buick engines... how do i tell the difference?
Discussion in 'The Hokey Ass Message Board' started by oldskool55, Mar 1, 2006.
  1. oldskool55
    oldskool55
    from socal
    how do i know if i have a buick 350 or a 455?
  2. Judd
    Judd
    Try here.
    http://www.v8buick.com/
  3. oldskool55
    oldskool55
    from socal
  4. squirrel
    You just look at it...if it's huge, it's a 430 or 455. If it's not very big, then it's a 350.
    you might try going to google.com, click "images", then type in
    buick 350 engine
    and then try it with 455. maybe that'll help?
  5. 350's and the 400-430 & 455 look very similar and it's easy to make a mistake.
    One failsafe way, and it's easy is to look for three 1" high cast in numbers on top of the bellhousing area above the flywheel/flexplate.
    These can be seen most times with the engine in the car.
    Bring a flashlight.
    I've seen these numbers on 430's and 455's, but am not sure if they are on the 400.
    There's also a set of cast in numbers on the block sidewall behind the starter.
    These are about a 1/2" high.
    If I remember right, these numbers are upside down.
    If you do the bore and stroke measuring bit, the stroke on the 430 and 455's is the same so you'll need a head removed so you can measure the bore.
