Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Does anyone still use needle bearings between leaves with lots of bearing grease and a wrap on the spring pack afterward? I know it doesn't last forever, but back in the '60s that's what I did to get rid of squeaks and smooth out the ride.
  2. n847
    n847
    Gonna be the nicest spring pack in all of the KC!
  3. Tim
    Tim
    from KCMO
    I don't know about nicest but possibly the one with the most time put in to it lol.
  4. Tim
    Tim
    from KCMO
    image.jpeg Figured I'd start this post with another inspiration photo. Not to many sitting on an agressive take with no chop and this ones even green!
    Anyhow I got my leafs all sorted and ready to reverse today.
    image.jpeg I made a m***ive mess inside when I started yesterday so today I took advantage of the nice weather and the fact that most of my neighbors would be at work.
    I staryed cleaning up the gouges first. I used a flap when on my grinder and some other weird abrasive discs I had around but they didn't really cut the mustard so to speak. However as I grazed the end of each leaf I found some subtle indentions that I may have other wise missed so there's that.
    image.jpeg I ended up starting today by hitting the indentions with a grinding wheel with the spring in the vice. That worked much faster and then I fine tuned and got te last little bit of it out with the flap disc as it's quite a bit slower at pulling material.
    That done I moved rounding the ends of each leaf. I first took the grinding wheel and nocked off all four corners off the end of each spring. As long as some of those grooves I worked out were I figured the less things to grab the leaf under neath the better.
    The side ones I basically flattened out and the two on the tip were ground to give the end of the leaf a slightly round curve. I wouldn't say a half a circle round, more like a philbert tip on a paint brush... Or I guess like a finger nail.
    Anyhow I think rounded the bottom surface of the leaf getting rid of that leading edge all together. Some of them got all the way to a nearly a knife edge and others maybe a 1/16 thickness temained at the tip. I tried to make the slope as smooth as possible so I made the transition up to a half inch long.
    My thought is the smoother the better, and since working the grooves out of the leaves still gives you a bit of a wobbly surface is try to make up for it by really paying attention to the surface that would be sliding on it.
    The grinding wheel can be a little in forgiving it you catch a funny angle so I got them pretty close and then went back with the flap disc and got them all the way there.
    As of now the plan will be to drive the remnants of the old bushings out of the spring eyes, sand blast both packs, reverse the main leafs, trim the second leafs and then make the call on paint and ***emble with Teflon slips.
    Seems half say paint each leaf and the others say paint the whole pack as one.
    In my mind I should be fine painting them one by one because if I'm running the Teflon I shouldn't have springs pushing paint off the spring under it.
    That make enough since?
    I also know that they will sit for some time on a dowel and not put together under tension so it seems painting each leaf would stave off any rust from
    Sitting around waiting for the ch***is to be ready. With the reverse eyes I'll have to strip the pack to just the main to install it because you can't use a spreader on them. So I don't see the point of putting it all the way together only to take the pack apart to put
    It on the car
    Well other than for easier storage I guess.
    Wow that was a ramble
    Any how that's were I'm at.
    image.jpeg Making a mess
  5. wuga
    wuga
    As for a gas tank, how about a 1948-52 Ford pickup tank mounted in the back like this
    Did it in 62 and did it now. Fits like Henry designed it. Repops available from Speedway.
    Love 28-29 Tudors. Built several back in the 60s but foolishly talked myself into a 30 this time. Just my opinion, but please no 32 tank on an A
    Warren
  6. Tim
    Tim
    from KCMO
    Thanks for the photo warren, David has his like that in his red oxide sedan I posted and you really don't lose much foot room doing it like that.
    I'm shying away from this option for a few reasons however.
    1: really don't want the tank inside
    2: with stock foot room I might be able to have someone sit in back and have my dog lay on the floor in the back
    3: I'm planing to have it possible to pull the body and have a driving ch***is with out pulling fuel lines or anything.
    There's probably more reasons but that's the jist, though it does look like it was build for this use doesn't it!
    Right now my current idea- which is subject to change- is a tank behind he rear axle but not sticking out past the bottom of the body and paint it flat black.
    I think with some polished nerf bars and the license plate mounted either on the nerf or on the body near the bottom with a Hollywood plate lamp that the tank would disappear into the back ground 90% of the time.
    Polished stainless vs flat black
    Out in the sun vs tucked under
    Round tank vs plate and nerfs with strong angles and definable edges
    Should be able to fit a spun type tank that holds 11 gallons with about 7 inches to spare width wise
  7. Tim
    Tim
    from KCMO
    Dig this! The darker green is similar to the green we are thinking.
    I'm still voting black fenders and the more sea foam/mint green on the wheels and striping . Also the grill shell will be painted body color.
    Though body colored fenders with black wheels and the lighter green on the caps and stripes is still appealing.
    In the end I'll probably spray paint each side of the car different and see which one looks cooler
    juan motime and mctim64 like this.
