Technical Grand National Rear end.
Discussion in 'The Hokey Ass Message Board' started by Sttevil, Mar 11, 2016.
  1. zbuickman
    zbuickman
    8.5's came in Turbo Regals 84-87 (3:42)and 442's (3:73) They could also be had with the Aluminum drums. Notice the tabs. Squared tabs = 8.5". ImageUploadedByH.A.M.B.1458424039.774500.jpg
  2. Sttevil
    Sttevil
    Thanks, I got the rearend, picked up a posi and I'm under a grand. Awesome street rod rear end [emoji6]
    Sent from my SAMSUNG-SM-N910A using H.A.M.B. mobile app
    Johnboy34 likes this.
  3. Sttevil
    Sttevil
    If you look at the bearing surface, price, brakes, axles, it makes perfect sense. Run what cha brung build how you like it. ;)
  4. tfeverfred
    tfeverfred
    I like it when the newbs pop in, clueless, get the pot stirred with some Facebook ******** request/question and after they get awesome advise and an answer, they come back like they knew the answer all along.:rolleyes: But that's cool. I'll wait till he posts a pic of those "fat *** tires". THEN, it'll really be funny.
    And why the hell is this in "TRADITIONAL HOT RODS"?
  5. Sttevil
    Sttevil
    Really, I just wanted a pic if someone else had done it. Geez...settle down.
  6. tfeverfred
    tfeverfred
    Man, I am down to tha ground.:D
  7. hotroddon
    hotroddon
    This was one of the most confused by the OP and participants thread in a long time - So many folks answered without obviously reading the whole thread as it had NOTHING to do with Buick's - Was good for a laugh
  8. Jason147
    Jason147
  9. What he said.
  10. tfeverfred
    tfeverfred
    Here's what he's talking about, but again, it cost the same as a regular 9" rear end, so why go through the h***le? Seems unneeded and over kill in a T Bucket. Oh, ****! I forgot, " Run what cha brung build how you like it." Carry on, Big Dawg!:D
    http://www.speedwaymotors.com/Grand-National-Rear-End,6587.html
    HOLD THE PRESSES! Speedway disclaimer:
    "This rear end is intended for use in circle track racing applications and does not typically work well for street use since it uses 5/8" wheel studs. Most commonly available street wheels accept up to 1/2" wheel studs max."
  11. jimmy six
    jimmy six
    This is for the Speedway disclaimer. Gee...drill 5 new holes in the pattern you want. Dah. We broke an axle in the Pontiac rear end which had been re-drilled for a Chevrolet bolt pattern. I put the brake drum on which now has 10 holes. Marked the centers of the 4-3/4" pattern and drilled them and installed new studs. It's not rocket science. If I had a GN rear I'd install it in anything I had just like my 3/4 ton pickups.
  12. tfeverfred
    tfeverfred
    I have a pretty good feeling the disclaimer wasn't for the hole sizes. But hey, they probably don't know what they're talking about, anyway. I just tossed it out there. Wasn't trying to discourage using it. If the guy REALLY thinks he needs that setup, good luck to him.
  13. Sttevil
    Sttevil
    Avail for purchase is 1/2in wheel studs they screw in on the 5 on 4 3/4 hubs ;)
  14. mongo4u2
    mongo4u2
    from sparta
    I have sold alot who put them in their rods, from now on I will ask to send pics back to me . I always have 100 in stock and ready to ship DSCN1468.JPG
  15. gimpyshotrods
    gimpyshotrods
    Just make sure that the hub register will fit through the wheels of your choice. They are larger than your average axle flange register, so be aware.
  16. darkk
    darkk
