Projects roadster tops home built
Discussion in 'Traditional Hot Rods' started by rustyrods, Feb 5, 2016.
  1. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
  2. May not fit the bill for what you're looking for but Clark here on the HAMB make a killer fibergl*** top for a sport coupe he built a while back. Covered in upholstery you'd be hard pressed to know any better at first glance. There's a thread on it I just cannot remember the search criteria. Maybe some has it bookmarked.
  3. Made this from scratch drawing heavily on Dana Barlow's thread on making his folding top. I got the lines right by covering it masking tape. The bows will be kept in the right position using Pirelli webbing. There's no mechanical connection between the back three bows and the front one - it's all done with the tension of the webbing. I still have to make the wooden header and then I will have it upholstered in either double duck or mohair.
    dana barlow and falcongeorge like this.
  4. I have been following me this with interest. Might want to make one next year. A lot of these look really good.
    I'd be interested in seeing pics of them folded down as well.
    dana barlow likes this.
  5. rustyrods
    rustyrods
    from Dixon,Il.
    Has anyone used the Irons Kit that sells on ebay for $315.00
  6. kevinwalshe
    kevinwalshe
    I was considering making one out of aluminum tubing, and Bimini hardware from a boat top. Has anyone gone down this road? I figure if it is covered with canvas, you'd never really see the hardware. Just a thought
  7. Gary Addcox
    Gary Addcox
    Presently, I run a Bop Top with curtains on my roadster. Since it is a long-distance ride, I would like to find someone who has a similar-looking liftoff top with flanges for installing custom-made plexigl*** panels. I know the Deuce is a roadster and not a coupe, but the wind noise from under the rear of the floating top and everywhere around the ****ty curtains is not unlike riding a motorcycle. A rigid, liftoff top would be better than a folding top because I think I could seal it tighter. I just have to keep the roadster instead of buying a coupe because of LARS. I saw some really fine examples of hardtops at Pomona in June. If anybody knows of someone with a hardtop for sale, please have him contact me here. Gary Addcox
  8. kevinwalshe
    kevinwalshe
  9. von Dyck
    von Dyck
    I bought 4 books on steam bending wood. Talked to numerous wood workers and received numerous and varied responses. I found the best reference to be "Wood Bending Made Simple" by Lon Schleining (2010) which includes a companion step-by-step DVD video. Made my own top bows using his technique.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thanks , good info ..
    dave
  11. joshuajardine
    joshuajardine
    from NSW OZ
    Here's what Ive cooked up.....
    Sth. Tweed Tuck N Roll.
    NSW
    Australia
    ratster, hfh, tr_rodder and 7 others like this.
  12. Grant Clemens
    Grant Clemens
    from Montana
    I just built this top on my Roadster about a month ago. It is made of sheet aluminum riveted to conduit and then covered with vinyl top material. It doesn't fold but can be lifted off. 20220216_160248.jpg 20220303_135604.jpg
    pecker head, hfh, VANDENPLAS and 3 others like this.
  13. Donut Dave
    Donut Dave
    I made this lift off top and had the Upholstry shop cover with Harttz cloth. I added a metal visor as part of the top ***embly.
    D182A99F-3BB1-4465-A519-252ECF37F80D.jpeg E6B4C608-F58B-46E0-AB7D-CBD6630B57B9.jpeg
    54reno, alfin32, hfh and 5 others like this.
  14. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Wow! How cool is that? That gives me inspiration to try making one for me '26 T.
  15. Stan Back
    Stan Back
    When you see one like the above, you're looking at one that can endure going fast. The "V" notch lets a lot of air off. The slick, curved one can let you see it go away when you're headed into a SantaAna wind. This car needs one like the one it has.
    hfh, VANDENPLAS and Okie Pete like this.
  16. Blake 27
    Blake 27
    My homemade steam bender.
    I used a 3' PVC pipe bent a little in order to keep the oak off the bottom while being steamed.
    My buddy had a propane burner (for deep frying a turkey) that my metal gas can fit perfectly.
    I used a piece of brake tubing across the center to hold up the wood. I drilled a drip hole to drain the condensation.
    Rags in the ends sealed in the steam.
    Here's a crude drawing and a picture. Worked Great! steam003.jpg DSC02693.JPG
    hfh, pprather and sloppy jalopies like this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Excellent ! You wouldn't happen to have pictures of your bending jig ???
  18. Blake 27
    Blake 27
    Once I had the shape determined, I cut it out of plywood. While researching bending, I read that after
    the oak cooled it would spring back a little so I over bent it some. I got lucky that it sprung back to my original shape. I used 1/8" oak strips that once glued, held their shape. 10.JPG 11.JPG DSC02686.JPG DSC02687.JPG DSC02688.JPG DSC02689.JPG In the jig I used a strip of Formica around the outside so the clamps wouldn't damage the oak.
    bct, hfh, Ned Ludd and 3 others like this.
  19. Blake 27
    Blake 27
    I like the shape of this one. 001-cramer-1931-ford-model-a-front-three-quarter.jpg
    A Boner, alfin32, hfh and 2 others like this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thank you ......so you steamed 1/8" strips , then bent them ,then glued the together ? Sometimes I'm a little dense ....trying to understand ...
  21. Dean Lowe
    Dean Lowe
    That's because it's perfect Blake!
  22. Ned Ludd
    Ned Ludd
    I love the proportions of that! I keep saying that A-pillars want to be at the midpoint of the wheelbase on cars of that era.
