Projects 30 model A coupe project
Discussion in 'Traditional Hot Rods' started by 28av8, Feb 13, 2016.
  1. 28av8
    28av8
    It should be coated with something. I sprayed some rustoleum on it after I got it bent half way. The bottom isn't shown in the pics with the exception of before I sprayed it. I have weld through primer but it wasn't really necessary since that area won't be welded.
    whtbaron likes this.
  2. 2doorwagon
    2doorwagon
    Nice car you have!! Love a coupe
  3. whtbaron
    whtbaron
    from manitoba
    Do you think it would be possible to make a single complete roof panel from the hole forward. Basically I'm thinking one panel from drip rail to drip rail including the visor... or is the visor itself too complex? Might be more work than grinding the welds for 4 separate pieces. My 5 window in waiting is identical to yours, but much rougher, so I'll have to replace the side panels as well as making the roof panel.
  4. 28av8
    28av8
    Sounds like it would be a lot more work then making it in multiple pieces. I dunno how you would ever maneuver the whole roof in a bead roller to do the visor. I find myself other trying to make too complicated of a piece and just end up cutting it apart to finish it
  5. 28av8
    28av8
    Got the visor finished up this morning. I punched some holes in it with a dimple die. Now it's sure to go fast haha.
    jkluge, AHotRod and whtbaron like this.
  6. waxhead
    waxhead
    from West Oz
    Looks faster already :)
  7. 28av8
    28av8
    It's amazing what removing 5 inches of metal will do.
  8. Aaron D.
    Aaron D.
    Too cool man!
  9. 28av8
    28av8
    I made some relief cuts in the back and started tacking everything together.
    K.L, OLSKOOL32, AHotRod and 1 other person like this.
  10. 28av8
    28av8
    I spent the day working on my rear lower corner piece. I started by making some patterns. I tried making it out of one piece but couldn't get it through the bead roller. I ended up cutting it into 3 pieces.
    It took a lot of shrinking on the pullmax to get the right shape. It ****ed to have to cut it but it made everything a lot easier.
    Ron Funkhouser and whtbaron like this.
  11. sloppy jalopies
    sloppy jalopies
  12. sloppy jalopies
    sloppy jalopies
    there is a small steel bracket spot welded inside the skin at the upper beltline... it anchors the outside door handle screws... no one sells it... made one this week... pix if you want ? ...207-786-4795
  13. 28 Ford PU
    28 Ford PU
    from Upstate NY
    We are free to enjoy things like old Fords because we have people like you supporting our country.
    We have always been great and you can't Trump that.
    Atwater Mike likes this.
  14. Dino 64
    Dino 64
    from Virginia
    Great chop, cleaver corners, looking good. Waiting to see how you do the wheel wells. Lots to learn on this thread, thanks.
  15. 28av8
    28av8
  16. AKGrouch
    AKGrouch
    Nice work. I wish I had just some of your metal skills. It is looking good. Enjoy the chop except don't get a crick in your neck trying to see stoplights......I watch the walk/don't walk signals some.....it helps. My coupe is chopped between 4 and 5 inches.....I would not chop any more.
  17. 32owner
    32owner
    WOW very impressed
  18. dirt t
    dirt t
    Make your self a s****book of this build and use it as a resume. Your developing some great skills.
    With your military service and schooling you will be a great addition to a shop.
    Thank you for your service.
  19. 28av8
    28av8
    I got around to making the rear inner trunk panel today.
    The trunk lid fit like ****. It wasn't flat on the bottom. I trimmed it and welded the seam up.
    Before.
    After.
    O yea, and now it's a trunk instead of a rumble.
    I still have a lot of little stuff to do on top of the wheel wells. Tomorrow is the last day of body fab. I start refinishing in a couple weeks. I should be able to finish everything there. The goal is to be leaving with a painted body in the next 3 months.
  20. Racer29
    Racer29
    Man you need to start your own Model A panel business! Looking good. We are moving to Rapid City next week. Need to meet up with you. I was up at the Hot Rod Ins***ute a few years ago looking around.
  21. brady1929
    brady1929
  22. BenLeBlanc
    BenLeBlanc
    Geez, it's the model a body repair express! You are trudging through it on no time flat.
    I am starting to do the body work myself. Thanks for posting this loose "how to".
  23. Futura63
    Futura63
    from N/W ohio
    Looks good.. Just got mine out of the booth. 100_0722.JPG 100_0725.JPG 100_0725.JPG 100_0724.JPG
    chop job and whtbaron like this.
  24. 40Ford!!
    40Ford!!
    Great job my friend. Glad to see our guys on the front lines have such great metal skills. Good luck with it and thanks for serving!
  25. 28av8
    28av8
    I got back to school today to find my parts from Howells finally arrived. Kinda weird since I cancelled them but o well. They're surprisingly nice. It's too bad the company ****s as far as customer service goes.
  26. Great build, you do some amazing work! How much did you end up chopping it, 4 inches?
  27. 28av8
    28av8
    It's chopped 5 inches
    I got right back to the grinder this week. Here's some new pics.
    They still needed a little work.
    This Lazze bead roller is pretty much the best thing ever. The inside bottom die is just a guide. I tipped the edge up around the upper die. Then I just had to shrink the curve.
    Trim to fit and start welding. I did the wheel well to the curve on the table.
  28. 28av8
    28av8
    Forgot this one. I made the drip rail for the drivers side. It's a pretty good match.
  29. Dino 64
    Dino 64
    from Virginia
    Thanks for showing the wheel wells repair. Is the panel a reproduction, if so where did you get it. You did a great job. Unfortunately, I don't have the equipment, but at least I know how to do it. Thanks.
  30. 28av8
    28av8
    The wheel wells are from Snyders. They were much better then some of he others I've seen.
