Technical Any one have American Classic 710-15's?? Sizes?
Discussion in 'The Hokey Ass Message Board' started by Rocket's Hot Rod Garage, Feb 8, 2016.
  1. I'm doing some tire shopping for a mild custom in our shop. We're wanting a slight rubber rake & I'd like to run the Coker American Cl***ic Bias Ply look radials. The issue I see is the 670-15's are listed at 28.24" tall and the 710-15's are listed at 28.21" tall? They're almost the same; but why? Why would they have almost the same tire with the 710-15's actually being shorter. I found another site where they actually list the 710" at 27.98" tall.....
    Is there anybody out there who has some 710's mounted on a car that can give me a real deal height measurement? Or some 670's?
    Thanks
  2. Chaz
    Chaz
    My 560/15's are 25 1/2"......
    I don't have any 710's ,but my source says 28.21 inches tall.
  3. Anyone have the 710's or 670's?
  4. Nobody has the 710's yet?????
  5. Jess H
    Jess H
    I happen to have access to a 710R15 American Cl***ic. Let me double check the overall diameter on one and I'll post.
    Thanks,
    Jess H.
    Coker Tire
  6. That'd be fantastic. Thanks
  7. Jess H
    Jess H
    Ok, a quick check on the 710R15 verifies it is around the 28.25" You might look at using a 670R15 in the front and the 800R15 in the rear to give you the rake you want. That would give you just over a 1" difference in height.
    Thanks,
    Jess H.
    Coker Tire
    Jessh@coker.com
  8. The thing I'm hesitant about is the difference in WW size. The customer wanted to stay with a smaller WW & sense it's a big body 50's car we don't want to exaggerate it much. I know the 670R15's are listed at 28.24" but how true is that? I just don't understand why they'd make 2 tires that are almost identical.
  9. Jess H
    Jess H
    The whitewall difference is only .5” between the 670R15 and a 800R15. Its your call on whether it will look ok or not.
    The 670R15 is very close to the 28.25”, I just measured one today, so bank on it.
    Both tires were developed for people whose cars use those sizes as a OE fitment. A person that has a car that used a 710-15 as a OE size, really isn’t going to want to use a 6.70-15. It’s the same reason we offer both the 670-15 and 710-15 in bias ply even though they are dimensionally close.
    Hope this helps. Feel free to call me if you have other questions.
    Jess H.
    Jessh@coker.com
    1-800-251-6336 ext. 263
  10. Jess, Thanks I'll be getting ahold of you shortly.
