Technical Please Delete
Discussion in 'Traditional Hot Rods' started by vespaholic, Mar 3, 2016.
  1. Please Delete
  2. dumprat
    dumprat
    from b.c.
    If it is a tapered pipe thread it will be about 1 1/2" pipe. Pipe is measured by the inside diameter.
    You could solder the fitting on too.
  3. 2 1/16" is a non-standard size. 2" plumbing/electrical pipe is actually 2 3/8" OD, 1 1/2" pipe is 1 7/8", there is no 'standard' size in between. If it's a NPT (national pipe thread), you could use 2 1/16 OD pipe (if you can find it, which I doubt) and find a friendly plumber with a pipe threading machine with an adjustable die to cut the right thread. If it's not a NPT and/or you can't find the right size pipe, then you'll need to have it machined after figuring out the thread pitch. If you can get the threaded bung out of the tank, soldering/brazing would be the easiest fix...
  4. bonzo-1
    bonzo-1
  5. side_valve
    side_valve
    Alliance Vendor
  6. brokenspoke
    brokenspoke
    FYI the radiator hose your using will not work well with gasoline....
