Have my 1949 hudson 2 door super six for sale. Had this for awhile and getting it finished might be a long shot. Here is a list of whats been done too it. *Over hauled 1976 Olds 455 with a th 400 installed in the car. Never been ran after the tear down, all new seals replaced. Was in a running 76 olds 4 door when it was pulled. *1976 Dodge Valory torsion bar suspension and the rear end out of the the valory is under it. No drive shaft will need a carrier bearing setup cause of the lengh of the car. *Bullet tail lights, lake pipes ( have those they go with the car) all the sheet metal has been replaced if needed be. Under side is painted with black ch***is saver paint. It was on a rotisserie for the restoration cause its a unibody car. Painted ppg flaming aztec red. I have everything too finish the car interior bumpers etc. (All the major body panels are painted and cleared. The whole car could use another buff for fine scratches and polish swirls) *Frenched in 56 olds turn signals into the front fenders. Was going to run the staock grill setup on this. *Installed wireing harness needs too be finished Being hooked up. *Some parts and pieces need too be painted. *Was going to go red and grey on this but it can go all red if need be. *All in all the hard stuff is done just needs to be finished and put back together *Will need a radiator for this 70s dodge van is suppose to fit the stock radiator bracket with some t******* *Any questions or additional pictures you can send me a pm i check ever day sometimes several times a day. *Iam sure there is things iam missing so do ask. Thanks **Tried adding more photos but saying they are too large. Brad (3zero7) 2six7-2four2eight Can accept texts if need be . *****Clean wyo ***le****
