Hot Rods Barn find 1937 Chevy coupe
Discussion in 'The Hokey Ass Message Board' started by airbag, Feb 14, 2016.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    I'm a hot rodder and all, but man, I love that car and I am not sure I'd touch it! Great score!
    Old-Soul likes this.
  2. airbag
    airbag
    I originally said I was gonna put a 327 4speed in the car but after having the time to go thru it and realize how original it is and the fact of knowing there ha never had any paint or body work and can't find any bolt that had been turned let alone replaced. I can't do anything but get it running and drive it and enjoy it.
    Lebowski, TinShed, Jet96 and 7 others like this.
  3. YJ4000
    YJ4000
    Great find. Looks great. Have fun!!
    Ryan.
  4. TFoch
    TFoch
  5. old1946truck
    old1946truck
    You could always upgrade the brakes so you know it will stop safely.
  6. what a beauty! i feel with you with letting it alone in this state, it would hurt to take even the engine out of her...
    kiwijeff likes this.
  7. volvobrynk
    volvobrynk
    from Denmark
    I wouldn't loose a nights sleep over removing any part and preserve them to a later re***embling in a distant future. If such a future ever comes up.
    And mount a 261, two carbs, a modern(ish) 4 speed with synchro, highway friendly rear gears and drive it all the time and everywhere, at any speed. Maybe run modern(ish) brakes from a early fifths Chevy AD, so you could relax and enjoy the car as it was meant to be, even in modern traffic.
    By cutting in the pristine body and all around awesome(!) piece of history, would brake my heart. But rodding it up like a kid would have done way back when, one piece at the time , would make my body tinkle and my brain let out even more endofines then having ***.
    loudbang, 1low52 and tb33anda3rd like this.
  8. Fedcospeed
    Fedcospeed
    Yup, road worthy it and drive.It will never be what it is again if you change things around
  9. I agree, one of the nicest looking pre-WWII cars built. Pretty grill and hood sides. Always liked those slanted B-pillars.
    As for the French designed independent front suspension, it's junk. This is one reason why the Standard cars with a straight axle are more plentiful than the Deluxe models. Except for Michelin tires and the BIC ball point pen, is there very many good engineering marvels that have a French origin??? These knee action ***emblies, back in the day, killed people. These aren't like the later knee action that had the upper control arm/shock absorber unit. They were OK.
    To keep the car original, but more functional and safer, I'd swap a '37-'38 stock parallel leaf spring straight axle front end under there and do the Bendix brake upgrade. Not sure if the steering box is the same.
    tb33anda3rd likes this.
  10. tb33anda3rd
    tb33anda3rd
    the french did bring us Le Petomane.
    Jet96 likes this.
  11. dirty old man
    dirty old man
    Once a French Army officer asked a British Army officer why the Brit officers wore a red coat into battle.
    The Brit replied that the red coat concealed the red blood if the officer was wounded but still on his feet, thereby continuing to inspire his troops as he led them into battle.
    From that day forward all French officers wore brown trousers.
  12. ^^^ I've no idea how this aplys here, but that's freakin funny.
    As for leaving this car alone, I'm usually the first to say, cut it.
    37 Chevys have been my favorite year of Chevs since I was a teenager, so in a very rare, not likely to be repeated moment, I have to say I'd not like to see it cut either.
    I'd not cry over it if you did, I'm a Hot Rod guy, but that thing is so Damn perfect, it'd be nice for it to remain so.
    volvobrynk likes this.
