Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. 26 T Ford RPU
    26 T Ford RPU
    That's a nice peddle. JW
  2. nitrobrother
    nitrobrother
    That's a nice job! Digging' those carbs......
  3. Blue One
    Blue One
    from Alberta
    Time to say goodbye to the disc brakes :)
    Had to make some thick washers to make up for the backing plates being thinner than the disc brake plates, that allows the bolts to be tightened into the steering arms without bottoming out.
    I have one more task, the wheel studs aren't quite long enough due to the drums thickness, I'll have to source some longer ones. :cool:
    Larry brakes 001 (2).jpg brakes 002 (2).jpg brakes 003 (2).jpg 20160207_114131_resized_1 (2).jpg 20160207_114145_resized (2).jpg brakes 004 (2).jpg brakes 006 (2).jpg
    Uncle Lee, daddio211, brad2v and 4 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    Much better look. Those are really nice.
  5. AndersF
    AndersF
    Cool build. No short cuts, just the parts you want.
    Looking great.
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    yup...what he said
    kidcampbell71 likes this.
  7. Blue One
    Blue One
    from Alberta
    I didn't like the way the old boot from the MC worked for the throttle rod so I ordered a Stude-Avanti boot from that auction site.
    Once it came I made the appropriate 2" hole in the firewall.
    The boot has a 1/4" hole in it and my throttle rod is 3/16" Stainless rod.
    So, I slid a piece of plastic tubing over the rod and sanded down the diameter of it a small bit, then held it in place with a length of shrink tube.
    It now works and seals very nicely.
    20160221_133929_resized.jpg 20160221_153345_resized.jpg 20160221_154255_resized.jpg 20160221_154409_resized.jpg 20160221_154613_resized.jpg
    Uncle Lee, gonzo, daddio211 and 4 others like this.
  8. It is all those neat little details that you have do***ented here for us that once your car is completed, lots of people won't notice sadly. Sometimes it is a pity to paint and upholstery cars as so many things are hidden under carpet and paint which doesn't allow one to see how straight the body is and been repaired to.
  9. Blue One
    Blue One
    from Alberta
    I decided to change the way I did the wishbone ends front and rear as I had mounted them to the frame with 5/8" heim ends.
    I bought 4 polished SS 5/8" tie rod ends from So-Cal and a tie rod reamer (1.5"-foot = 7 degrees ) from Speedway motors so that I could fabricate a mount pocketed into the frame.
    The mount plates are 1/2" steel with the tapered tie rod hole.
    One down, 3 to go :D
    Larry
  10. brad2v
    brad2v
  11. 26 T Ford RPU
    26 T Ford RPU
    They will now match the drag link, looks good. JW
  12. Blue One
    Blue One
    from Alberta
    Another front mount ready to weld into the frame.
    Welded in and the fronts are done. I left the weld cleanup on the inside for when I take it apart for finishing.
    A good day in the shop :)
    20160312_152301.jpg 20160312_152400.jpg 20160312_154102.jpg 20160312_154753_001.jpg 20160312_154919.jpg
    gonzo, AndersF, loudbang and 5 others like this.
  13. Very tidy and now done the same as I have on my T. Just finishes the detail nicely I believe.
  14. rusty rocket
    rusty rocket
    That looks way better. The devil is in the details!!!!!!
  15. Blue One
    Blue One
    from Alberta
    The rear wishbone frame mounts required a different approach.
    Because of the contour of the frame the mounts had to be raised off of the frame rather than pocketed in.
    After a little thought I started out by pressing a 4 inch square piece of 9/64"
    cold rolled plate into a 3" pipe using an impact socket to form a cone.
    volvobrynk, loudbang and AndersF like this.
  16. Blue One
    Blue One
    from Alberta
    After that it was time to sleeve the frame, make the tapered bungs and weld them into the cones.
    Cut the cones down to fit the sleeves and fit and weld it all in.
