Hot Rods 32-33-34 pickup what year is it?
Discussion in 'The Hokey Ass Message Board' started by Shinerunner82, Feb 13, 2016.
  1. Shinerunner82
    Shinerunner82
    from Alabama
    Truck was at my mothers restaurant tonight , possibly for sale And im not sure if the year. ImageUploadedByH.A.M.B.1455425034.242482.jpg ImageUploadedByH.A.M.B.1455425048.014238.jpg ImageUploadedByH.A.M.B.1455425063.088908.jpg ImageUploadedByH.A.M.B.1455425079.980789.jpg ImageUploadedByH.A.M.B.1455425102.042128.jpg
  2. jimcolwell
    jimcolwell
    from Amarillo
  3. There are a couple of things you can check to confirm if Jim is right. The '32 will have a center K member and not an X member. The '32 will have a reveal at the bottom of the frame over the running board (I don't think I can see one but the picture is not clear.) The radiator of the '32 will be vertical while the '33-'34 will slope back. The '32 firewall is removable while the '33-'34 is spot welded to the body. The '33-'34 will have a slight raised area on the front fenders to clear the rivets on the frame. Count the louvers in the hood side panels, ***uming it is a '32, 25 louvers means the hood (if in good condition) is worth about $2K.
    Charlie Stephens
    verde742 likes this.
  4. WiredSpider
    WiredSpider
    Its a 34.It has the wide bead on the back of the cab.32 and 33 only have the 2 lower beads
    Ckke2000, 3wLarry, Dave Mc and 2 others like this.
  5. 2deuces64
    2deuces64
    Bingo we have a winner
    da34guy likes this.
  6. Shinerunner82
    Shinerunner82
    from Alabama
    It's got fibergl*** running boards and fenders , a small ford rear end and dropped axle, you can see the pinstripe on the head light , an old rod that's been hiding for years , really a rare bird round these parts , he told me 6,500 and gave me his number
  7. With that much fibergl*** and my guess about the quality of the mechanical work I think I would p*** at that price. Of course I am coming from a different place with different interests. What is the final vehicle you want to end up with? Add up all of the money you will need to put into it and you will probably find it is cheaper to find one finished or at least in better shape.
    Charlie Stephens
    verde742 and Bill Nabors like this.
  8. Hot Rods Ta Hell
    Hot Rods Ta Hell
    It's definitely a 34 cab but not a 34 hood as they have a dip in the louvers for emblem. Either a 32 or 33. 32 side panel length; 32- 11/16", 33/34- 33 5/16"
    $6500 isn't bad if it's ***led (is that an issue in Alabama?)and isn't full of bondo. $5000 would be a great deal if the body and ch***is are solid.
    • It's on a trailer. Did he just buy it/on his way home (having dinner) and you're the first potential buyer to flip it to?
    • Someone recently shot a quick coat of primer on the cab (didn't mask the rear window). That's a major red flag in my book when looking at a car for sale because I instantly wonder what they're hiding. Look for 80 grit sanding scratches in bondo under the primer and use a magnet, and look at the inner side of the panels.
    • Any engine or trans? Tailgate? How's the cab floors, bed sides?
    Prone to rust in the lower cowl, door and cab corners. Check it good.
    Remember, the ch***is for 32/33/34 trucks are essentially the same as their automobile counterparts and valuable by themselves especially when ***led.
    Parts for these trucks are not cheap.
    Cab with doors would go for about $2500-$4000.
    Solid pr. of doors $1000-$1500.
    I envision it built back as an early Rod with juice brakes, Flatty or early O/H V-8, etc.
  9. Shinerunner82
    Shinerunner82
    from Alabama
  10. Shinerunner82
    Shinerunner82
    from Alabama
    He just bought it, it was 20 minutes from where I live I guess I missed it . I'm gonna call him and go take a look. No engine no trans , flathead parts and upholstery in the back the floors and doors were solid. Somebody would jump on it around here for that price. You can't find ford stuff like that around here.
  11. Kevinsrodshop
    Kevinsrodshop
    All comes down to supply and demand. If you've always wanted one, have a quick look at it, but buy it because it might be gone tomorrow. Solid doors are a huge bonus.
  12. I am not sure that it isn't a '34 hood. The dip in the louvers was for the V8 emblem and many of the trucks were 4 cylinder with no emblem or dip.
    Charlie Stephens
  13. Hotrodmyk
    Hotrodmyk
    Going to venture a guess but I think it is largely a '34. '34 cab for sure, looks like '34 4 cyl hood and probably an ***ortment of other parts to complete the truck. I would like to see more of a side view of the radiator shell though.
  14. dumprat
    dumprat
    from b.c.
    34 has the holes in the grill shell for the stainless trim. It has the holes.
    Hotrodmyk likes this.
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Great call Charlie. Didn't even think about the 4 cyl.
  16. fleetside66
    fleetside66
    It's hard to tell, but it looks solid. Hopefully, the stainless grill surround will be with the miscellaneous parts, as that is as tough to find as the doors.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
  18. verde742
    verde742
    looks like bunch of part shoved together,, rear left fender looks to be a Model A, maybe even old Chevy, looks weird, and other little hints look su****ious to me, Cab is a 34, but other things ??
    32 frames are SO different from 33/34 . on truck frames, running boards bolt on BOTTOM of frame, cars bolt to the face of frame.
    Buyer be-aware: These trucks are So expensive to build and so uncomfortable to fit in when they are done. i.e. vertical 2 inch thick back of seat.
  19. Petejoe
    Petejoe
    from Zoar, Ohio
    Quote. Buyer be-aware: These trucks are So expensive to build and so uncomfortable to fit in when they are done. Quote
    Chopped yes but an unchopped 33-34 with their added 6" of firewall clearance, they are very comfortable to drive with an adjusted column location. By the way my jumper seat is close to 4" but moved it clear to the back panel. It still has an angle to it.
  20. dumprat
    dumprat
    from b.c.
    Mine is pretty comfy? Stop lights are gonna be a bit hard to see but oh well...
  21. k32t
    k32t
    from Hog town
    it's a 33/ 34 box
  22. HOTRODPRIMER
    HOTRODPRIMER
    The cab is a 1934 Ford as is the radiator cap,the running boards . 33/34HRP
  23. Hotrodmyk
    Hotrodmyk
    Here's how I fixed the stop light issue.
    dumprat likes this.
  24. I agree with others, it's a '34 with the 4 cylinder hood. '34 was the last year for a 4 banger until '41 and '42 when the 9N tractor engine was an option. Fair number of Ford pickups were built with 4 cylinder engines in '33-'34.
  25. Shinerunner82
    Shinerunner82
    from Alabama
    I have his number if anyone is interested, I hate to but I'm gonna p***. I'm getting close to finishing my a sedan but I still have some parts to find and pay for , 10 year build I gotta finish.