  13. As usual, a little late with my comment(s) but here goes: I'm very glad about your decision to leave it as is, at least for now - that car is absolutely gorgeous, as is - WOW! I had a '37 Chev pick-up in the early '80's that was roached out. I had heard about this 'new' fad of using a Mustang II front cross member & decided to check it out. I did some measuring & configuring - all I had to do was notch the inner slope of it, so it would fit around the frame rails and it fit perfect. I installed it with a slight front to rear tilt as it was in the mustang. I used a protractor but forget the angle/dimensions. My next concern was oil pan/firewall clearance. A generic '70's sbc pan worked great & the dist fit nice against the firewall. Good ol' Speedway had 5 lug disc rotors, that took care of that issue. I used the original '37 trans cross member & a 350T trans. Again angles were checked. A '68 Camaro gave up its 12 bolt rear & Leaf springs completed the drive train. I got the old truck up to a running driving state. You could take your hands off the steering wheel & it tracked just fine, after getting front end lined up. I used to put stuff together and get 'em running and sell 'em. I wish I had it back - oh yeah - I didn't have to change front springs as the weight of the engine 'lowered' it....it rode & drove great - my story :) I'll post pics when I find them.....
  14. 48 PLYMOUTH HEMI
    48 PLYMOUTH HEMI
    from WV.
  15. 383deuce
    383deuce
    DAM! This thing brings back some good times as my very first car was "Just like this one" same color even. I gave 50 bucks for it back in 1954.
    Thanks for posting the photos......
  16. 38Chevy454
    38Chevy454
    That really cleaned up nicely. As I said in my previous post, I have a 37 Chevy Ute, all stock with the same knee action front suspension. I drive it 60 mph on the highway, it just drives like an old car. 60 is about the limit for the engine not revving too high. Brakes seem fine on mine, you just have to drive with caution and understand the limits of the suspension and brakes as designed. The 216 runs fine, the 3 speed trans works, although the shifter is pretty vague due to wear; made worse by being shifted with left hand (remember it is RHD from Australia). Acceleration is kind of like a switch, floor it to get up to speed, no speed shifting for sure! That about keeps up with modern traffic.
    So what is all my rambling for? Just drive and enjoy the car. It is plenty drivable as it is, not a hot rod, but also not something to sit and never be used. Have fun with it, the excellent condition of your car will make for a nice drive and you will get countless stares, pictures, comments and thumbs up from almost everybody.
    TagMan and Fedman like this.
  17. image.jpg I just saw this, nice find! This one has been in the family since '68.
  18. joel
    joel
    Beautiful '37. My son has '50 and I'm working on collecting the parts for the Bendix style brake conversion: that's his only complaint.
  19. zeph4057k
    zeph4057k
    don't wash it, you can preserve the dust by spraying 3M 77 spray tack glue on it. just switch out the spray nozel on the spray glue with a spray paint nozel and it will mist the glue over the car. let it sit for a couple days ,and you have permant dust, heres my car I did it with on my willys ! 47-2016-detroit-autorama-move-in-photo-gallery-.jpg
    osage orange likes this.
  20. I sure hope you're kidding
  21. milo1303s
    milo1303s
    I don' think he is that willys is gl*** bodied (if it's he car i'm thinkin about)
    and looks great how ever he did it the hemi helps abit too LOL!!!
  22. dirty old man
    dirty old man
    Since when did having a dirty, dusty car become the style?
    loudbang, volvobrynk and Leakie like this.
  23. Faux patina, purposely adding rust to an old survivor, and this is about the dumbest **** wannabee hot rodders have come up with.
    joel, loudbang, ewob53 and 1 other person like this.
  24. rusty1
    rusty1
    some people like red, some like blue, it's all a matter of choice.
  25. Silverado85
    Silverado85
    Hey, I need a 1938 Chevy project again. Sold mine. Need antother. Where can I buy it? Thanks
    bigbore1934 likes this.
  26. 19ford49
    19ford49
    from Casper,Wyo
    Thats a nice color for that car. Thats a good find. :)
  27. 327!!!!!!!!!! come on Nate cut it up.
  28. shown50
    shown50
    that thing looks like a time capsule. I love the color on it awesome find!
  29. vetteguy402
    vetteguy402
    from omaha, ne
  30. Drag'n 59
    Drag'n 59
    from DALLAS, TX
    I now own this car. Wild how I came to find this page. Interesting story on this one.
