Hot Rods Spalding Bros Repro, for "Too Tall" Ganahl.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jul 13, 2015.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    pgan, marty and steel rebel,
    My bad. Man, I've got to get my eyes checked as I erroneously thought steel rebel's post referred to mounting the rear radius rods with Heim ends. Clevises are better. I'm glad they're there since you intend to drive it hard, and I did not mean to imply your car wouldn't be used as a race car. In fact I think it would be wonderful to see two inline six / crossflow headed dirt cars with a combined drivers' height in excess of 13 feet dice it out on some short track somewhere. Perhaps our compe***ive paths will cross to make it happen.
    brad2v likes this.
  2. Marty Strode
    Marty Strode
    Did anyone notice Pat's new Avatar ? Excellent choice !!!!!!!
    1947knuck, jangleguy, HEMI32 and 2 others like this.
  3. steel rebel
    steel rebel
    I hadn't. Is that the engine going in this build? Wish he would post a larger picture.
    Gary
    brad2v likes this.
  4. Marty Strode
    Marty Strode
    Gary,
    That's the GMC in his dragster. Nice to see everything in the copper stage. Spalding 6.jpg
  5. Speaking of the Iacono dragster, I thought I would post this pic of Ike's dragster.
    1947knuck and Countn'Carbs like this.
  6. Asphalt Demon
    Asphalt Demon
    from Australia
    I love this thread. Ive always admired and respected your work over the decades Marty. and i love it even more now to know you suffer from the same distractions and having goofball/oddball friends like the rest of us.Johnny thanks for sharing
  7. Wow, I must have been unconscious for the last eight months.
    I thought I was the only person building a Blueflame power Ford with a Ford Trannsmission, and a quick change.
    volvobrynk likes this.
  8. Marty Strode
    Marty Strode
    While waiting for some essential pieces (that I will have soon), I did some cleanup machining on one of the rear end side-plates, and the rear axle construction is getting underway. The salt car I built a couple of years ago, needed some alterations ( 3 " lower roll cage & some streamlining). A little finish up work, and it will be completed. IMG_6331.JPG IMG_6332.JPG IMG_6335.JPG IMG_6351.JPG IMG_6356.JPG IMG_6355.JPG IMG_6366.JPG
  9. Weedburner 40
    Weedburner 40
    I like the RMR Marty. Kind of reminds me of the one we did several years ago for a guy in Portland, only it was a 27 body.
  10. Marty Strode
    Marty Strode
    The "Big Brown Truck" showed up today, bringing some parts from Schroeder Steering. They shipped us an empty steering box, so I can mount it and finalize the length of the steering shaft to the wheel. The torsion bar arm blanks and stops, will be trimmed and shaped to the desired length, and mounted. The bronze bushings will be fitted into support blocks on each end of the bars, and welded the the side of the frame rails. More progress on the Lakes/Salt car. IMG_6368.JPG IMG_6370.JPG IMG_6376.JPG IMG_6373.JPG IMG_6374.JPG IMG_6375.JPG
    1947knuck, brad2v, volvobrynk and 2 others like this.
  11. steel rebel
    steel rebel
    Marty I ****ing love all the stuff in your shop even that bicycle thing in the background.
    bct and brad2v like this.
  12. Marty Strode
    Marty Strode
    1947knuck, jangleguy, brad2v and 4 others like this.
  13. porkshop
    porkshop
    from Clovis Ca
    Marty do you build and sell those? That pretty slick looking.....
  14. steel rebel
    steel rebel
    Very Kool Marty!
  15. Marty Strode
    Marty Strode
    Porkshop, My Brother and I "motorize" some bikes just for ourselves, his sits a little lower to the ground than mine. I couldn't help taking for a ride, after I finished his gas tank. I built mine for a pit bike at Bonneville, but have since re-powered an old Cushman, thinking if and when we return to the salt, it would be more appropriate. IMG_5215.JPG IMG_5727.JPG
    1947knuck, bct, brad2v and 5 others like this.
  16. steel rebel
    steel rebel
    I had one like that in the "50s. I'll try to find a picture.
