Projects Henry J Southeast Gassers build
Discussion in 'The Hokey Ass Message Board' started by Uncledirty616, Jan 16, 2016.
  1. Uncledirty616
    Uncledirty616
    She is back down on all four wheels, and ready to ship out to start ch***is work. I will be lowering the rear for sure, and hopefully the front also. Stay tuned. 12119747_10205947261745094_1660344116_o.jpg
  2. Uncledirty616
    Uncledirty616
    Got her out to Mikes and gonna start tearing into it. Threw the motor and trans in to see where everything sat in relation to the mid plate that was already in the car. Looks like its pretty close. 1914589_10205953447139725_2471081169323354672_n.jpg
  3. Uncledirty616
    Uncledirty616
    Started work on the car today. Got the motor positioned, leveled and welded in the mounts. 12821529_10205960042624608_5320615001599085794_n.jpg
  4. Uncledirty616
    Uncledirty616
    pulled the front end off. We decided to replace the radius rods, the ones on the car had been dog legged and i was concerned about safety with how fast I intend on this car going. 12722477_10205961144372151_962596721_o.jpg
  5. Uncledirty616
    Uncledirty616
    Also started work on a cross member for the trans/bones/ladderbars. Car looks pretty naked right now. 12675018_10205961144612157_2110662229_o.jpg
  6. Uncledirty616
    Uncledirty616
    Cut the fire wall out
  7. Uncledirty616
    Uncledirty616
    New radius rods
    Dog_Patch and 9sectruck like this.
  8. Uncledirty616
    Uncledirty616
    In the car
  9. strokedstang331
    strokedstang331
    from Beloit WI
    Pretty soon u will have all the extra sheet metal trimmed out. That's how I started out on mine trim a little here and there and now all I have left of the stock sheet metal is the out side skeleton. Remember every ounce counts :D
    powrshftr, Uncledirty616 and II FUNNY like this.
  10. Uncledirty616
    Uncledirty616
    Got the front suspension back together and in the car. We have 11 degrees caster. And the super old school look of buggy spring+ radius rods. Very happy.
  11. powrshftr
    powrshftr
    Looking great Man!
    Uncledirty616 likes this.
  12. Higgy's Henry
    Higgy's Henry
  13. Uncledirty616
    Uncledirty616
    I did a little work on the heads. Not much visual at the moment. Waiting on the rearend.
  14. Cabbage
    Cabbage
    Looking good keep at it. You are ahead of me for sure!
  15. Panel Pete
    Panel Pete
    Oh Henry, I'm lovin' the J!! What a tough lookin' little machine, really diggin' the tilt front end and the fit/offset of the rear tires. Subscribed fo sho to follow this bad little mofo!
    Gotta ask a couple questions: what's the overall flange 2 flange width of the rear axle it came with vs. the width of the one your using and what's the back spacing of the old rear wheels vs. the ones yer using? Also, does the front suspension use stock ford pieces (spring/axle dimensions) or is any of it "dropped".
    I'm askin' since your setup looks just right and I'm collecting parts for my own Henry J build up, and I'd like to build a ch***is and buy wheels only once! Mines in pieces at the moment and I'd like to make a roller before I go and collect the body.
    Thanks bud,
    Pete
  16. Uncledirty616
    Uncledirty616
    thank you for the compliment. The front end is a stock 1939 Ford truck axle, spring, spindles, and radius rods. Its using pretty much stock Ford parts except it has been converted to disk brakes, prior to me owning the car. Me and a friend (Mike Boerema of Gas Axe Garage) Redid the front though because when i got it the radius rods had been dog legged and i just dont feel it would have been safe. As for the rearend, the Axle flange to Axle flange measures 55 3/4" if i remember right. Im hoping to have it back soon, so i can get to fitting it in the car. The car never had a stock rear end in it since i have owned it so no idea what it would have measured. School is done next week, so im hoping to get back into workin on it. Have a great day, and i hope that helps.
  17. alumslot
    alumslot
    The track with for a stock Henry J is 54" front and back. Hope this helps you.
    Jim
  18. Uncledirty616
    Uncledirty616
    Cut most of the floor out today. Tried to do it nice and clean so that when i put the aluminum in, it still looks nice. cuttinfloorout.jpg
    Dog_Patch and powrshftr like this.
  19. Uncledirty616
    Uncledirty616
    decided to throw what i cut out on the scale, with the trunk lid, but not including the firewall. Drumroll, a little over a hundred pounds weightsavin.jpg
    Dog_Patch, 9sectruck and powrshftr like this.
  20. Uncledirty616
    Uncledirty616
    scottinstruction.jpg My Carbs showed up about a week ago, and finally got to dig them out and play with them. Apparently the Canadian instructions are much more thorough then our janky American directions lol Thank you Scott =)
    Bondo Slinger, Spoggie, enloe and 4 others like this.
  21. Uncledirty616
    Uncledirty616
    So of course i had to throw them on the tunnel ram and see what it looks like =D tunnelramside.jpg tunnelramfront.jpg
  22. powrshftr
    powrshftr
    That's some bad***ery right there.
    Looking good Brother!:)
  23. Uncledirty616
    Uncledirty616
    Lovin the carbs thank you so much!
    powrshftr likes this.
  24. powrshftr
    powrshftr
    No problem Brother!Same goes for that little bit of Blue Oval gold you sent me.Greatly appreciated!:)
    Scott
  25. Higgy's Henry
    Higgy's Henry
    I knew those were Canadian instructions as soon as I saw the duct tape!!!!
  26. Dog_Patch
    Dog_Patch
    Is that really how you spell Baloney ?
  27. Uncledirty616
    Uncledirty616
    Lol yes, i take it your to young to remember the Oscar Meyer commercials?
  28. Uncledirty616
    Uncledirty616
    Hope she serves you well. Is it going in the Mustang?
  29. powrshftr
    powrshftr
    It might be going in a 65 Fastback if I can ever get it home.lol!
    Jackson was kind enough to locate one for me ages ago,and I'm working on getting it back across the border as we speak.
    Local guy might be able to pick it up for me.:)
    Thanks again Man!:)
    Scott
  30. Uncledirty616
    Uncledirty616
    Got the main hoop fitted tonight. 13086760_10206356807583484_8340970310431560837_o.jpg
