Projects 1950 DeSoto
Discussion in 'Traditional Customs' started by bsilvey, Feb 26, 2016.
  1. bsilvey
    bsilvey
    Hello, new to this age of the car scene as all I have ever had before was 1970 and up. Ran across this 50 DeSoto and I couldn't p*** it up. Plans to lower without bags, flat midnight blue with a white top. I will have many questions as I go, I am sure of that. Interior is all there, except what the mice chewed on while it was sitting in a barn for 47 yrs.
  2. slv63
    slv63
    Sounds good but we need pics!
  3. 1952B3b23
    1952B3b23
    from Western MA
    I agree we need some pics. Sounds like a cool car!
  4. bsilvey
    bsilvey
  5. gatz
    gatz
    ...and, maybe a little off the top ?
    (solid color)
  6. bsilvey
    bsilvey
    Top may be in the plans, but not right away. The inline 6 is locked up. Current plan is to drop a 360/904 that I have sitting in garage. Does anyone make motor mounts for this swap? And has anyone done this, I do not want to hack on the inner fenders.
  7. 73RR
    73RR
  8. oldwood
    oldwood
    from arkansas
    It has the Correct Gas Pedal!!! Congrats
  9. choptop40
    choptop40
  10. Nice start! Bruce.
    1949dodge likes this.
  11. choptop40
    choptop40
    Check out my profile pics..did this 49 dodge , I know a lot about these models , I've owned at least 10 by now...be happy to answer any questions ......
  12. vintage6t
    vintage6t
    from CT
    I'm about 1/2 way through putting a 383/727 into a 50 Desoto Convertible. My goal was to keep the original front suspension and steering. Looking at the pictures of the dodge in the link above, I think there are differences in that the Desoto is a center steer, so I think the steering box is closer to the firewall than what I see in the Dodge pictures and there is a steering rod that runs from the steering box side arm to the center steer arm at the front cross member. In order to clear the steering rod , I had to set the 383 up high and a few inches offset to the right (p***enger side). This also meant that I had to cut the firewall for valve cover clearance and trans tunnel to clear the ****** bell. You may find the 360 will fit better but I found cutting the firewall to be a good compromise to get the placement I wanted and to keep the steering intact. I don't think you're going to find off the shelf motor mounts and also I think you'll find regardless of engine/****** combo you'll have to remove the stock ****** cross member, which is riveted into the frame. I fabricated my own engine and ****** mounts after many hours of fooling around with engine placement. Another issues with the 383 was the front mount oil filter, I'm going to have to use a remote filter and adapter. Also if you're planning to keep the stock steering you'll find a center dump exhaust manifold will fit better than a rear dump, that is another difference that I see as compared to the dodge.
  13. Atwater Mike
    Atwater Mike
    Ch***is Engineering has mounts for that engine. Most of the Mopar engines take the 'channel' shaped mount on both sides, attach to the factory cast 'ears' front sides of the block.
  14. George
    George
    lots of Threads on 46-54 Mopars, info tends to interchange.
    loginrc likes this.
  15. BuiltFerComfort
    BuiltFerComfort
    Problem tends to be the driver's exhaust manifold hits the steering box. Most of the rest is straightforward if not always easy.
    The 273 Valient had an up-and-over manifold to clear the steering box. Find one or make some headers.
  16. AlkyWagon
    AlkyWagon
    I'd lay the rear of the top down to make it flow with the car, better. There's only so much I can do with the Paint program, lol. Good Luck!
  17. themoose
    themoose
    Here's a little inspiration...
  18. bsilvey
    bsilvey
    Thanks themoose and alkywagon those are awesome.
  19. bsilvey
    bsilvey
  20. bsilvey
    bsilvey
    ImageUploadedByH.A.M.B.1464125945.135640.jpg ImageUploadedByH.A.M.B.1464125957.140369.jpg
    Got the 360 mounted and in. No major issues yet. I will now put the dog house back one for a quick moment to see if that has any issues. If not I will pull the motor out and freshen up before putting it back in.
    kiwijeff, czuch and Squablow like this.
  21. steinauge
    steinauge
    from 1960
    Might want to put the exh manifolds on and have a look before you pull the engine back out.
    czuch likes this.
  22. joshmodelskidoo
    joshmodelskidoo
    Marvel mystery oil in the cylinders freed mine up
    czuch likes this.
  23. bsilvey
    bsilvey
    For sure I will put manifolds back on.
  25. Good raw material you got there. always been a fan of those. Love their unique roof line.
    loginrc likes this.
  26. bsilvey
    bsilvey
    Now with the engine at least temp installed, time to lower back 2". Next question is lowering the front. I have seen the option of Ford Aerostar springs, has anyone done this? Or what other economical options have you all done?
  27. 73RR
    73RR
    One easy way to drop the front is to remove the lower spring plate and bolt it to the underside of the A-arm.
  28. bsilvey
    bsilvey
    How do I remove the stainless trim beneath the windows? I do not see any nuts on the inside.
  29. soto
    soto
    from chicago
    By any chance you still have the ujoints for the fluid drive trans ?
    Looking for one
  30. bsilvey
    bsilvey
    Soto.....yes I should. Let me look.
