Customs Who chromes steel wheels?
Discussion in 'The Hokey Ass Message Board' started by fatty mcguire, Mar 29, 2016.
  1. fatty mcguire
    fatty mcguire
    Im loooking to send out a set of wheels to get chromed, my local chromer wont touch them...Any leads would be great IMG_0843.PNG
  2. Chaz
    Chaz
    I've yet to see a chromer that'll plate steel wheels. Too many tight spaces to guarantee the plating will cover correctly is what I'm told. I know it was done in days of old, but Its waaaay cheaper now to just buy new chromies. They will quickly rust in the recesses in left out in the weather at all.
  3. fatty mcguire
    fatty mcguire
    I dont think they make 40 ford style wheels new in chrome reverse?, and theses wheels are apart right now, so they could get chromed and welded up after
  4. Nailhead Jason
    Nailhead Jason
    Wheelsmith does very nice quality and have bought several sets from them. They will reverse or do any back spacing since they are custom made when you order them. very quick turn around too.
    http://www.thewheelsmith.net/
  5. Nailhead Jason
    Nailhead Jason
    Not the best pic but here is one on the front of my 39 from wheelsmith
    dana barlow and lothiandon1940 like this.
  6. Dadio 56
    Dadio 56
    dana barlow likes this.
  7. There's special 'fixturing' involved for plating wheel rims and very few platers are equipped to do it.
  8. mgtstumpy
    mgtstumpy
    My chrome plater years ago had no issue as long as I had them split so he could do a decent job. It was then up to me to get them trued and welded back up again when finished. A bit of silver frost on the welds and done.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    these are for the Les popo 40, currently produced chrome wheels will be incorrect for the restoration. He needs the tapered rim, look at the pics. that is why he was asking about who plates wheels. the plater will have to build an annode for the wheel centers so the plating will get into the lug nut area, even with the wheels apart. I had wheels plated for my outlaw clone but I didnt care about the part that got covered up buy the merc hub cap. I would think that any good plating shop could do this. I have had good luck with AIH custom chrome in Dubuque Iowa
    lothiandon1940 likes this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Silver Frost? HRP
    lothiandon1940 and Moriarity like this.
  11. Good luck. Only plater I could find willing to do a set of old slots for me quoted me $600.00 per wheel. That was 3 yrs ago.
  12. mgtstumpy
    mgtstumpy
    Silver paint on the inside of the rim where the inner is welded to the hoop itself.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    what ever happened to rally america? @wheelkid ? they used to make and sell the exact wheels needed for this car
    lurker mick and lothiandon1940 like this.
  14. chopolds
    chopolds
    from howell, nj
    I've seen late model wheels at my plater, freshly chromed. I can check what the story is for you.
    Moriarity and lothiandon1940 like this.
  15. fatty mcguire
    fatty mcguire
    ok cool and thanks for the input guys, and mark is your guy local?would be great to find someone driving distance, shipping a set of wheels boths ways cant be that cheap haha, gotta save where i can
  16. Wheelkids place burnt down. Don't think they ever got back up and running? PM Brian B***, he has a place down South he uses.
  17. SicSpeed
    SicSpeed
    from Idaho
    Call Stockton Wheel, # 209-464-7771 or 800-395-9433
    stocktonwheel.com
  18. 51box
    51box
    from MA
    I talked to Stockton about it before, he will do original ford centers in a 5" wide shell for $355 per wheel chromed. There are a lot of horror stories about that place though so be aware.
  19. Stu D Baker
    Stu D Baker
    from Illinois
    Is it at all feasible to remove the centers, and have everything polished and plated, then reinstall the centers again? I realize it's a critical, and labor intensive job, but if there are no other option?
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    that is how it is done, they are welded after chroming
  21. fatty mcguire
    fatty mcguire
    yes stu d baker, yes its going have to come apart, I think 2 or 3 wheels are already done, just screwed together for now,
  22. Stu D Baker
    Stu D Baker
    from Illinois
    Once the wheels are apart, doesn't that make the chrome process more doable? I know how they are done originally, and that original process seems to be uncomplicated for a plater. Or, is it still an issue with plater's doing the hoop?
  23. Chaz
    Chaz
    I would think once the wheels were apart that's a different game.... Most platers could handle that.
    I am surprised that welding after chroming doesn't cause some issues.
  24. chopolds
    chopolds
    from howell, nj
    Mike, I've been using the guy in Asbury Park on and off for some things. Super Chrome, or something like that. Guy's name is Robert. I'm dropping off in a week or so, so I'll check.
  25. brad2v
    brad2v
    He had a fire some time ago. I'm unsure if they are coming back or not. He did great work.
  26. The things to remember is plating is both line-of-sight and it will attach to the first surface it comes to. You have to 'draw' it into recesses with 'fixtured' anodes, and a recess could be defined as anything deeper/lower than about 1" next to the surrounding surface. So just plopping a rim hoop in a plating tank without doing this will give a rim with great plating on the 'outside' surfaces (the area under the mounted tire) and about 1-2" in from the rim lip. The closer you get to the center, the less plating you'll have and it can be zero if the recess is deep enough. Same thing goes for the wheel centers around the lug nuts on OEM type wheels; that's why when they rust, this is where it almost always starts. Same reason plated aluminum wheels start going bad from the recesses out; thin plating in these areas.
    Commercial wheel outfits that offer plated wheels are set up with this special fixturing (***uming they do plating in-house) but few 'regular' plating shops are and don't want to h***le with it because they can't compete price-wise on a handful of pieces or may not have the needed stuff to fixture it.
  27. Torkwrench
    Torkwrench
    Since your wheels are dis***embled, it's surprising that you're having trouble getting them plated. If they were still in one piece, it would be different.
    I had the wheels on my 34 Chevy plated in January 2014 at Quality Plating in Sterling Illinois.
    http://www.qualitychromeplating.com/
    The wheels are original 55 Chevy. Before they were chromed, the rivets were drilled out and the centers removed from the rims. After the centers and rims were chromed, they were trued and welded back together. Silver paint was used on the welds. They turned out really nice.
    They did have to be dis***embled to be chromed. Quality Plating wouldn't touch them if they were left in one piece.
    I did start out with some very nice pit free wheels, though. For the rear, new 7 inch rims were used on the original 55 centers. The fronts are all original 55 Chevy, chromed and reversed. Course, Sterling ILL is quite a way from New Jersey.
  28. jcmarz
    jcmarz
    from Chino, Ca
  29. Nailhead Jason
    Nailhead Jason
    Advanced plating in Nashville TN did some for a friend a few years ago. Did an awesome job to. His were 53 Chevy wheels with the centers taken out and plated separate from the hoops.
    http://www.advancedplating.com/site/
