Projects Oh no not another Willys Gasser build, this time a Willys shop truck
Discussion in 'The Hokey Ass Message Board' started by langy, Dec 8, 2013.
  1. captainjunk#2
    captainjunk#2
    ive never pressed the like ****on either I never even notice it lol
  2. brg404
    brg404
    As a full-time lurker, I have to admit to posting 3 times on this thread. Heres why:
    Steve does the complete job, not taking short cuts, applying design skill, not just mechanical skill to problems. Its a learning experience to see how a pro takes a project to completion. Its really easy to tear something apart, its really difficult to build something from scratch. This is a thread lots of folks use for inspiration, thats why I follow it, and hope to see more...
  3. Kiwi Tinbender
    Kiwi Tinbender
    Yep, what he said, And I`m supposed to be a `Pro`as well....whatever that means...
    Steve, we are following, mate, and hope you will do us the great favour of updating here....
  4. I rarely reply to anything, But Steve's threads are truly inspirational.
    langy and loudbang like this.
  5. langy
    langy
    You nailed the very reason I put it here bud, if my thread inspires just one person to take on a project it makes it all worth it !!!
    I'm just a enthusiast like most people on here, I love to see interesting build threads here also, I don't diffentiate between steel or fibregl*** as in my opinion both have s lot to offer, we can never have too many build/tech threads.
  6. DDDenny
    Steve
    I've been "Jones' n" for some hand whittled alloy goodness from North of London.
    Any progress on the shifter for the hydro?
    How's that Odyssey blower drive coming along?
  7. langy
    langy
    Huh ???
  8. DDDenny
    Maybe I missed it, I recall you saying something about making a shift handle, back when I commented about your choice of shifter and I submitted the photo of that B&M hydro shifter.
    Sorry bout that, I had major neck surgery three days ago and the meds apparently have got me a litle "rummy", completely spaced that you already did the blower drive.
    I went back and looked and enjoyed those old photos again.
    Glad your back.
  9. jays41willys
    jays41willys
    from nj
  10. jays41willys
    jays41willys
    from nj
    you do great work steve
    langy likes this.
  11. langy
    langy
    I thought I had missed something !!! Hope the drugs wear of soon bud
  12. langy
    langy
    Thank you Jay, I know it's not to everyone's taste but I try and be a little different.
  13. Degenerate
    Degenerate
    from Indiana
    I'm a lurker mostly and don't feel I should waste space with a compliment unless I have a follow up question. Forgot there is a like ****on and don't think about using it. I enjoy Langy's work and I swear he doesn't know any other metal exists other than stainless steel. Hope you keep posting langy.
    langy likes this.
  14. Jedidiah
    Jedidiah
    from Ft Worth
    I don't post much either but have been following this thread since the beginning. There is a lot to learn here. This is one of the threads that makes me want to go out in the garage and work on my own projects. I do appreciate your posts Langy.
  15. Whoa - went to look back at some cool stuff Steve has made for his Willys and the pics are mostly gone!
    Steve
  16. langy
    langy
    Not sure what's going on Steve but all the pics are there for me ???
  17. Must be time for some more Inspiration?
  18. Looks like it may have been my POS laptop...
  19. langy
    langy
    This may help others hanging doors Willys, the original Willys hinges are £400 a set so quite spendy, an alternative I found is the Speedway budget hinges which are available in steel or polished stainless but are slightly lighter duty, built my coupe and the truck with these hinges but I noticed the hinges flex which allows the door to drop ever so slightly which is slightly annoying !!! Anyway I found a solution [​IMG]
    My fix was to double up the thickness which is not a problem as the original willys hinge is thicker anyway.
    The hinges tend to flex by the hinge point shown in the pic below
    Next I cut a piece of 3/16 stainless flat plate and tig welded it to the existing hinge flap., a bit of blending and fettling and it was done.
    I only strengthened the flap that fits to the door as the body side has inherent strength due to the shape, bolted them back on and got zero flex
    olscrounger, loudbang and Drewfus like this.
  20. langy
    langy
    Well a bit of an update, been poncing about with the **** that loosely resembles the doors !!! these are probably the worst mouldings i've ever come across, there is no way they would ever have fitted the cab, they resemble willys but are so far out of shape its soul destroying, anyway after a few weeks of adding bits here there and everywhere and moving sections of the door around they finally fit pretty well, you can see where parts have been added. The gaps are set roughly and require final sanding but are basically there.
    Heres a short video of the doors working
    [video=youtube;HxVYdIcPX3c][/video]
    loudbang and greaser like this.
  21. rottenleonard
    rottenleonard
    Nice solution on the hinges. With as close together as they are you could see how a little flex would be a big issue.
  22. wrenchbender
    wrenchbender
    Thanks langy I've been pondering this for awhile on my Willys but really hadn't come across a solution but thank you for sharing your findings
  23. langy
    langy
    Exactly bud, with hinges that close together its never gonna work very well
  24. The 39 guy
    The 39 guy
    Finally the Langy drought is broken! Good to hear from you again Steve. Another well thought out and executed fix ( the hinge) and your usual fibergl*** magic. Thanks for sharing with us again.
    loudbang, FlyFisher and greaser like this.
  25. loudbang
    Magical as usual with all your work.
  26. Inspirational as always.
  27. DDDenny
    Good to hear from you Steve.
    Nice job on the doors.
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Steve, Just want to compliment you on the colour choice(s):)
    Glad you're back.
  29. LKR
    LKR
    from Australia
    Really dig this build. Keep up the good work mate
  30. langy
    langy
    Yeah it certainly looks like a patchwork quilt at the moment but you have to look beyond that, soon no longer an ugly duckling !!!
