1952-59 Ford Bolt on motor mounts for 460 in a '56
Discussion in 'Off Topic Hot Rods & Customs' started by Texas57, Feb 9, 2016.
  1. Texas57
    Texas57
    This is probably on of those topics covered a zillion times, that I never paid attention to because it didn't have anything to do with my build. I did go thru the FAQ stick, couldn't find anything. A '57 forum member is helping a friend install a 460 in a '56 fairlane g***er. They would like to use bolt on motor mounts to the original oem crossmember. Is there such an animal? and if so, who/where?
    Thanks
  2. Edsel58a
    Edsel58a
    A friend used a modified Lincoln mounts. I thought Fox Mustang mounts would work since Fox SBF mounts work.
  3. yblocker
    yblocker
    from Layton Ut
    I have a set I bought from Crites, I just today decided I'm going to put a sbf in it I'll sell them 127$ unused
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. Edsel58a
    Edsel58a
    To specify, the Fox 429/460 mounts will work, not the 5.0 mounts
  7. Texas57
    Texas57
    I p***ed a link to this thread to the '57forum member, but you may want to pm me your contact info. I'll p*** it on to them in a pm also.
    Just to verify, yours are for a 460 in a '56 and are bolt on?
    For my own curiosity, Jeff...the 400M articles you posted a link to...the 400m is same block as 460?
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    No it is 100% like the 429-460 It is similar to the Cleveland and can even use Cleveland heads.But it does according to the Hot Rod link share bell housings and transmissions with the 429-460.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
  10. yblocker
    yblocker
    from Layton Ut
    Call Crites in Asheville Ohio, they had mine to my for in 1 week 127$ shipped.
