Technical ford 11'' brake drums
Discussion in 'The Hokey Ass Message Board' started by nz hotrod, Feb 6, 2016.
  1. nz hotrod
    nz hotrod
    Hey guys looking to identify ford 11'' 5 by 4.5''pitch brake drum???? Will measure off set if needed. Does any body know what year/model these would be from.?? There will be somebody out there who would be able to tell me straight away
  2. Montana1
    Montana1
  3. Tim
    Tim
    from KCMO
    A photo would help but even so there's variation. They used the same drums on all sorts of different trucks and cars and aftermarket replacement measure the same but may not have the same look.
    Example, the stock drum might have ribs or grooves and the replacement is smooth.
    What's the situation your dealing with that might make us more useful.
  4. Some '70s wagons had 11" brakes they were 5 on 4.5. the trucks were 5 on 5 I think, but the Broncos came in 5 on 4.5 in the later years and some of them had 11" brakes.
    If they are rears they would only be from a big bearing 9" rear. Those should all have the same stand off on the axle so the backing plates should all be the same.
  5. thorpe31
    thorpe31
    from nor-cal
    11" 50s ford full size
    11 1/32" 60s ford full size and rears thru 70s
  6. nz hotrod
    nz hotrod
    First of all thank you all for helping!!! much appreciated. Here a couple of photos
  7. nz hotrod
    nz hotrod
    The brake liner faces measure about 2. 1/8 so I'm thinking its to suit 2" brake liners. Centre spigot hole measures 2. 7/16.
  8. nz hotrod
    nz hotrod
    They have been drill out to chev PCD but are 5 by 4.5" originally.
  9. captaintaytay
    captaintaytay
    The hat being higher on the drum and the center hole diameter are throwing me off..
    I was thinking early Bronco as the width of drum could also take a 1 .3/4" shoe.
  10. Tim
    Tim
    from KCMO
    Early bronco is 5x5.5 they kinda look like f-1 front hubs but the pattern would still be 5x5.5
  11. captaintaytay
    captaintaytay
    oops!:oops:
  12. seb fontana
    seb fontana
    from ct
    Yes the offset of the drum is strange...The 62 station wagon and 67 Galaxy [police cruiser w/disc front] both have the 11-1/32 drums with 2" plus [2-1/4 per Napa] wide shoes..Some cars used that same drum/brakes on the front also before disc brakes with a wider shoe [2-1/2 per Napa] I think..The set of after market 11" brakes I have are flat face and the shoe area is just about 3" wide..Makes me question as to why the shoes are only a hair over 2" wide, can't remember where I bought them from..Edit: Summit..
  13. RICH B
    RICH B
  14. seb fontana
    seb fontana
    from ct
    ""I have a '59 car 9" small bearing rear with 11"x1-3/4" brakes""
    Rich B..Yes you are right..I put same 9" in my Comet [72] but the small bearing was an odd ball, maybe HD for Station Wagon..If I remember right the drums are still pretty much flat with the narrow shoes accommodated by less backing plate off-set..
  15. @RICH B I was talking late model and I have yet to see them on a small bearing rear. The shoes are wider then yours like about 2" as I recall.
    Looks like @seb fontana has some for a small bearing late model rear.
  16. seb fontana
    seb fontana
    from ct
    ""Looks like @seb fontana has some for a small bearing late model rear.""
    No, I think I got shafted by summit..Edit: While the actual shoe width is pretty close to 2-1/4" it would have been nice if the lining width was close in stead of being 2-1/16"...
  17. bobss396
    bobss396
    The pictured drum is a Kelsey Hayes if that helps. Usually the lining is 1/2" narrower that the measured contact surface of the drum.