  17. sololobo
    sololobo
    omg, cool, one of my alltime fave hot rods, drooled over it in the little books
  18. sololobo
    sololobo
    salt, dirt track, drag strip, no problem, this warrior feared none
  19. Les Moran
    Les Moran
    from australia
    Marty. Glad you were able to clean up some of the scars on the Side - Plates. Makes me happy .
    kidcampbell71 likes this.
  20. brad2v
    brad2v
    Makes me wish my mailbox were farther away
  21. Marty Strode
    Marty Strode
    Thank you my friend for supplying them, they are just what we needed for this project.
    1947knuck likes this.
  22. Marty Strode
    Marty Strode
    Well, I finally got my land speed project completed. It needed an air box and scoop for the induction system. Being relatively new at pounding out aluminum body parts, and still learning by trial and error, this is what I came up with. Using .050 - 3003 aluminum, I settled on a design similar to a 60's era dragster. Back on the Spalding next week !!!!!!! IMG_6399.JPG IMG_6405.JPG IMG_6406.JPG IMG_6407.JPG IMG_6410.JPG IMG_6411.JPG IMG_6456.JPG IMG_6459.JPG
  23. steel rebel
    steel rebel
    Simple. Well you make it look simple. Beautiful.
    Gary
  24. Marty Strode
    Marty Strode
    I got started on the steering box mounts, machining the large sleeves and clamp bolt tubes were the first tasks. When I fixture parts for welding, I normally form up a channel to align the parts, it is much easier than trying to clamp small parts. With the clamp sleeves welded, I sawed them in half, and ground the mating surfaces. IMG_6463.JPG IMG_6467.JPG IMG_6470.JPG IMG_6472.JPG
    1947knuck, brad2v, 50Fraud and 3 others like this.
  25. Marty Strode
    Marty Strode
    Step # 2 ; Rather than try to fab the steering stands in the car, it was much easier to build a fixture using exhaust tubing and muffler clamps and build them on the table. When fitting round tubes, I sometimes shear strips of s**** aluminum (7/8" wide in this case) to fit the angles and miters, and transfer to the tubes. The large side gussets with the 3" holes will be next. IMG_6474.JPG IMG_6475.JPG IMG_6476.JPG IMG_6478.JPG IMG_6479.JPG IMG_6482.JPG
  26. RidgeRunner
    RidgeRunner
    from Western MA
    Neat fabrication tips, thanks for sharing. Older I get the more I like working smarter not harder.
    Ed
    falcongeorge and volvobrynk like this.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice. Do you drill-and-tap into the frame or use Rivnuts to retain?
  28. tfeverfred
    tfeverfred
    Thanks for taking the time and energy to pause in your busy schedule and chronicle your progress.
  29. Marty Strode
    Marty Strode
    Do you mean on the steering stand ?
    Frenchtown, if you look at the original car you will notice the boxing plates ended at the back of the block, and had bolts had nuts. My preliminary decision was to start out with plates longer, making the ch***is a little more rigid, because dirt tracks can get rough and Pat is going "use it". If we stay with the existing plates, I will weld nuts inside, or at least flush with the rails. I fabbed the tower gussets today, notice the difference in "lightening" hole sizes and vertical location, they were different on each side. The next operation will be the torsion bar mountings, and profile the blank arms to resemble the originals. Spalding 1.jpg IMG_6483.JPG IMG_6484.JPG IMG_6485.JPG IMG_6486.JPG IMG_6487.JPG
    1947knuck, volvobrynk, brad2v and 6 others like this.
  30. Marty Strode
    Marty Strode
    I finally finished Jim Lindsay's Lakes/Salt car today, fitted the front axle fairings. He got some paint on the new cage and aluminum work, along with some advertising for his "Highly Acclaimed" book. Dean Lowe, if you are watching, look at the last picture, I didn't have room to haul the doors and gas tank home today, but I have a good start, and I am serious . Pat won't let me work on it until I get his job completed though ! IMG_6536.JPG IMG_6534.JPG IMG_6541.JPG