  8. FinnishFireball
    FinnishFireball
    I hear you Tim with the gastank headschratching issue. I had saddletanks on my puppy and I hated them. I did not want the tank inside, the spun tanks looked somehow strange to my eye and deuce style kits are overpriced. Anyhow I felt that the space between fenders needs to be filled so I ended up fabricating my own 10 gallon version out of stainless. At least it's homemade if nothing else :p
    Outback, bymanr, kiwijeff and 3 others like this.
  9. @Tim something just occurred to me, if you reverse the spring eye the divot on the main leaf is going to be on the back side and won't make any difference other than if someone gets down there and looks at it.
    The spun tank out back takes a specific type of car to actually be right. A performance oriented car like an early '60s street strip car almost begs for it, but a cl***y cruiser doesn't want it at all. At least that how I view it.
    Outback likes this.
  10. Tim
    Tim
    from KCMO
    That looks pretty cool fireball! I'd thought of doing something similar actually but decided that I actualy prefer the space open.
    With the tall skinny tires and the heavy rake I think that space being empty makes the body not only look shorter but higher up. I think if the build were heading a different direction I'd do what you did but for now I think I'll try out this "hiding in plane sight" idea
  11. arkiehotrods
    arkiehotrods
    From the 2012 Hot Rod Garage open house
    kiwijeff and Tim like this.
  12. The nice thing about fenders is they give you a good place to hang tail lights. ;)
    Nice sedan @arkiehotrods I have never been one for green vehicles (bad luck) but that color combo was my dad's favorite and I always like to see one painted like that. :)
    Outback likes this.
  13. Tim
    Tim
    from KCMO
    Thats a cool one Duncan! Dig all that rubber stuffed in the back. For an area that's so often not thought about/discussed I really think it makes a big difference in how the car feels.
    Got some cool ideas brewing :)
    Atwater Mike likes this.
  14. flatout51
    flatout51
    Actually I started to do that but ruled against it. It took up too much room to have a back seat and with my son back there didn't like the thought of the fuel right there. I was running the stock tank but now will be using the saddle tanks from Tanks. I think they are the most logical placement for tanks in an A Tudor.
  15. Tim
    Tim
    from KCMO
    I guess with the filler up high and your seat spaced forward to jump to the conclusion that the tank was back there. How's your progress going on that one?
  16. Tim
    Tim
    from KCMO
    image.jpeg Holy cow those wheels look bright! A friend changed the wheel color, ditched the plate and "painted" the grill shell for me real quick in Photoshop.
    On his lap top those wheels are a nice soft sea foam, on my phone they look day glow green! Lol thought I'd post it anyways
  17. flatout51
    flatout51
    Yeah the filler was from when I was going to run the tank back there and the seat is as far back as you can get a seat. Thats how much room you'll have. Its moving slowly forward! Waiting on parts.
  18. I'm glad I came across this thread as I will be picking up a 2 door sedan body either this weekend or the next. I too want full fenders. I like a green. I'm staying with the 4 cylinder banger. The really scary part, I have a beard similar to yours.
    Tim likes this.
  19. Tim
    Tim
    from KCMO
    Cool! Gotta love the fenders :)
    That makes since David, I took a lot of photos of the back seat area of stock restored cars last summer so is know what to expect. I'm super excited
    flatout51 likes this.
  20. Tim
    Tim
    from KCMO
  21. All though I'm not sure the year of it, here are a few teaser pics....
    Outback and kidcampbell71 like this.
  22. Bader2
    Bader2
  23. Tim
    Tim
    from KCMO
    Yup! Show us the firewall and maybe we can narrow it down. Looks dang good though, is it chopped?
  24. Dan Hay
    Dan Hay
    I realize I'm a little late to the spring pack party, but a safe (ish) way to take them apart is after you get the bolt out and they are all clamped, use a long piece of all thread, nut and washer on both sides, then you can unclamp and back the nut off slowly to unload the leaves. you can also do this to put them back together.
  25. Tim
    Tim
    from KCMO
    Yeah I think I mentioned in one of the first posts that that's how I had planned to do it.
    In the end when only the main leaf was left I still had to beat on it for five minutes to drive it out. There was no way that thing was gonna come out of the whole pack
    Dan Hay likes this.
  26. Not a lot of room for tanks in these things. I have all the parts to make a 32 style tank out of two Triumph tanks. If I ran fenders I would run a couple small saddle tanks, maybe 7 gallons per side. The store bought ones look like you could drive cross country w/o refilling. You WILL be stopping more than that.
  27. Tim
    Tim
    from KCMO
    Hey Trent! Man I forgot all about your sedan project. How ya been?
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    I still have the gas tank from my F1. It's clean (I was running it before the accident) and even has a sending unit.
    It's yours if you want it... and I like Boulevard Wheat.
  29. Tim
    Tim
    from KCMO
  30. Tim
    Tim
    from KCMO
    I think I'll have to go look at a stock car/back seat and see how forward that tank would put the seat. That's nearly double capacity and with new rubber it probably wouldn't stink up your car inside
    Outback likes this.
