Hot Rods steering box f100 1956 ???
Discussion in 'The Hokey Ass Message Board' started by dutchrod, Mar 29, 2016.
  1. dutchrod
    dutchrod
    I bought this steering box to put in my deuce , the seller told me it was a f100 box.
    I need to order parts to rebuilt it but i'm not sure what i got.
    On the shaft there was a little paper with 56 590 on it .
    On the box i only see "A3" , "gemmer" and "3CC03"
    I tried the search function and found the same one for sale , advertised says 1956 so i think i'm good.
    Can somebody confirm ?
    Hotrodjohn71 likes this.
  2. Sure looks like an F100 box to me!
    The earlier F1 boxes had the column shaft exit out the bottom while the F100 boxes exit out the top.
  3. dutchrod
    dutchrod
    Thanks !
  4. sdcoupe33
    sdcoupe33
    I have the same box on my '33. Can't identify the numbers as my box has been smoothed out and chromed but visually is identical. Vern Tardel has a nice booklet regarding identifying and rebuilding these early boxes http://www.verntardel.com/collections/books/products/ford-steering-booklet . Parts are easily available over here in the States. Use only 600w oil or #00 grease as anything lighter has a tendency to run out over time. Most of the grease sold is for ch***is or wheel bearings and is type 2 (no good). Vintique sells 600w oil; several manufacturers sell #00 grease, a lot of Hambers like John Deere Corn Head grease. I found some #00 grease at a local lawnmower shop as it is used in mower gearboxes.
    Hotrodjohn71 and bct like this.
  5. louisb
    louisb
    I don't remember the lengths but I know the 53-55 boxes and the 56 boxes had different length shafts to fit different steering wheels. One had a deeper dish. You should verify this but I think the 56 is shorter. Otherwise they are the same.
    --louis
  6. Bader2
    Bader2
    56 is a couple inches shorter.
    Hotrodjohn71 and louisb like this.
