Projects The Black Cavendish
Discussion in 'Traditional Customs' started by Eric H, Sep 23, 2012.
  1. Eric H
    Eric H
    Thanks! He is a good friend and very talented.
  2. Eric H
    Eric H
    Thanks Ryan! That's extremely encouraging!
  3. xrosczech
    xrosczech
    Great build, looking good!
    Eric H likes this.
  4. KCsledz
    KCsledz
    Excellent work. So much effort put into the small details.
    Eric H likes this.
  5. Peanut 1959
    Peanut 1959
    Colooooor!!!
    Eric H likes this.
  6. voodookustoms
    voodookustoms
    Eric H likes this.
  7. K13
    K13
    He is widening the hood gaps by cutting out a thin strip (the width of the cut off wheel) hammering the outside flange in to eliminate the gap created by the cut off wheel and then welding it back together again. Conversely if he was trying to reduce the hood gap he could do the same thing but push the flange out and put a filler strip of metal in the gap created and again weld it back up.
    voodookustoms and Eric H like this.
  8. voodookustoms
    voodookustoms
    Ok that's what I thought was going on. Thank you for explaining it. Is there a good tutorial somewhere on here I could get some more pointers on before trying it on my car?
    Eric H likes this.
  9. The 39 guy
    The 39 guy
    Top is looking great!
    Eric H likes this.
  10. Royalshifter
    Royalshifter
    Moderator
    Looking outstanding Eric.....there needs to be a gathering of the Shoeboxes at the GNRS in one of the main buildings because there are some beautiful Mercs out there but in the past few years there are some stunning Shoeboxes also.
    EBW, Eric H and daddio211 like this.
  11. daddio211
    daddio211
    Make it several years out so I can get mine done too!
    EBW and Eric H like this.
  12. Eric H
    Eric H
    Thanks Mark. That would be really great to see.
  13. Finnrodder
    Finnrodder
    from Finland
    Friend of mine was at the GNRS at this year.He said to me that i should really go there.
    Well,shoebox gathering could be an another good reason to make a visit there..
    Eric H likes this.
  14. Eric H
    Eric H
    image.jpeg image.jpeg Third times a charm. Finally got some paint on without leopard spots.
    Gotgas likes this.
  15. Finnrodder
    Finnrodder
    from Finland
    Still looking great!
    Eric H likes this.
  16. loveoftiki
    loveoftiki
    from Livonia,Mi
    Wow....hope to see this car at some Detroit events this summer...very nice work
    Eric H likes this.
  17. Eric H
    Eric H
    Thanks man. It will probably be at the Relix show this summer.
  18. Eric H
    Eric H
    image.jpeg image.jpeg image.jpeg Started fitting the 54 Merc hood. I'll cut and **** weld as I go. I will then replace the chrome scoop with rod and sheet metal.
    tomkelly88 likes this.
  19. Peanut 1959
    Peanut 1959
    Now that's a mod I don't recall seeing on a shoebox, before! Very interesting.
    Eric H likes this.
  20. Ltorch
    Ltorch
    Thats funny your putting that scoop on And i think that is the worst part of my 54 merc i want to take it off.
    Eric H likes this.
  21. Eric H
    Eric H
    image.jpeg image.jpeg image.jpeg Picked my top up from the painter.
    Tuck, drdave, tomkelly88 and 2 others like this.
  22. K13
    K13
    Look forward to seeing the hood scoop done.
    Eric H likes this.
  23. Torchie
    Torchie
    I am as well...........
    Great transformation.
    Torchie
    Eric H likes this.
  24. The roof looks awesome, Eric
    Eric H likes this.
  25. Eric H
    Eric H
    image.jpeg image.jpeg I have the 54 hood cut and tacked in. Now I'm making the scoop from scratch.
    biggeorge, Gotgas and K13 like this.
  26. Peanut 1959
    Peanut 1959
    I'm confused. Aren't you using the Merc scoop?
  27. Eric H
    Eric H
    No, it's too busy. I'm building the scoop from rod and sheet.
  28. Finnrodder
    Finnrodder
    from Finland
    I wasnt sure about that scoop idea,but i think that rod/sheet scoop will work fine.
    Eric H likes this.
  29. I liked the way the scoop echoed the shape of the grill insert. But I see you retained that shape in your re-do of it, so it still works. And the new version is much less "busy." I like it!
    Eric H likes this.
  30. Gotgas
    Gotgas
    from DFW USA
    This car is looking amazing. Love the Merc hood scoop on the shoebox! I always thought they needed something.
    They do look better with the trim removed and an opening added. Kind of '50s jet inspired. To each their own!
    Kage, Tuck, biggeorge and 1 other person like this.
