Projects 1931 VICTORIA SOUTHEAST GASSER BUILD
Discussion in 'Traditional Hot Rods' started by Cabbage, Mar 26, 2016.
  1. Cabbage
    Cabbage
    Message_1454362597693.jpg Im not as good as my buddy BigA with the artsy pics but i get by ; )
    Ether likes this.
  2. tylercrawford
    tylercrawford
    from Buford, GA
    Dangit man, I knew I should have stopped by last wednesday night :confused:
    :D
  3. Old phone ?
    You have these guys thinking you're superman and posting in realtime here.
    I know better but it's like TV
  4. Cabbage
    Cabbage
    Im just trying to keep it interesting 31vicky. Im not gonna lie just the trusses in the frame cost me 10lbs of welding wire, 2 1/2 bandsaw blades and about a month to complete. Ive been saving up pics till i had enough to post without being a slow tease
    kiwijeff and mad mikey like this.
  5. Cabbage
    Cabbage
    Lets get this thing bolted and welded in! FINALLY phew that was another PIA Message_1455939117458.jpg
    Mtn Goat, D-Russ and volvobrynk like this.
  6. Dude I know that was a lot of work!
    1/2 notch in each piece :eek:
  7. Cabbage
    Cabbage
    20160221_232943.jpg The rear floor needs to come up a few inches to cover the bumper brackets.
    volvobrynk and Dog_Patch like this.
  8. Cabbage
    Cabbage
    Message_1456114703005.jpg Test fitting the gas tank. I dont think im gonna use this one. Its seriously heavy made outta gonzo thick steel
    Mtn Goat and D-Russ like this.
  9. Dog_Patch
    Dog_Patch
    Thought this was a race car - not a moonshine hauler ;)
  10. brett4christ
    brett4christ
    Stellar work, Chuckles! Shooting for SIM??? ;)
  11. Cabbage
    Cabbage
    Thanks Brett! Chuckles is south of the equator messing with the locals minds and brewing yummy reserve no doubt. Steel n Motion is a long shot but dont rule me out
  12. It's Georgia... it'll pull double-duty. :D
    Looking damn fine Russ! That frame is cool as hell.
    Ether and volvobrynk like this.
  13. mad mikey
    mad mikey
    Great build, my kind of g***er. Can you run some moonshine up to PA. in 6 hours? They say it cant be done. LOL:D
    Dog_Patch likes this.
  14. brett4christ
    brett4christ
    Brain fart!!!! I knew that!!!! Still a nice job! Coming up to AF next weekend?
  15. Cabbage
    Cabbage
    Probably not ive got a g***er to build :) lots to do here
  16. Cabbage
    Cabbage
    20160223_214504.jpg Mikey i would need the snowman to run blocker : ) thanks guys for the kind comments. Lets see whats next? Here she is bolted to her frame for the first time in a long time. 10 mounts so far and several more to come. Up front and rear is solid mounted like a 32 but the middle is on urethane biscuits
  17. Cabbage
    Cabbage
    Message_1456769958202.jpg Now that the body is on the frame its time to start fabricating the suspension mounts. But first lets swap out that model A axle for something a little cooler. I picked up this V8-60 axle awhile back. These things are pretty hard to track down and this one probably was under a hot rod cause its been chromed! Actually i dont think its been ran since chromed because the kingpin holes are a few thousands under. After a few hours of careful honing with the smallest brake hone i could find.... Finally the pin fits!
  18. Cabbage
    Cabbage
  19. Cabbage
    Cabbage
    20160227_155518.jpg About this time i borrowed some slicks from Tony for a look. I was sure these would be the perfect size. Until i got them in the fender. They look a little small to me
    Dog_Patch and elgringo71 like this.
  20. dirty old man
    dirty old man
    That axle is really gonna set that front end off to a real beauty! There's an ongoing dispute however, on the compatibility of tube axle and split radius rods or hairpins vs unsplit rods or 4 bar. Beam axle will twist more easily than tube, and split rods or wishbones tend to twist axle when ch***is is leaning in relation to axle, as in a turn when leaning, etc.
    Next time you encounter tight king pin holes, whether in spindle or axle, find a shop with the good old Sunnen pin honing machine and the right size stone. With the right man on the machine, pin fits are the best possible.
  21. elgringo71
    elgringo71
    You are doing fantastic work and I can't wait to see this one on the track. I love Vicky g***ers but you don't see them often
  22. Cabbage
    Cabbage
    20160228_160938.jpg Now this is what im after! Fills up the fender perfect. Ok so now we know what size slicks she will wear. There will be some hanging out in the wind but thats old school.
  23. Cabbage
    Cabbage
    Thanks Elgringo and Dirty ol Man i think it will be ok for a track car. Could be an issue on the street but you know guys have been doing it since forever. Lots of threads and opinions on the subject.
    volvobrynk likes this.
  24. Cabbage
    Cabbage
    20160125_194436.jpg Sorry i kinda skipped this. Before i did the subrails for the floor all the door gaps got set and then i welded the doors shut. Gotta keep everything in the right place so the gaps are nice.
    CoolYourJets and Dog_Patch like this.
  25. Chucky
    Chucky
    Not sure the width of that axle compared to the A, but one thing on my list is to narrow my A axle about 4". With disc brakes my tires are under the fenders, but just barely. I think tucking the tires in would look mucho bettero. Your car is looking pretty darn nice already.
    CoolYourJets likes this.
  26. Cabbage
    Cabbage
    Message_1456781167835.jpg Heres the next problem. With the nose bleed stance we got goin. The bone hanger brackets would need to be 11 inches below the frame! Kinda stupid looking. What to do???
    kustomitch likes this.
  27. elgringo71
    elgringo71
  28. Cabbage
    Cabbage
    20160301_201125.jpg Mmmmm i wonder if i flipped the tubes on the bones? What the hay... Lets cut em up!
  29. Cabbage
    Cabbage
    20160304_152050.jpg Thats the ticket! Now they are only 4 inches under the frame! I can live with that. Time to pie cut the ends for some caster. I ended up with about 8 1/2 degrees at 4" below the frame
    Mtn Goat, Dog_Patch and volvobrynk like this.
  30. HotrodHR
    HotrodHR
    What's the scoop on the other vehicles in your shop?
