Features Dropped Axles and Aesthetics...
Discussion in 'Traditional Hot Rods' started by NealinCA, Sep 30, 2007.
  1. gwhite
    gwhite
    SUPER MODERATOR
    They are extraordinarily crude...pretty cool to see the scars of Ed's 100-ton power hammer!
    117harv likes this.
  2. RainierHooker
    RainierHooker
    from Tacoma, WA
    Simple simplicity in cobbling together a few different years of stock Ford parts with a dropped A axle to get a factory-looking drop...
    bct, LOU WELLS, Jet96 and 2 others like this.
  3. Manager
    Manager
    Mine is s back on the road 003.jpg imilar, a little more drop and a bit of cut and weld.
    bct and Jet96 like this.
  4. Schwanke Engines
    Schwanke Engines
    Only stock dropped axles that look good, are 32 heavy. IMO . I prefer aftermarket axles.
  5. I'll be happy to dispose of any ugly stock or dropped axles you decide to get rid of. I'll even pay shipping.
  6. falcongeorge
    falcongeorge
    from BC
    I am willing to be the West coast franchise for this deal...;)
  7. You have said a mouthful here my friend. I don't think that anyone on this thread including myself has said more with so few words. :cool:
    Rough and tumble. In my mind every hot rod should have that street brawler look to it, smooth but a little rough around the edges. The axle that you use depends on the build, but a little on the rough side has always said, "raisin Hell and putting a brick under it" to me. Tough and ready to s****. ;)
  8. NealinCA
    NealinCA
    This old axle in under a 32 pickup I just brought home...
      219.2 KB
  9. falcongeorge
    falcongeorge
    from BC
    ^^gotta like the Olds bumpers as well, thats an interesting looking truck. Is there somewhere we can see more?
    gwhite likes this.
  10. verde742
    verde742
    PLEASE, Show me your dropped spindle with an I-beam axle..?
  11. gwhite
    gwhite
    SUPER MODERATOR
    Looks like a Mor-Drop to my eye....very cool!
  12. dumprat
    dumprat
    from b.c.
    Each to their own but I am of the opinion that the 32 heavy axle is UGLY in any form dropped or not. A dropped standard axle has the look of a swan. The heavy has the look of a plow horse.
    1oldtimer and falcongeorge like this.
  13. falcongeorge
    falcongeorge
    from BC
    I really like dropped '33/'34 axles...
    Jet96, Squablow and Just Gary like this.
  14. verde742
    verde742
    The shape of a dropped axle "MAKES ME SMILE"
    I don't know why, It Just does.. I see a dropped axle, even hanging on a wall, And I smile.
    Mustang II, not sooo much !!
    Just Gary likes this.
  15. RainierHooker and falcongeorge like this.
  16. rusty valley
    rusty valley
    maybe off topic, but same end of the car, i have a lovely 34 axle dropped by okie joe and i just cant see using that ugly 34 spring. model a's, look better, and the nice tapered leafs of a 35 better yet but they are 1/4" wider. anyone ever grind an 1/8 off each side and go that route?
  17. gwhite
    gwhite
    SUPER MODERATOR
    Use a 34 main spring and the remaining leaf pack from a Model A.
    Or if you're lucky, find a nice original 32-early 34 spring pack; these were tapered leafs similar to the A, although more in number. A springs were 10 leaf, 32's (and likely 33 & 34) were 12 leaf.
  18. 117harv
    117harv
    Hey, this is an axle thread... :)
    3wLarry and gwhite like this.
  19. rusty valley
    rusty valley
    ha ! yes, but its an "aesthetics" thread ! yes, GWHITE, i have A springs here in my pile too. i once ground all the ends of an A spring to try to simulate the 35 taper, and let me tell you that was a lot of work, and did not look like ford made it. i think just taking an 1/8 " off the side would be less grinding, and better results. i did not know the early 32 was a taper leaf, like 35, and early model T ?
  20. gwhite
    gwhite
    SUPER MODERATOR
    Ahhh...my mistake, I meant 'clipped corner' or 3-sided taper. The 32-early 34 spring had the clipped ends just like an A; the late 34's and all service replacements thereafter had square cut ends.
    Here's an example of the 3-sided taper springs (A-early 34). I reckon you could do a little grinding on these if you wanted a true rounded taper.
  21. Mark T
    Mark T
    The only problem with making a straight cut leaf rounded or three sided on a used spring pack is the leaf below will always show the scars of the leafs former shape.
  22. tfeverfred
    tfeverfred
    One of my favorite threads.
    3wLarry likes this.
  23. Detonator
    Detonator
    from santa cruz
    I'm surprised that lower shock mounts haven't made it into this discussion. I'd take a welded-on stud or bung over those lazy brackets that bolt onto the bottom of the perches any day.
  24. rust
    rust
    Thats funny..... I have been thinking about lower front shock mounts all day. I agree
  25. gwhite
    gwhite
    SUPER MODERATOR
    Not if you're using new/NOS/NORS parts :D
    porknbeaner and 3wLarry like this.
  26. gwhite
    gwhite
    SUPER MODERATOR
    Take a gander at 39-50-ish MoPar front shock studs - these bolt through the upper control arm on those applications and are plenty long enough for you to drill and mount thru your axle or cut & weld onto it...I've got a pair I'll be shortening and arc welding to the perch bosses of my Dago axle.
    town sedan, Tim_with_a_T and 3wLarry like this.
  27. rusty valley
    rusty valley
    no new parts here, just rusty old junk !!
  28. 3wLarry
    3wLarry
    from Owasso, Ok
    more pics of the pickup please!
    kidcampbell71 likes this.
  29. falcongeorge
    falcongeorge
    from BC
    Ditto! Cmon Gwhite, you know you want in on this too!
    3wLarry likes this.
  30. 3wLarry
    3wLarry
    from Owasso, Ok
    me too
