Projects Martin Ford '32 Roadster build.
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Feb 19, 2016.
  1. Like Larry says "I'm in" too......
    volvobrynk and tmfcracing like this.
  2. El Hueso
    El Hueso
    In relation to the rear suspension, are you planning on running a panhard bar? What are you planning on running for a rear spring? Beautiful work as always!!!
    tmfcracing likes this.
  3. tmfcracing
    tmfcracing
    from Sweden
    Thanks you guy's, its so much appreciated!!!!
    @El Hueso . Yes the plan is to make a panard somehow as it won't be a K-link setup. Might be a vintage looking watt-link in the rear. The springs for the rear are also going to be torsion bars.
    As I said in the first post I'll start from the very beginning so here we go :)
    Rails neads a cleanup . Frame jig in the background .
  4. tmfcracing
    tmfcracing
    from Sweden
    Drilled and done .
    Stogy and volvobrynk like this.
  5. tmfcracing
    tmfcracing
    from Sweden
    Made the sides for theX-member and the step-boxing plates .
    Stogy and saltflats like this.
  6. tmfcracing
    tmfcracing
    from Sweden
  7. HuskyV8
    HuskyV8
    Looks like it's going to be a nice one.
  8. brady1929
    brady1929
    You make it look so easy Martin, even though it's not.
  9. weldtoride
    weldtoride
    Subscribed, and thanks for taking the time off from your project to share.
  10. hasty
    hasty
    So are you teasing us or are you going to post some more of your progress?!
    Looking forward to updates (and a view of the front suspension).
  11. Buz
    Buz
    I loved following the build on your coupe. This will surely be a watched thread.
  12. Rand Man
    Rand Man
    Man, I'm digging on some mad fab skills here. Keep it coming.
  13. scotti32
    scotti32
    Beautiful work.
  14. gnichols
    gnichols
    from Tampa, FL
    Beautiful build. That's it for the pix?!??! Can we see more of the front cross member, please? And.. what the heck is a Wedgecaster? Sounds fishy to me. Gary
  15. waxhead
    waxhead
    from West Oz
    Love your coupe. Subscribed to this build.
  16. tmfcracing
    tmfcracing
    from Sweden
    Sorry guys, been a lot lately.
    After the boxplates where made I weld them on to the rails in the jig and then remove it just to grind them on the bench.
    Still needs some straightening on the isade edges.
    loudbang, saltflats and Stogy like this.
  17. tmfcracing
    tmfcracing
    from Sweden
    Frontmember . . From drawing to reality. The holes far out on the sides is where the torsion bar tubes will be.
    Testing between the rails .
  18. clem
    clem
    From post 1 - "Bare with me but this project is not a true traditional build with every single part made before 1955 or so, somehow it will stay sort of in a traditional look and most important the plan is that it turns out the way I want it . Hopefully some of you finds it interesting and inspiring =)"
    Martin,
    any thing you build we are happy to follow along. Your work is a****st the best I've ever seen.
    Traditional or not, I knew it would be 'interesting and inspiring ' just from following your thread on your coupe.
    I scrolled down to the first pic on your first post and I am already impressed !
    Thanks for posting!
    Stogy, tmfcracing and loudbang like this.
  19. dirt t
    dirt t
    subscribe
  20. DDDenny
    I'm with Clem
    This build is one of a couple here that represents using their best skills as well as quality materials. Not something you can always say about our historically "traditional" cars.
    Nor can it be said of some of the other current builds going on.
    Do I absolutely love them; yes, most of them, but this build is of a totally different "ilk".
    For the life of me I can't fathom someone thinking this build is not HAMB worthy.
    Bravo
    Stogy and tmfcracing like this.
  21. dirt t
    dirt t
    To quote the boss "WOW".
  22. gnichols
    gnichols
    from Tampa, FL
    Loving the front X member. Can't wait to see how your front end goes together. Thanx, Gary
  23. tmfcracing
    tmfcracing
    from Sweden
    @clem , @DDDenny , thank you for your extremely kind words. Thanks !!! and of course a big thanks to all you guys cheering me and my little project !
    @gnichols Front member is on its way =) , I'm not completely done with the hole frontend but hopefully it ain't that far away . I know it´s a fishy name, isn't it great ;)
    Here is my granddad´s old mini break, he had a metal shop around 1950 to 1971 . He gave it to me in the 90th´s after I found it in his ba*****t. I use it extremely much when working on ch***is. Everyone should have one.
    Torsion bars and backplate of front member
    tb33anda3rd, Stogy, loudbang and 2 others like this.
  24. tmfcracing
    tmfcracing
    from Sweden
    Rear member , when I started with it I had a Currie 9" , later I has to change the midsection on it to clear the new V8 Quick Change.
    Stogy, volvobrynk, loudbang and 2 others like this.
  25. tmfcracing
    tmfcracing
    from Sweden
  26. alfin32
    alfin32
    from Essex, Ma.
    Popcorn ordered!
  27. saltflats
    saltflats
    from Missouri
    Man your work is top shelf.
    Sure would like to see some more detail pictures of the metal brake.
  28. tmfcracing
    tmfcracing
    from Sweden
    They are possible to buy new , google "Flat Bar Bender" . There is a lot of manufactures .
  29. BenLeBlanc
    BenLeBlanc
    Crazy good build! Hopefully I'll pick up some ideas along with your tips and tricks. (Maybe even some SKILL?) Very inspiring.
    loudbang and tmfcracing like this.
  30. El Hueso
    El Hueso
    What process do you use to grind your welds? In particular, where you welded in the boxing plates on the frame. You can't hardly tell that it was welded.