    Whew! :D :cool:
    Larry
    20160319_105813.jpg 20160319_105342.jpg 20160319_111748.jpg 20160319_120806.jpg 20160319_121558.jpg
    gonzo, Barn Find, Rich B. and 7 others like this.
  17. nitrobrother
    nitrobrother
    That's a nice job.
  18. Just Gary
    Just Gary
    Thanks for posting all your beautiful details.
    Mind if I copy your throttle linkage?
    :cool:
  19. Blue One
    Blue One
    from Alberta
    Go for it Gary. :)
  20. Blue One
    Blue One
    from Alberta
    Well, I got a set of fibergl*** cycle fenders similar to the ones in this photo from a fellow in the UK, Mark Bull.
    They were not quite the right width for my tires so with a little work I widened them to fit.
    I'm going to be sending a pile of parts to Ogden Chrome in Ogden Utah for plating very soon. :cool:
    I wanted to have the cycle fenders for the option of running them if I want to even though most of the time I'll be running fenderless.
    And, I want them to look good instead of looking like an afterthought, or modified trailer fenders :rolleyes:
    It will make inspections and registration a lot easier as well ;)
    The cycle fenders look better when they are mounted close to the tire so for mounting brackets I think I like this idea.
    The external brackets and supports allow for closer to the tire mounting.
    I will probably fab up something similar.
    Larry.
  21. Trucker Jim
    Trucker Jim
  22. Dick Stevens
    Dick Stevens
    Tucking them in close to the tires does make them blend in and not stand out like a sore thumb.
  23. t-rod
    t-rod
    Why Ogden Chrome? I've heard good things about them, so I'm not questioning your choice, just curious. And, I work not far from their facility.
    Sent from my SM-G386T using H.A.M.B. mobile app
  24. Blue One
    Blue One
    from Alberta
    Mostly because they are pretty much straight south of me here in Alberta and also due to the fact that the guy at Alberta Plating is telling everyone he can charge whatever he likes and then does less than great quality work.
    I contacted a bunch of places, Jose at Ogden took the time to call me and discuss my needs.
    In the end they won't be the cheapest, but I'm convinced that they will do nice work.
  25. Six Ball
    Six Ball
    from Nevada
    Quality is worth paying for and going around someone with an at***ude is frosting on the cake. :cool:
  26. t-rod
    t-rod
    I've not used their services, but they do have a good reputation.
  27. Blue One
    Blue One
    from Alberta
    Since you work close to them you could always stop by for a tour of their shop and see some of their work and then report back here ;) :) :D
  28. t-rod
    t-rod
    Could do. And, if you make a trip out of the delivery or pick up of your parts, give me a shout.
  29. Blue One
    Blue One
    from Alberta
    Will do, not sure if we are coming down yet or not.
  30. t-rod
    t-rod
    So, I went to Ogden Chrome today, and ***o was very accommodating to my request to see the place on behalf of a friend. He first showed me where they work on bumpers, and explained what it can take to prep them for chrome. 1462233271367.jpg
    The next room is where small parts are restored and preped. 1462233407517.jpg
    Then, he walked me through the dipping room, and told me about the commitment to quality they have. Parts are dipped in copper, inspected, fixed more as needed, dipped again, inspected again, repeat as needed until the part is ready for the nickel bath. 1462233724720.jpg 1462233729556.jpg
    ***o walked me through the final inspection and packaging area and explained how they track a customer's parts through the process, so nothing is overlooked or mispackaged. He took a part of the shelf, wrapped in foam, and opened it so I could see the quality of work they send out the door. And, if a customer lives in the lower 48, Ogden Chrome covers the shipping to and from their shop. In Blue's case, he said to use a service which you send your stuff to the border and once your stuff crosses the border, Ogden Chrome will cover the rest. If Jose didn't already talk with you about this, he's the one to talk to. All in all, I would now not hesitate to use Ogden Chrome for any chrome work I need done. ***o said a few times, they're not a cut rate shop, not the cheapest out there, and the quality of the work I saw is worth it.
