Hot Rods Corroded Aluminum Pistons All response appreciated.
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Feb 4, 2016.
  1. Fortunateson
    Fortunateson
    I have 8 new Pistons for my 292 Y-block. Somehow they have gotten a bit corroded, nothing too serious. So, best method to clean them up? Wire wheel, gl*** bead, some liquid solution? My favourite method is electrolysis but I don't think that works on aluminum or does it?
  2. eagleeye8789
    eagleeye8789
    I don't "think" electrolysis would work but wire wheeling would be too rough and gouge the Pistons. Use some scotch bright if you have the time and elbow grease to spare. You could also use bras so or my personal favorite quick-glo. Check out this video-
  3. David Gersic
    David Gersic
    from DeKalb, IL
    Quick Glo? Wow, I haven't seen that stuff since my high school & college bike shop days. If it's the same as it was back then, it actually does work really well on surface rusted chrome.
  4. Soda blasting should work,,,,no personal exp.
  5. Jalopy Joker
    Jalopy Joker
    post pics of pistons
  6. bobss396
    bobss396
    Word... gotta know how bad they are. I saw this one "mechanic" at the shop I was with cleaning up some pistons that came out of an engine, using a wire wheel over the ring lands. I was 18 at the time and knew better... kept my trap shut as it was for his engine and he knew everything.
  7. hotroddon
    hotroddon
    Without pictures, advice is futile at best
  8. Grumbler
    Grumbler
    Bead blasting aluminum works best but you should be able to clean up with red scotchbrite as long as they aren't pitted. Absolutely no wire wheel
  9. Saxman
    Saxman
    How bad are they?
  10. Mark T
    Mark T
    Never blast pistons with gl*** bead, sand or anything abrasive, as mentioned above soda blasting is okay.
  11. 1946caddy
    1946caddy
    from washington
    Quite a few years ago I read an article about either painting or coating the top of the piston. Never did hear how that worked out.
  12. deathrowdave
    deathrowdave
    from NKy
    Look for a product named "strong arm" and soak them . I had a Harley flat head stuck for years , no spark plugs . Shot some strong arm into cylinders , spun free as new . Removed the jugs and Pistons soaked them looked new
  13. Grumbler
    Grumbler
    We gl*** bead very expensive aluminum aircraft parts , just regulate the pressure correctly and you won't damage anything. I agree sand is out of the question.
  14. Mark T
    Mark T
    Gl*** beads and other abrasives get embedded in the piston skirts, this destroys cylinder walls.
  15. gimpyshotrods
    gimpyshotrods
    If it is light, vinegar and a lint-free cloth.
  16. deathrowdave
    deathrowdave
    from NKy
    That is correct no beads or sand on Pistons , embeds into ring lands and skirts and scores walls and rings never seat .
  17. F-ONE
    F-ONE
    from Alabama
    That's odd. They must have been exposed to some type of oxidizer. Sometimes just being close to an oxidizer is enough.
    If there is any pitting and white chalky oxidation that will not clean up by hand, I would think really hard before I used them in a build.
  18. King ford
    King ford
    from 08302
    Maybe it will "buff out"
  19. Fortunateson
    Fortunateson
    Yes it is odd. I haven't had a chance to look at them that closely. Initially I thought a Scotchbrite pad might just do it but I posted the other ideas to get everyone's thoughts. I know if there is pitting they"'re done. Will update later.
  20. bobss396
    bobss396
    I deal with mil-spec machined parts (and the vendors..) every day. Some workmanship standards say out right that abrasive blasting is prohibited unless specified on the part drawing. We do a lot of vapor and soda blasting though, along with very strict procedures.
  21. seb fontana
    seb fontana
    from ct
    Vinegar wouldn't work?
  22. Wow, Quick Glo is the best chrome polish EVER!!!!!!!!!!!! Never tried it on aluminum tho.....
  23. dumprat
    dumprat
    from b.c.
    Boil them in a pot of water and vinegar or acetic acid toilet cleaner. Works great and no damage to the aluminum.
  24. bobss396
    bobss396
    I had some parts in acetic acid recently, didn't realize that 1 part was aluminum. It was badly eroded when I fished it out in a few days.
  25. Hotrodmyk
    Hotrodmyk
    Carb cleaner?
  26. dumprat
    dumprat
    from b.c.
    An hour is good. A few days is too much.
