jul 25, 3 07 51 PM.jpg First up, pull the front end apart and get the frame ready for a front sump pan. Also here is the donor drivetrain from the Fairlane. I kinda set the engine in to mark where the frame would be cut for the pan. Photo Aug 17, 12 32 48 PM.jpg Photo Jul 26, 11 16 20 AM.jpg Photo Aug 17, 12 32 56 PM.jpg
  9. xrosczech
    xrosczech
    So I marked the frame and used my handy plasma cuter and cut the section out. Then I made a cardboard template and boxed in the section of the frame. No turning back now! Before welding I cleaned the whole front section of the frame mostly with wire wheels and wire brushes, the agony! Photo Aug 04, 4 52 08 PM.jpg Photo Aug 04, 4 55 11 PM.jpg Photo Aug 04, 4 55 21 PM.jpg Photo Aug 04, 4 55 40 PM.jpg
  10. xrosczech
    xrosczech
  11. xrosczech
    xrosczech
    Took the template, cut the pieces with the PC, tacked into place, welded up, cleaned up (not perfectly on purpose) and POR 15'd the front of he frame. Photo Aug 05, 5 39 21 PM.jpg Photo Aug 05, 5 39 27 PM.jpg Photo Aug 05, 5 39 30 PM.jpg Photo Aug 05, 5 39 45 PM.jpg Photo Aug 05, 6 52 25 PM.jpg Photo Aug 05, 6 52 32 PM.jpg Photo Aug 05, 6 52 41 PM.jpg Photo Aug 05, 6 52 48 PM.jpg
  12. xrosczech
    xrosczech
    I made some plates to mount the engine using the Fairlane Photo Jul 30, 4 31 02 PM.jpg Photo Sep 05, 7 01 51 PM.jpg Photo Sep 05, 7 04 33 PM.jpg motor mounts, and extended the trans mount to work with the C4 and the stock cross member.
  13. xrosczech
    xrosczech
    I will use the factory kingpin suspension, Aerostar coils, disk brakes and probably drop uprights in the end. So all the suspension pieces got stripped and some POR 15 action too.
    Photo Sep 21, 6 48 28 PM.jpg Photo Sep 22, 11 43 48 AM.jpg Photo Sep 26, 12 53 55 PM.jpg
    bali-rod and EBW like this.
  14. Buddy Palumbo
    Buddy Palumbo
    Very nice start . I didn't chop my Club Coupe either (build thread in my sig below)
    xrosczech likes this.
  15. xrosczech
    xrosczech
    So after the front end was semi done and the engine and trans in place, I swapped the rear ends, I guess everyone says to use a Maverick rear but this 8inch 63 Fairlane rear was almost if not exactly the same width (perches need to be moved). Lucky I guess, as I had the Fairlane before I even thought about buying the 49, and I was able to use the drive shaft from the 63 too! So put it in with 4 inch blocks. last pick was before and after 4inch blocks Photo Oct 01, 7 06 30 PM.jpg Photo Oct 01, 7 06 49 PM.jpg Photo Oct 01, 7 07 01 PM.jpg Photo Oct 01, 7 08 57 PM.jpg , sorry for the poor quality Photo Sep 29, 6 30 35 PM.jpg
  16. xrosczech
    xrosczech
    Thanks Allen, I will def check out your build page!
  17. xrosczech
    xrosczech
    Next was stripping the interior, removing all the gl*** and the starting rust repair on the floors and rockers. I dont have many fabricating tools like a brake or bead roller, most of the shaping is just beating the metal on a vise or bench tops. Photo Dec 07, 1 38 14 PM.jpg Photo Dec 07, 1 38 32 PM.jpg Photo Dec 07, 3 09 42 PM.jpg Photo Dec 07, 3 09 47 PM.jpg Photo Dec 07, 3 09 52 PM.jpg Photo Dec 07, 3 10 01 PM.jpg Photo Dec 07, 3 10 08 PM.jpg Photo Dec 07, 3 10 13 PM.jpg Photo Dec 26, 4 45 01 PM.jpg
  18. xrosczech
    xrosczech
    Floor section repair. As with all learning experiences I would probably order a whole floor section if repair another floor, just saves time really, but hey I'm happy I tried. Photo Dec 07, 4 31 57 PM.jpg Photo Dec 07, 4 46 36 PM.jpg Photo Dec 07, 4 52 05 PM.jpg Photo Dec 28, 11 40 39 AM.jpg Photo Dec 29, 4 06 20 PM.jpg Photo Dec 29, 4 06 28 PM.jpg Photo Dec 29, 4 06 40 PM.jpg Photo Dec 29, 6 22 37 PM.jpg Photo Dec 29, 6 22 52 PM.jpg Photo Dec 29, 6 23 08 PM.jpg Photo Jan 03, 1 42 18 PM.jpg Photo Jan 03, 1 42 28 PM.jpg
  19. flathead4d
    flathead4d
    Wow! And I thought I had a lot of rust when I did mine. You definitely have your work cut out for you.
    Good job.
  20. xrosczech
    xrosczech
  21. xrosczech
    xrosczech
    Removing the factory tar insulation was the worst, next time I'll pay someone to that job! Heat gun, s****per, SOS pads and WD40 to get that crud off. Photo Feb 04, 4 02 41 PM.jpg Photo Feb 04, 4 02 58 PM.jpg Photo Feb 04, 4 03 04 PM.jpg Photo Feb 04, 5 56 22 PM.jpg
  22. xrosczech
    xrosczech
    So I made room for the trans by raising/making a new tunnel section. Photo Jan 25, 11 29 45 AM.jpg Photo Jan 25, 11 20 53 AM.jpg Photo Jan 25, 12 22 38 PM.jpg Photo Jan 25, 2 32 47 PM.jpg Photo Jan 25, 2 33 04 PM.jpg Photo Jan 25, 3 54 27 PM.jpg Photo Jan 25, 5 08 25 PM.jpg
  23. xrosczech
    xrosczech
    Once its was all patched up and cleaned up I primed the floor. I also got rid of the spare tire hump, wasn't digging Photo Mar 10, 2 25 51 PM.jpg Photo Mar 10, 2 25 58 PM.jpg Photo Mar 10, 3 12 01 PM.jpg Photo Feb 03, 3 08 37 PM.jpg Photo Feb 03, 3 09 00 PM.jpg Photo Feb 03, 5 45 27 PM.jpg Photo Mar 06, 4 36 42 PM.jpg Photo Mar 10, 4 23 48 PM.jpg Photo Mar 17, 10 17 39 PM.jpg Photo Mar 11, 8 59 20 AM.jpg it..
  24. xrosczech
    xrosczech
    Next up was the dynamat, another PITA!! Photo Apr 14, 5 41 24 PM.jpg Photo Apr 26, 4 45 00 PM.jpg Photo Apr 26, 4 45 08 PM.jpg Photo Apr 26, 4 45 20 PM.jpg Photo Apr 26, 4 45 37 PM.jpg Photo Apr 02, 1 40 20 PM.jpg Photo Apr 02, 6 50 10 PM.jpg
  25. Rathbone
    Rathbone
    Don't throw the headliner bows out with the headliner.
  26. xrosczech
    xrosczech
    Thanks, nothing that was to be reused was tossed!
  27. 2bubbas
    2bubbas
    Very nice job on the floor- I'm enjoying your build-
  28. Buddy Palumbo
    Buddy Palumbo
    Nice work
  29. Looking good so far. Like the others have said, no need to chop a coupe, they look good anyway (and hard to make look good chopped).
    Robbievanb and xrosczech like this.
  30. xrosczech likes this.
