home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. Leakie
    Leakie
    Very cool bike too, you do some great work! What are those tires on the bike?
  2. BuiltFerComfort
    BuiltFerComfort
    I like the mower concept, but better use it only as a finish mower on dry gr***. Wet gr*** clippings will clog up those fenders.
  3. porsche930dude
    porsche930dude
    thanks those tires are from a vw beetle they were so old and dried out i had to run tubes in them but that was fine because the spokes needed sealing anyway. The wheels are porsche 914 wheels with the centers cut out. theyre basicly the same as vw wheels i think theyre all 5.5" wide
  4. dirty old man
    dirty old man
    Nothing to add right now, just resubscribing to the thread lost subscription in the last big change Ryan made. Glad I found this again.
    stealthcruiser likes this.
  5. Jethro
    Jethro
    P1010018.jpg P1010013.jpg P1010014.jpg P1010015.jpg I'm a little late to the party but this is what I just made. It's a Ball/ Radius turning tool for my lathe. Every time i wanted to make a knob or handle I couldn't get a perfectly round ball or make a nice smooth radius so a little searching I found some plans for one of these. Pretty happy with the results! P1010013.jpg P1010013.jpg P1010014.jpg
  6. If you have an air supply, and a couple of hours or so, try using a truck park brake roto chamber and the park brake disk &
    caliper. You can fit a regulator in line to slow the reaction. Worth a go
  7. redzula
    redzula
    Most truck brakes fail on don't they. Meaning all you'd need to do to lock the brakes on would be to remove the air.
    russellmn likes this.
  8. redzula
    redzula
    Most air-brakes fail into the braking position. Meaning locking it in a position would be as simple as removing the the air supply.
  9. Ulu
    Ulu
    from CenCal
    Too complicated. You need a rod and a pedal to work the shoes. Springs keep the brake on, a rod compresses the springs when you hit the pedal.
    Unless you really want another air hose laying across the floor.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Jethro,
    Do you have a link to the plans? I don't mind searching, but if you've already found this, it seems that it's just extra work to start over.
    Thanx,
    Bruce
  11. porsche930dude
    porsche930dude
    Today i made two tools. A digger for metal detecting and some sharp angle pliers. I think theyre usually called fender pliers.
  12. Jethro
    Jethro
    Wooster likes this.
  13. PKap
    PKap
    from Alberta
    You can mount a disk e-brake from a small car with a mechanical calliper. Use a spring so it holds the calliper engaged, and a small air cylinder to release it when air is applied. You can drill some holes in the rotor to engage a safety pin if you like ( I would) but those e brakes are designed to stop a few thousand pounds from speed, and will hold a properly mounted car on a rotisserie.
  14. Ulu
    Ulu
    from CenCal
    One of the simplest things is to do a strap brake or contracting band brake. Almost no precision would be required for this application. It can be steel to steel. You need a solid spring to pull the strap tight over a drum. A simple pedal relieves the spring so the brake will turn.
    You need to develop some force but wear resistance won't be a factor.
  15. Ulu
    Ulu
    from CenCal
    Oh yeah, the fender pliers rock! I need some. :cool:
  16. 64 DODGE 440
    64 DODGE 440
    from so cal
    You could always use an early Mopar parking brake like they mounted to the rear of the transmission. Nice simple small mechanical linkage external band.
  17. Ulu
    Ulu
    from CenCal
    Right sort but perhaps too small.
    I think they're only about 8" or maybe 9 for the limo.
  18. eagleeye8789
    eagleeye8789
    Use a worm gear. You don't have to worry about brakes. Match that with an electric motor and it will spin slower or faster based on the gear size or hand crank for good accuracy. Pull a steering gear out of a truck for the worm gear and find a helical cut gear to match. Maybe out of an old transmission or a timing gear.
  19. porsche930dude
    porsche930dude
    I finished up my lil scalper . Im over the moon with it. came out freakin beautiful
  20. DDDenny
    Wow
    That's cooler than the other side of the pillow in July.
    loudbang and ct1932ford like this.
  21. pat59
    pat59
    Love the 'Lil Scalper! :)
  22. slack
    slack
    Suh-weet! That's a museum piece. Good job man.
  23. xpletiv
    xpletiv
    from chiburbs
    ...well, damn, didn't that come out just perfect! I'd hate to use it and get it dirty.
  24. loudbang
    Is that a Native American with the shotgun on the front?
  25. porsche930dude
    porsche930dude
    Thanks guys it really came out great. Yes it is just a painted plastic guy. I have a metal one with a bow and arrow but its too big so i went with the smaller one.
  26. woodbutcher
    woodbutcher
    :D Very nice sir. What kind of 1/4 times do you get?1/4 of the yard that is:p:rolleyes:?
    Good luck.Have fun.Be safe.
    Leo
  27. Ulu
    Ulu
    from CenCal
    Except for the ornament, I love it 100%.
    What would make it perfect?
    Ditch the silver guy.
    Miniature replica Pontiac hood ornaments or Indian motorcycle fender ornaments, with the light up amber Indian head. One on each front fender.
    But really man that is so nice it almost makes me want to start mowing my lawn again!
    64 DODGE 440 likes this.
  28. whtbaron
    whtbaron
    from manitoba
    Sweet mower... matches the bike nice too! I had some leftover dark blue metallic (79 Ford color) from a project once... kids got tired of me painting everything dark blue metallic for about 2 yrs after...
  29. Ulu
    Ulu
    from CenCal
    Well these were home made but not by me. I picked them up for free from a buddy whose family farm was just sold off.
    They're both a lot bigger than the ones I owned, and the stands are crude but heavy duty.
    The price was sure right: free. Can't beat free.:D 20160306_130358-1.jpg
    Wow a Baldor! That's like the world best grinder.
    No name on the vice so maybe it's imported from Mexico. It appears to be cast steel, but I can't identify it.
    Other than the number 150 on the side there's no markings
    ratrod72, whtbaron and slack like this.
  30. Ulu
    Ulu
    from CenCal
    The new vice dwarfs Dad's old craftsman vice.
