Project: 29 model a (i dont have a name yet) started
Discussion in 'The Hokey Ass Message Board' started by chevy12, Apr 25, 2011.
  1. chevy12
    chevy12
    Thanks! should be taking shape now. get it back from the blaster next sat. then on to the body work.
  2. chevy12
    chevy12
    body sand blasted and now in epoxy
    time to start getting dusty!
    kiwijeff likes this.
  3. chevy12
    chevy12
    made some bracing for the visor to make sure it doesnt flop in the wind
    tacked the drip rails on from the inside, then filled all the holes with panel bond
  4. chevy12
    chevy12
    front axle powder coated and king pins installed
  5. chevy12
    chevy12
    doing final ***embly. body is in spray poly now all body work done!
    kiwijeff and Jet96 like this.
  6. chevy12
    chevy12
    dash in, now what to do for gauges....
  7. chevy12
    chevy12
    Got this little 12v electric defrost unit. going to install under the dash
  8. chevy12
    chevy12
    piped it into my dash support
    and out the top
  9. chevy12
    chevy12
    carved a louver into a piece of wood
    hammered into the dash
  10. chevy12
    chevy12
    had to make a cut in the window frame
    my new vents
    tb33anda3rd, kiwijeff and Jet96 like this.
  11. verde742
    verde742
    I am seeking inside rear side upper window frames, are you going to use yours, or can I purchase them from you? Anybody? 28-29 ford tudor?
  12. chevy12
    chevy12
    I am using them, i might have an extra set. Im using the best ones that i have
  13. chevy12
    chevy12
    starting to make the roof insert
    sanded it to the contour i want, i hope
    kiwijeff and Donut Dave like this.
  14. chevy12
    chevy12
    wiring started
  15. chevy12
    chevy12
    gauges all wired up
    cl***ic instruments looking good
    kiwijeff and low budget like this.
  16. bengeltiger
    bengeltiger
  17. Donut Dave
    Donut Dave
    I like using the installation board, a great way to get create a visible form without spending a fortune. A shape can be made, cut, sanded, glued, modified to get the desired result. Several thickness are available at Home Depot. The draw back is the mess it creates!
  18. low budget
    low budget
    from Central Ky
    Like those gauges!
  19. chevy12
    chevy12
    yeah makes a big mess!
  20. chevy12
    chevy12
    yeah i loved the gauges when i saw them. cl***ic instruments does a nice job. a little spendy but i think they will look great in the car!
  21. chevy12
    chevy12
    got a good start on the roof.
    1/8 baltic birch with relief cuts ready for glue
    on the form.
    in the bag
    in the vacuum. repeat 4 times
  22. chevy12
    chevy12
    got the motor back
  23. chevy12
    chevy12
    set in place
    drive shaft made and in
  24. chevy12
    chevy12
    radiator mounted
    headlights mounted
    low budget and kiwijeff like this.
  25. chevy12
    chevy12
    floors and tunnel installed
    low budget likes this.
  26. chevy12
    chevy12
    made a steering column cone
    getting good at gas welding
  27. Nice work, this is looking sharp.
  28. 39 Aaron NZ
    39 Aaron NZ
    I know I'm 2 years to late, but what an awesome chop!
    Every thing about this car is cool. I really like the ch***is and the demister setup.
    It will be a great driver with nice suspension and the 5 spd. Keep up the good work.
    Cheers Aaron.
    Sent from my SM-G360G using The H.A.M.B. mobile app
  29. chevy12
    chevy12
    Here is the new grill insert, i didnt like the other one
    1/4 stainless
    filled with wax
    flattened on a press brake almost all the way
    stainless bent at 90* then punched at .5 with a die and mounted on a stud to the grill
  30. chevy12
    chevy12
    here they are all 35 tubes set in place
    Now do i polish them or have chromed? still have to tack them all in place
    brEad and dvs like this.
