History What is this car?
Discussion in 'The Hokey Ass Message Board' started by Dutchwonder, Feb 27, 2016.
  1. Dutchwonder
    Dutchwonder
    Hi all,
    I've been asked if I can identify this car. After lots of research, I'm still not 90%. I want to say a 1928 Chevy 2 Door Touring, except there's no little headlight. And the running board has me a little stumped too. I've eliminated several brands, so I'm not reaching out to you. Any thoughts? Thanks!
  2. Belt line looks like late 20's early 30's G.M.
  3. bscc50
    bscc50
    from n.e.
  4. Kume
    Kume
    I would have said 27 or 28 chev or 27 or 28 pontiac - maybe just missing cowl light
  5. verde742
    verde742
    [​IMG]1926 overland?
  6. bct
    bct
    Chrysler had the double belt line too.
  7. El Caballo
    El Caballo
    from Houston TX
    Wow, I think you nailed it verde.
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    I don't think so...compare visors and lower door bead moulding...side of Overland visor is longer and curved
  9. Ghost28
    Ghost28
    No the belt lines are too wide on the overland. 28 chevy is probably correct because the 27 had a taller roof line. The splash aprons look correct also.
  10. bct
    bct
    Middle hinge is between the belt lines on chev.
  11. studeynut
    studeynut
    Many cars with the double belt lines, some have 3 hinges some 4. The visor is different than most, the closest I can find is a 1928 Chrysler, its the closest I can find, but doesn't look quite right. Whippet and Chandler were also similar.
  12. Stogy
    Stogy
    Darn homogenized old cars...:D...So many different models in some of them too.
