Projects 32 5 window build
Discussion in 'The Hokey Ass Message Board' started by Novaron, May 4, 2014.
  1. seadog
    seadog
    On My New Age 5 window I sprayed the inside floor AND the outside bottom of the car with Lizard Skin. The inside was also covered with DynaMat. Lizard skin on the underside of the body seemed to help with sound deadning and it makes a nice, tough finish for underneath the car, which on a driver won't get seen anyway. Just p***ing this along...your build looks great!
  2. Novaron
    Novaron
    from New York
    Thank you. I like the lizard skin idea.
  3. Novaron
    Novaron
    from New York
    Four coats of SEM Trim Black on the bottom. Direct to gelcoat-no primer as per manufacturer's instructions . Scuffed with 400.
  4. Novaron
    Novaron
    from New York
    Trans tunnel epoxied in. 24 hours to cure for fairing, prime, and paint.
  5. Novaron
    Novaron
    from New York
    Firewall primed. PPG NCP 271 primer. 4 coats.
  6. Blue One
    Blue One
    from Alberta
    If you are painting in your garage, pop over to my garage painting thread and share how you set up your "booth" and all the other details.
    Larry.
  7. Novaron
    Novaron
    from New York
    Just about done cutting and buffing the frame. Wet sanded with 2000, then 3000. Used 3M compound, then machine polish, then ultra fine to buff.
  8. Novaron
    Novaron
    from New York
    Firewall is painted but not cut and buffed. Trans is rebuilt with a shift kit and a 2000 rpm stall converter.
  9. loudbang
    Dam that frame is fine looking.
  10. Novaron
    Novaron
    from New York
    Well thanks. It's not perfect like a pro would do, but I'm happy how it came out. I learned a ton of stuff about painting. Now the fun begins. Re***embly and taking the time to detail everything as it goes back together over the winter.
    Merlin, rexrogers and 54reno like this.
  11. Novaron
    Novaron
    from New York
    20151223_094551.jpg Ch***is back together.
  12. Novaron
    Novaron
    from New York
    Body going back on.
    1932 Ford chassis finished.jpg 1932 Ford body mounting2.jpg 1932 Ford body mounting5small.jpg
    buck 32 likes this.
  13. loudbang
    Must be nice still having good weather so you can keep working on it now.
  14. Novaron
    Novaron
    from New York
    Love it!
  15. Novaron
    Novaron
    from New York
    A bit OT, but thought some of you might enjoy my latest find. A c1915 Van Norman Model 0 milling machine. Can't find much info bout it.
  16. Novaron
    Novaron
    from New York
    Doing some wiring. Mostley done with that. Wanted to make a different shifter pedestal.
  17. Novaron
    Novaron
    from New York
  18. Novaron
    Novaron
    from New York
    Made a jig to bend the flatbar.
  19. Novaron
    Novaron
    from New York
  20. Novaron
    Novaron
    from New York
    Getting there. Milling a slot for the nutral safety switch wires to exit. shifter mock up  with mill.jpg shifter mount 4.jpg
  21. Novaron
    Novaron
    from New York
    Almost done. I'll get this tig welded by a friend and then chromed.
  22. loudbang
    NICE improvisation..
  23. Novaron
    Novaron
    from New York
    Thanks.
  24. Novaron
    Novaron
    from New York
    Brake pedal back from the chrome shop and installed.
  25. Novaron
    Novaron
    from New York
    Back on the road, just in time for spring!
    loudbang and elgringo71 like this.
  26. Novaron
    Novaron
    from New York
  27. Bigbangtheory
    Bigbangtheory
    from ohio
    Just read through the whole thread again, great job and your car looks awesome!
    Novaron likes this.
  28. elgringo71
    elgringo71
    Congratulaciones on an excellent build. Now you get to drive it and work the bugs out.
    Novaron likes this.
  29. 1-SHOT
    1-SHOT
    from Denton
    image.jpeg I have followed your build and congratulations on it. The looks *****in, just need to get off my *** and finish mine. Grand son can't wait.
    Novaron likes this.
  30. Novaron
    Novaron
    from New York
    Thanks all. Though it looks painted in the pictures, the body is still bare gelcoat. Lots of small stuff to do. Would like a nice stereo, need to install the blinker indicators and hi beam indicator. Finish the roll bar. Next up is dye the seat black. Any suggestions? Leaning towards regular fabric dye, though I've read some info on cloth and vinyl paint, and even something called chalk paint.
    Next winter I'll start the body work and paint. Who knows when I'll get to the interior. Just gonna enjoy for the summer.
