Technical 1932 Ford trans id?
Discussion in 'Traditional Hot Rods' started by Ilari, Mar 13, 2016.
  1. Ilari
    Ilari
    image.jpeg I'm not sure which trans I have in my roadster now. Motor is 1937 flathead. Can you help me to id this?
  2. Ilari
    Ilari
  3. Dak Rat
    Dak Rat
    from NoDak
    My guess is '32 ford--has the leaned back shift tower, and a "B" serial number. I was wrong once.
  4. 48-760
    48-760
    from OH
    32 shift top. Look at the number stamped above your duck tape it will tell you the year of the case. 18-001 to 18-203,126 is 32
    LOU WELLS likes this.
  5. rusty bill
    rusty bill
    Only 32's had the shifter top cover with the mounts for bolting the e-brake handle to. Also 32's didn't have a square inspection plate hole in the top of the case in front of the shifter. Therefore you have a 32 topcover and case.What gears are inside are yet to be determined.
    302GMC likes this.
  6. Ilari
    Ilari
    Thanks for reply, I tried to see the area above The duck tape for numbers but I did not see any.
  7. Bruce Lancaster
    Bruce Lancaster
    B 7222 is the part number ('32 correct) for the main casting of the shifter. It's the only year with lugs for brake, so is '32 for sure. Serial as noted should be above the tape...but is engine one originally sold in Europe? Most countries there required Ford to stamp serial on engine block (done on the manifold face of block). I do not know if Ford also stamped the trans in the usual USA way. '32 V8 engine would be either USA or Canadian built, there were no other V8 plants until later.
    Any gears will go into a '32 case, but that shifter top will only work properly with '32-5 gears unless pretty thoroughly modified.
  8. Ilari
    Ilari
    I do not know the origin of the engine, the ch***is is danish, but engine has been rebuild here in Finland and should be 1937.
