1955 Dodge 1/2T pickup, C3B. Short lowside bed. There is surface rust on the floors but they are solid. There is some rust on the bottom passenger door. The only major body damage is the rear driver fender. The engine is apparently a 1964 era 318 Wide Block Poly V8 engine. Has not been run in a few years but should run with typical maintenance. It is a 4 speed. i have an additional V8 engine option (additional engine to go with the truck for an additional $1500). Truck was originally green and had the flathead 6 engine.
