Technical 700 r4 tv cable bracket help needed
Discussion in 'The Hokey Ass Message Board' started by cobalt333, Feb 13, 2016.
  1. cobalt333
    cobalt333
    i got this bracket for my tv cable.. i know the tv cable snaps in the far square hole...but what the one in front of it for and what is the one in my hand that was shipped loose and not attached for and if used where does it go? im sure one has to be for the throttle cable...thanks ps no instructions shipped so ive got nothing
  2. cobalt333
    cobalt333
    ps if you have a picture of yours hooked up it would be great
  3. squirrel
    yeah it's for a throttle cable.
  4. tb33anda3rd
    tb33anda3rd
    is that installed correctly? the throttle cable should be mounted higher than the tv cable. i think the "extra" bracket is for a alternative style cable.
  5. tb33anda3rd
    tb33anda3rd
  6. themoose
    themoose
    Should look more like this....
    belair and RICH B like this.
  7. Oldbill51
    Oldbill51
    themoose is telling you straight, and to be honest the bracket on your carb linkage is the most important. Both Jegs and Summit sell what they call a corrector bracket. It bolts to your carb linkage and provides the correct amount of travel throughout the throttle rotation on the way to wide open throttle.
  8. cobalt333
    cobalt333
    looks like the front one needs to be flipped up or the one in my hand needs to replace it but again flipped up...not like they have it attach right in front of the tv cable one
  9. cobalt333
    cobalt333
    yep im thinking your right..its for a different tv cable..and i dont need it cuz the tv cable fits the one on it...and that front bracket needs to be turned up not like how they sent it...thanks
  10. RICH B
    RICH B
    You need to get a 700R4 arm for the carb too.
  11. cobalt333
    cobalt333
    yep already got one of those a couple of days ago..
  12. cobalt333
    cobalt333
    already looking better...have to get the throttle cable on there and have a pro set the tv cable tension
    Chucky likes this.
  13. jazz1
    jazz1
    That pic should be included in instructions. Been there done it. My last build was first time I had installed a automatic, never thought I'd see the day....
