Projects 29 roadster highboy build
Discussion in 'Traditional Hot Rods' started by kracker36, Feb 11, 2016.
  1. kracker36
    kracker36
    Im working pretty hard now on a 28-29 roadster build. Brookville body with an original 32 v8 frame. I pinched the front and rear of the frame yesterday and almost finished up the boxing job today. I pinched the front 1 1/2" on each side. Boxing with ASC plates that I already had. I mocked up a 40 Ford X member tonight. Hoping to use it. I ve been planning on running a 260 SBF that Ive already built, but Im still considering a 292 Y that I have also. Ill post pics ASAP.
  2. kracker36
    kracker36
  3. kracker36
    kracker36
  4. kracker36
    kracker36
    Before and after pinch
  5. kracker36
    kracker36
  6. kracker36
    kracker36
    ***embling a dropped 40 axle with 40 spindles, F100 brakes, F1 steering box, and posies spring.
    Running 16x3.5" fronts on 450-475-16 tires and 14x4.5" rears on 700-16s.
    Restoring banjo wheel as well
  7. kracker36
    kracker36
  8. kracker36
    kracker36
    Glad I got a Brooville body, because Ive spent 4 days doing body work on 4 Merc hubcaps. The one in the pic is finished. I do ceramic coatings in my shop and this cap is done in KG Industries gun kote. Stainless steel with black, red and br*** accents.
    BenLeBlanc likes this.
  9. kracker36
    kracker36
  10. Atwater Mike
    Atwater Mike
    Ha! Jerks used to file into my shop in numbers, '76, "What'cha doin' that for?" I must have pinched '32 rails 'til I drew blood...
    Nothing on the charts makes a nicer fit, time spent here is golden later on.
    One piece look, like it 'grew there'...
    I'd get a sculpted fit, then the honiocks would paint the frame and body different colors, like a 'Goodguise Tutone'! That's what I called it... (I call 'em like I see 'em)
    Polite mode: "After careful blending of the two, I saw it necessary to enhance the fit with common colors..." (making mouth as 'small as I can')
    gwhite and lothiandon1940 like this.
  11. kracker36
    kracker36
  12. kracker36
    kracker36
    64 model 260 bored .030. milled and ported 68 302 heads. ( if I save the Y for a 29 coupe!)
  13. kracker36
    kracker36
    True Mike. Its soooo much nicer looking now sitting on the frame. If it was a 30/31 i could live without it, but not on the 29
  14. kracker36
    kracker36
    Tony at Astro Performance transmissions built my 64 model borg warner T10. Looking for shifter now.
  15. kracker36
    kracker36
  16. kracker36
    kracker36
    Deciding on this super cool SW panel or going with a 42 merc dash. I already have a speedo for the merc redone by Williamsons Instruments in Chester Arkansas. Top notch work from them!!
  17. kracker36
    kracker36
  18. kracker36
    kracker36
  19. Atwater Mike
    Atwater Mike
    Hot Rods always gained 'DeLuxe' status with Merc parts.
    Your dash and caps are 'Kracker-Jack!'
    lothiandon1940 likes this.
  20. kracker36
    kracker36
    Intake for my 292. My coating on the intake, carb bases, and stacks. Carbs by Rudy Faltermeier
  21. kracker36
    kracker36
    The y block is getting Merc valve covers and I have early edelbrocks for the SBF if I use it
  22. Macy
    Macy
    Do u have any frame diagrams for where you pinched the rails? I'm working on the same set up. I have the wescott diagram for where to pinch it in the rear but find no info on pinching it in the front
  23. kracker36
    kracker36
    Macy, I actually put my body on my lift and rolled my frame underneath to mock up. I spot welded the frame to a rolling structure that I built to help hold the frame in place while I welded on it. I just decided where I wanted the body to be positioned on the frame and marked the places where the frame needed to be altered to follow the body lines. I made cuts into the top and bottom of the frame in these places, and used ratchet binder to pull in the frame. I would cut the spot welds holding the frame to the table as I went. Worked pretty well.
  24. Macy
    Macy
    Ok cool I'm actually doing it the complete opposite way haha. I have my body spot welded to a frame table. I'd love to see pics of where the rear cross member sits if u have any tho. Thanks
  25. lothiandon1940
    lothiandon1940
    Watching the progress and loving it so far. Nice work. like the Merc caps.
    kidcampbell71 likes this.
  26. brady1929
    brady1929
  27. Super Streak
    Super Streak
    from Florida
    That's a great project, I think the Y block would be the way to go with it. Keep up the good work.
  28. Jalopy Joker
    Jalopy Joker
    Wow - ya doing good
  29. VonKool13
    VonKool13
    Just my 2 cents.....but why gather all those rad early parts, achieve the "look" just to screw it up with a modern motor? Even though it's a 60s motor, it isn't vintage enough to roll with that car. Just sayin. Go y block atleast. Really, I would save the money to go flathead or even 331 caddy. That's what I'm doing, gonna add extra time to my build because a good flatty isn't cheap or plentiful, BUT it's going to be a rad payoff..... your car do as you like, just throwing it out there. By the way, great looking build.
  30. woodhawg
    woodhawg
    Hot Rod ****! Love it. I like a SBF in an A roadster, that is what I built. It fits better into an A with 32 frame. Still may have to scoot radiator up or cut firewall?
