Projects SOUTHEAST GASSERS "BRAND X" BUILD
Discussion in 'Traditional Hot Rods' started by HEMIBERT, Oct 12, 2015.
  1. swade41
    swade41
    from Buffalo,NY
    Coming along nicely !
  2. sonic03bluegt
    sonic03bluegt
    from sc
  3. HEMIBERT
    HEMIBERT
    I'm moving along. Nothing really new to see right now. No real visual progress. Ordering axles tomorrow. Will complete rearend this weekend. Building drive shaft tomorrow night. Ordered new fuel line and fittings today, that will plumb the tank to pump to whatever goes on top (carb or injection). Not even started to work the heads yet. Need a fairly clear mind for that. Tonight ordering rocker arm parts and rollers for the engine and gauges for dash. Have dash made but not installed. Waiting to finish transmission cover first. That will be done this week too. Going to pick up a couple of windshields and a spare rear window sat morning. I'll try for some pics this weekend.
  4. HEMIBERT
    HEMIBERT
    New axles came in Friday. Got them installed, gear set up, drive shaft shortened and installed and brakes bled.
    Found myself needing a windshield, so this weekend I looked around and managed to score not only one but another one for a spare. Same guy had a rear glass I bought for a spare also. On these things, you can't have enough glass. AXLE2.JPG REAR3.JPG
  5. Quain Stott
    Quain Stott
    Your going to make it I just know it. Looking good.
    enloe, AHotRod and loudbang like this.
  6. HEMIBERT
    HEMIBERT
    Coming together. Engine assembled and installed. Need to finish plumbing and electrics. Seats and headrest installed. Most of tunnel done, needs closeout for shifter. Dash installed and wired. Hope to get front and rear windows in this week and start on body work, weather permitting. Tons of obvious little stuff. I now have a side bet of a case of Moon Pies on whether or not it is ready for the opener! Inspiration! IM015077.JPG IM015075.JPG IM015078.JPG IM015079.JPG IM015080.JPG
  7. Zak Hall
    Zak Hall
    Looking good Robert!
  8. HEMIBERT
    HEMIBERT
    Thanks. You guys moving along OK?
    Zak Hall likes this.
  9. Quain Stott
    Quain Stott
    Your going to make it.
  10. Zak Hall
    Zak Hall
    We're making progress. We should make it to the opener.
    kidcampbell71 likes this.
  11. porkshop
    porkshop
    from Clovis Ca
    That's looking great!!!!!
  12. 3dnsouth
    3dnsouth
    from North Ga
    Really nice work! Lookin' forward to seeing it at the track.
  13. saltflats
    saltflats
    from Missouri
    Wish I had another set of M/T valve covers to send you.
    Quain Stott likes this.
  14. wrenchbender
    wrenchbender
    Car looks good man and I have a nice new can of hemi orange paint for those valve covers in case you ran out I will be happy to send it to you lol may even have some extra 426 stickers to put on them too lol keep up the good work
  15. HEMIBERT
    HEMIBERT
    I have access to a set, but these are sooo light. Quain and I talked about them and I hate to cover the blue, but I'll be painting these Hemi orange like the block and heads.
  16. HEMIBERT
    HEMIBERT
    I have some Hemi orange left and will be painting them with that to match the block and heads. I really like blue thoughb but they do look out of place.
  17. HEMIBERT
    HEMIBERT
    After you stand back and look, one sees things not noticed at first. Easier to fix them now. Fuel pump and regulator will be moved a little more out of sight. Looks wrong where it is now.
    loudbang and II FUNNY like this.
  18. HEMIBERT
    HEMIBERT
    After 5 months on build. OUTSIDE2.JPG OUTSIDE3.JPG Windshield in and outside for some body work.
  19. AHotRod
    AHotRod
    Looks ready to go to me !!!!
  20. HEMIBERT
    HEMIBERT
    I know, me too, but Quain said something about doors, fenders and windows! Go figure.
    dwollam, kiwijeff and Higgy's Henry like this.
  21. mad mikey
    mad mikey
    Ready for test and tune! LOL. Looks fantastic, you have been doing extremely well with the car.:D:cool:
  22. HEMIBERT
    HEMIBERT
    Thank you very much.
  23. dusterdave173
    dusterdave173
    Tell us about the engine whats inside/ What heads, rockers, etc
  24. TFoch
    TFoch
    That's going to be a fun ride!
  25. Legendlives
    Legendlives
    Ive narrowed a few axles - both I-beam and tube - but I've always step-cut them (see my build thread) to give more weld run and (hopefully) more strength. Never had one break.
  26. HEMIBERT
    HEMIBERT
    Not much in the engine compartment right now. Been close to 40 years since I ran a 4-speed. Don't need to re-learn on a really good engine. Just a basic 383. TRW 12.5 pistons, stock bore, stock stroke steel crank. Comp cams solid .557 lift, Crane rockers. 906 heads. Home made headers. Tunnel ram with 2 AFB's. Stock Chrysler ignition. Nothing fancy at all. It's easy to trick yourself into looking stoopid! Hoping to get down the track, get all the gears for a couple shows--then we'll talk.
    loudbang and AHotRod like this.
  27. HEMIBERT
    HEMIBERT
    I cut 5" out, re-welded it in a steel fixture and boxed the I-beam about 6" front and back of the weld. Shouldn't be a problem. The center of the axle takes the least stress, unless when jacking of course.
  28. 55Deso
    55Deso
    from Wyoming
    Thats looking mean, cant wait to see video of it hustling down the strip!
    Whats the story on the COE in the background? Any more pics or a build thread on it?
  29. HEMIBERT
    HEMIBERT
    57 Dodge COE. Custom frame. GM 1-ton front suspension, 440 Dodge/automatic, Ford 1-ton rear on Chrysler heave-duty leaf springs. Going to put a pick-up bed on it, dual wheels, built in storage boxes under bed. Going to be the tow vehicle for the Barracuda. Finishing that will be next. I have most of the parts collected, all I need is time. My wife thinks her Rambler wagon should be finished too. No build threads on either. We saw a picture of one. Ugliest thing we had ever seen. So we had to have one.
    dwollam, AHotRod and 3dnsouth like this.
  30. Russman69
    Russman69
    from MI
    The car is looking great! The COE will be the icing on the cake when pulling into the track. Great job!
