Hot Rods 1928 Ford Model A Pickup Build
Discussion in 'The Hokey Ass Message Board' started by bhurlin, Jan 28, 2016.
  1. bhurlin
    bhurlin
    from Texas
    I hope this post is ok, I have working on this for a while and have been trying to figure out how to put it together. I ask if it is ok, because the cab will be made out of fibergl*** as I could not find the pieces in one place. Essentially it is an extended cab 1928 that will utilize a coupe body through the "B" Pillars with the back off of a 1931 pickup. The top is chopped four inches.
    Here are the starts of the building of the cab itself.
    This is the start of the firewall and cowl
    This shows the doors with gell coat
    The door shell gl***ed in.
    The left side of the body completed back of the door
    The right side completed back of the door
    The New doors out of the Mold
    The A pillars and cowl ***embly to the right, doors to the left
    The cowl out of the mold.
    This is the cowl and a pillars attached to the right side of the car.
    kidcampbell71 likes this.
  2. If this is on the main board I don't see why you couldn't post if here, the traditional hot rod or custom guys may baulk at it but if the pros can post Brookville bodies and the like no reason a fella building one from scratch in gl*** couldn't post it.
    I guess if you have it posted in traditional hot rods or traditional customs you could drop one of the mods a note and ask him to move it to the Hokey ***ed Message Board.
    Looks like work to me but I don't work in gl*** so maybe its not. ;)
    1927graham likes this.
  3. haileyp1014
    haileyp1014
    from so cal
    Looks a little like this pick up
  4. flatheadgary
    flatheadgary
    from boron,ca
    how did you make molds if you don't have a steel body? foam buck or ? i am here to say, I LOVE FIBERGL***!! no warping or shrinking or beating on it . do you use tooling resin to make the parts with? i have found and had it verified with fibergl*** shops, that it will not shrink or warp like commercial resin does. a friend has about a hundred molds, as he has been at it for 50 years, and they have been sitting outside for all that time with no problems.
  5. bhurlin
    bhurlin
    from Texas
    I have been looking for a while for pieces to build a metal body. In my search I came across the Bruiser Body website.
    This company has changed hands and the molds were moved to Texas along with the name. I contacted them to see about getting parts so that I could put this together. It turned out they had molds for a Tudor, A Coupe and a 1931 pickup. The drawing is a photoshop but is essentially the front of a coupe that is stretched behind the doors and then the back of the 1931 pickup is brought into place. We are piecing together out of fibergl*** what was originally conceived on paper.
    I am working on a perimeter frame to match a 1932 frame, but will use 2 x 4 rectangular tubing. I am waiting on the body for final frame construction as I want to ensure a tight fit. It will utilize a spring behind front end. I still have not decided on the engine as I want it to all fit under a stock hood.
    We are working at being able to sell this cab. I also have the lead on a 40 inch fibergl*** pickup bed as well
  6. bhurlin
    bhurlin
    from Texas
    Finally getting out of the mold
    I am also starting on the framework with my ac***ulation of parts
    Using a Superbell with split wishbones
  7. Coming along, I'm watching, an interesting build in gl***, nothing wrong with that!! I believe the first gl*** hotrod body was a 32 roadster, built for drag racing in 1955.
  8. JimmyD3234
    JimmyD3234
    from PA
    THAT IS ONE - BAD - *** - PICKUP - :cool:
  9. bhurlin
    bhurlin
    from Texas
    The floor is now installed and it is out of the mold. We now will attach and mold on the back from a 1931 pickup as well as a flattened roofline to finish it all off.
  10. bhurlin
    bhurlin
    from Texas
    Here is the back of the Cab. Another day and we can start putting it together.
    As you can see this is a 30-1 back of cab and we need to match the bodylines of the 28-29 front portion.
  11. bhurlin
    bhurlin
    from Texas
    Here are the pieces out of the mold and set upon each other, the next step is to setup the cab length and then starting attaching pieces after the t******* is done.
  12. dirt t
    dirt t
    I subscribe!!
  13. bhurlin
    bhurlin
    from Texas
    Trimmed out and ready for roof and back to be attached
  14. The 39 guy
    The 39 guy
    Neat project! I will have to follow along.
  15. bhurlin
    bhurlin
    from Texas
    The left top fitted, ready to be trimmed
    The left side fitted into place
    And now the right
    The back slid into place
    And now the top into place
    Starting to bring all of the pieces together
  16. bhurlin
    bhurlin
    from Texas
    I am not sure how to make a video work, I hope this is it
  17. flatheadgary
    flatheadgary
    from boron,ca
    looks great!!! you are very good at gl*** work too.
  18. bhurlin
    bhurlin
    from Texas
    The seams are starting to be filled
    The visor is attached
    Filling in between the visor and the roof line
  19. bhurlin
    bhurlin
    from Texas
    Evering thing in place
    Rear view of the pieces filled in
    The visor finished out
  20. bhurlin
    bhurlin
    from Texas
    Almost ready to come home
  21. bhurlin
    bhurlin
    from Texas
    More....rear corners
  22. gnichols
    gnichols
    from Tampa, FL
    Nice job on the body build!!! FYI, I got mine commercially (by Russ-no-more, but I believe they are no longer being made). As you can see, it's very similar to your masterpiece. Love these kinds of bodies, they look so good they appear stock (except the chop). Gary
  23. bhurlin
    bhurlin
    from Texas
    Gary, they would not build another body for me. I was also looking at the larger size available in the Model a.
    Here are a couple more as we start to mount the door. I am also planning on not channeling this, but bringing the suspension down low.
    The hinges being installed
    This shows the inner bracing.
  24. Rand Man
    Rand Man
    Lots of hard work there. Good job. I have thought about this before. I would have made a mold from stock 29 pickup reproduction steel rear panels. Not saying that would be best. Did you just like the rounded look better?
  25. Barn Find
    Barn Find
    from Missouri
    Somewhere online I saw a photo of a complete Model A pickup in surface rust that had the cowl of a 29 and the back of a 30 cab. It took me a while to realize that was unusual. By then, I lost track of the photo. Did Ford ever build any like that?
  26. bhurlin
    bhurlin
    from Texas
    Doors being put together
    Door hinges in place
    Inner door installed onto hinges
    Top of p***enger door
    Another of the inner door installed
    P***enger side with door skin
    Drivers side with door skin installed.[​IMG]
    Tim_with_a_T likes this.
  27. bhurlin
    bhurlin
    from Texas
    Ford did not actually build anything like that, I am thinking I this would have been a transition look to get to the 30 cab.
    I was looking the smoother round look as if it was a prototype for the 1929 to 1930 transition.
  28. bhurlin
    bhurlin
    from Texas
    A couple more
  29. A Boner
    A Boner
    This is what you call building a hot rod.....and starting closer to the beginning than most builds. Keep up the great work!
