Just had a guy tell me 327 valve covers fit different than other sbc valve covers. I thought all sbc were the same
OTE="Jalopy Joker, post: 11385543, member: 19213"]depends on date of manufacture[/QUOTE] Wha Whats different?
Prior to 59 have staggered bolt patterns. If you find a staggered set you really like you can get an adaptor to run them.
Some can be "flipped around" on the same head, others, when they're "flipped around", make contact with the rocker arms. The 327 covers with the "box" in the center are good for either way. Some of the 305/350 covers, with brackets on top for securing wires to, can't be "flipped around" at all. Most aftermarket covers are good for however they're installed. The old script covers also contact the rocker arms if "upside down". I can be dependent on lift at the rocker arm. I am Butch/56sedandelivery.
Not a fitment issue, but there was IIRC, a one year only 327 valve cover(62-63ish) that had a slightly different rectangular decal pad, possibly in length only but also something about the area in the stamping where it transitions from the decal pad to the end. Have not found a photo yet, but I have physically seen a pair.
there are 3 basic common stock bolt patterns for SBC rocker covers. Stagger bolt, straight bolt ( both of those are perimeter) and center bolt. So the 327 rocker covers will fit all straight bolt heads given that the covers are stock and the heads are stock. They will not fit stagger bolt heads or center bolt heads without an adapter of some sort.
One more odd one that i have heard discussion about is the (IIRC), a 67 only and Canadian Pontiac only 327 valve cover that is basically the 283 style without the Chevrolet script stamped in it. I have also seen pictures of the earlier staggered bolt covers for the Canadian Pontiacs with Pontiac embossed in them. Hoping our intrepid fact finder @falcongeorge from "the great white north" will check his files for some photos.
I have seen late 327s with a 283 style rocker cover minus the script. That would have been a large journal 327 and the covers were punched for PVC. I have always had a soft spot for the 327 turbo fire style rocker covers. They actually seem to be the most rare of all the SBC rocker covers these days. If I ever get rich and the stars align I am going to get two sets to make myself on good set of tall rocker covers out of.
My apologies to @binderbart. One more OT but little known valve cover is a finned aluminum version of the Corvette staggered pattern 283 cover that has a plain center with no ID between the fins. I have heard talk of it being used on the 283/270 hp and 283/283hp engines in the regular p***enger cars. Possibly another Canadian application, but not sure.
The late fifties Canadian Pontiac valve covers have "Pontiac" stamped in them. That guy from Maple Ridge that had his '34 in R&C had a pair on his car.
Yep those minus the chrome. (my 302 had those ones when I pulled it from the wrecked vette in the '70s)
Wow. This site is very useful. The knowledge is overwhelming. I enjoyed reading every post and will refer back to this I'm certain. Here's the deal. I just picked up a 60 impala with a fresh 327. It has the cheap chrome valve covers and I would like to put a set of Mickey Thompson's on it. I'm a 3rd shifter and headed home for a short nap but plan on working on the car later till the better half gets off at midnight. I'll take some pictures and post later. From the numbers on the block we're coming up with a 1965 327. Thanks for all the replies.
There is actually a quick fix for cheap chrome valve covers, some medium grit sand paper and a couple of cans of paint. LOL I guess I am a dumb *** but I have never liked chrome valve covers much.
Denny, I've never seen or heard of these before. I do have some 9 fin covers that I got off a Toyota pickup in 1968. I bought him some brand new 'Vette ones & traded him.
I love chrome valve covers....if they're old chrome. Not the modern chinese **** (and by this I mean not the ****py 70s japanese ****, or the 80s Taiwan ****, etc either)
I'm sure we'd all like to know why the pet****? Something added for some reason. I have a pair of STAGGERED pattern Mickie Thompson valve covers; on the inside is casted, "Chev 327" (???). We all know the 327 came out in 62, 3 years after the staggered valve covers from the factory stopped (mid 59). I'm saving them for one of my builds, a 292 with a factory dual quad setup. I'd sure like to have a pair of those "PONTIAC" valve covers. They appear to be staggered; did they come in both staggered and straight across styles? I am Butch/56sedandelivery.
No idea, and its not original, just on the valve cover in the photo. I think they were also in straight, but not 100% certain.
Theres been a couple times in my life when I could have used one leading into a combustion chamber...
these were 1962 only. they are so similar that last year at a swap meet where I had several sets of stamped steel chevy covers someone grabbed one of each and bought them as a pair. I didn't notice until I got home and had only one 1962 cover left. there is a pair on ebay right now: http://www.ebay.com/itm/Corvette-an...ash=item542375b775:g:tcsAAOSwu4BV2i3~&vxp=mtr
