Technical Need Help Bad, driveshaft on the daily
Discussion in 'The Hokey Ass Message Board' started by El Caballo, Mar 6, 2016.
  1. El Caballo
    El Caballo
    from Houston TX
    Guys, I need help here with the driveshaft out of my '97 K1500 Suburban, it is the wife's daily.
    I know it isn't traditional, but HAMBers helping HAMBers is.
    The u-joints have 206k on them and I noticed a squeak coming out of them, okay change them out, no biggie. Except they seem to be pinned in. Also, there are no c-clips in there, WTF Chevy?
    I'm guessing the answer is to drill the pins out, but no mention of this in my ****py shop manual. Has anyone here changed out u-joints on your Chevy truck and run into this?
  2. atch
    atch
    El C;
    I'm probably wrong and will get my *** handed to me on a platter, but aren't those pins plastic and melt out? Do the new u-joints have new pins to check this against?
    El Caballo likes this.
  3. They should be plastic and melt.
    wedjim likes this.
  4. they are plastic and a small propane torch will melt them out. heat them and it will shoot out. then you use inside clips on the replacement u-joint.... i believe it is 534g
    i'm surprised they have never been replaced before
  5. wedjim
    wedjim
    from Kissimmee
    Use a torch if you have access to one, but don't glow the yoke red, just warm it until the plastic starts to ribbon out of the hole on its own. A br*** drift and hammer on a vice and they'll come out like traditional U-joints. You may have to reheat to soften the locking plastic while dis***embling them. The replacements will come with snap rings.
    kidcampbell71 and El Caballo like this.
  6. squirrel
    I just press the U joint cups out, there is no need to melt the plastic. It will break easily enough
  7. Russco
    Russco
    from Central IL
    ^^^ Yep, remove them just like any others, no need to melt anything and install new ones with the clips that come with the replacements.
  8. But the fire and melting is FUNNNN!
  9. El Caballo
    El Caballo
    from Houston TX
    I huffed the plastic fumes, weeeeee!
    Thanks guys, I would have never guessed they were plastic.
