Projects Grill design ideas
Discussion in 'The Hokey Ass Message Board' started by 01mikep, Feb 7, 2016.
  1. 01mikep
    01mikep
    i'd like to get an opinion on grill design. Right now I could go any direction and not married to any one idea.
    Options I can think of are:
    1. Stainless mesh almost 1/4 openings.
    2. Sheet metal with hole saw treatment.
    3. Sheet metal with louvres.
    Here is mine.
    See below for grill examples.
  2. Is no grill an option?
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Definitely louvers if those are your 3 options. But I would be concerned about adequate air flow.
  4. 01mikep
    01mikep
    I'm open to other ideas. This is just what I had been seeing.
  5. The Driver
    The Driver
    from Indiana
    I don't mean to hijack your thread but this is something that I m kicking around as well on my 34 pickup build. I have a shell that is missing some over the vertical bars and was going to the inside out and replace with a stainless panel. I never really considered louvers until you post that picture of the silver car. As someone mentioned above would louvers be hard to cool on the street?
  6. Have an example of the stainless mesh?
  7. adam401
    adam401
    Your car as is with no insert looks the coolest to me. Guess that doesnt help haha
  8. 01mikep
    01mikep
    This is Blue One's as an example.
    whtbaron and slack like this.
  9. Budget36
    Budget36
    Mesh looks nicest to me.
    How about 3/16ths or 1/4inch SS rods...polish them up, make an upper and lower attach plate, tack weld the in.
    I'm not digging the holes or the louvers.
    clem and slack like this.
  10. As budget36, I like the mesh way better than the louvers or hole saw treatment.
    Actually like no grill as well
  11. selectedgrub
    selectedgrub
    I like the mesh.
    The hole look could work if there were more and smaller.
    .... and dimpled. ;)
  12. Rocky
    Rocky
    Classified Editor
    No grille. This is a race car, right? Any weight is your enemy and especially weight on the front. Wind resistance at speed is also your enemy.
  13. I really like that top pic Vicky with a hemi.
  14. joeyesmen
    joeyesmen
    On your car, this might look better painted flat black . . . I think that stainless mesh (01mikep) looks pretty cool too. Or you could try bronze mesh, that might look good, especially after it fades to a dull brown.
    whtbaron likes this.
  15. cory27t
    cory27t
    from US
    Here's a couple good examples of grill shell inserts. The first is one that Skratch just built and the second is from Piero's Live Wire coupe. I think they both look fantastic.
    ImageUploadedByH.A.M.B.1454879793.228862.jpg ImageUploadedByH.A.M.B.1454879804.695912.jpg ImageUploadedByH.A.M.B.1454879814.750517.jpg
    j hansen and kidcampbell71 like this.
  16. scrap metal 48
    scrap metal 48
    lothiandon1940, clem, slv63 and 3 others like this.
  17. Just Gary
    Just Gary
    This is the ceiling ventilation duct grille from a downtown DC office building:
    And another one I made from sheet aluminum with 1.75" holes:
    lothiandon1940 likes this.
  18. That's KOOL ! Put that on the HOT ROD ART PAGE !!!
  19. Just Gary
    Just Gary
    Here are some more I saved off the HAMB when thinking about what I'd do. None are mine.
    Hope this helps.
    2in holes.jpg A RPU grill 01.jpg Curtis-08.jpg Picture%20055.jpg RoyalShifter 0.5 03.jpg DSC05852.JPG 58-9 Ford willys gasser grill.jpg
  20. Jalopy Joker
    Jalopy Joker
    how about a '51 Merc grill? Ha! looks like your mild ride needs the least resistance for short track racing
  21. Bert Kollar
    Bert Kollar
    Darby Wire Mesh has a great selection of ss mesh. I bought some from them for the same purpose but didn't use it. Contact me if you would like to buy it.
  22. Squablow
    Squablow
    Is it going to have a radiator in the shell? Because that's kinda hugely important to the conversation.
    clem likes this.
  23. 01mikep
    01mikep
    Yes. There will be a radiator.
  24. cfmvw
    cfmvw
  25. Atwater Mike
    Atwater Mike
    Why the 'A' shell on the 'T' bucket?
    Confuscious say:
    "Wide shell on T bucket give Henry 'Big Nose'."
  26. 01mikep
    01mikep
    Is this a restoration or a hotrod forum? Let me know if I'm off base.
  27. Squablow
    Squablow
    Is there a reason you want a grille in it? The car with the louvers above looks neat, but would give minimal airflow.
    I've seen pictures (unfortunately don't have any offhand) of drag cars of the era that had a flat panel insert for the grille shell that was removable with Dzus fasteners or something similar, the insert was just flat with no holes and usually had something painted on it, a sponsor name or whatever, so it could be taken off when needed. Might be fitting for the car you're building.
  28. I resemble that comment :)
    clem likes this.
  29. jjjmm56
    jjjmm56
    from FL.
    How about metal lath screening they use for stucco at lowes
