1952-59 Ford 1954 Hood hinge bolt question
Discussion in 'Off Topic Hot Rods & Customs' started by bashnaka, Apr 5, 2016.
  1. bashnaka
    bashnaka
    from england
    hi
    the bolts that hold the arms of the hood hinges dont seem to be the right ones as they are much smaller dia than the holes on the arms and they only work if loose which allows the hood to move about a lot when open and im looking on the internet and the bolts i can find listed only go up to 53 so did they change something and can anybody tell me how the hinge arms bolts work ( shims spacers ) ???
  2. Mark T
    Mark T
  3. bashnaka
    bashnaka
    from england
    The 4 bolts that hold the hinge arms to the hood
  4. Mark T
    Mark T
  5. bashnaka
    bashnaka
    from england
    the link doesnt work but they do look like the bolts that i have . so when i open the hood and then tighten them bolts it locks the hood in that position ist there a shim or bush between those bolts and the arms of the hinge and the hood ?
  6. bashnaka
    bashnaka
    from england
    hmm the ones showing at macs are shoulder bolts with lockwire holes and not the ones in your picture but the shoulder ones make sense so must use shims
  7. green53ford
    green53ford
    from Wisconsin
    You need the special shoulder bolts.
  8. Mark T
    Mark T
    I think the nut inside the hood looks like this, are yours okay? are they getting tight?
  9. Mark T
    Mark T
    The bolts that I took out of my '55 hood look just like the ones that I posted.
  10. bashnaka
    bashnaka
    from england
    do i have to then shim it to hold the hinge arms snug side to side but allow rotational movement ?
  11. bashnaka
    bashnaka
    from england
    55 is a totally diferent hinge
  12. Mark T
    Mark T
    I think you are incorrect, the '55 ford uses the bolts that I posted above.
  13. bashnaka
    bashnaka
    from england
    if you look at the post it says my car is a 54 which has a different hinge altogether
  14. Mark T
    Mark T
    My apology, I looked at your avatar and thought you were working on the '55
  15. bashnaka
    bashnaka
    from england
    cool ..haha i never thought of that maybee i need a new avatar
  16. bashnaka
    bashnaka
    from england
  17. JeffB2
    JeffB2
    from Phoenix,AZ
  18. bashnaka
    bashnaka
    from england
  19. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have the Ford Parts Manual CD-ROM that danman has hooked members up with there is a real good illustration how the bolts are installed,I can't scan it for you my new Operating System and printer /scanner are not playing nice with each other.
  20. Paul2748
    Paul2748
    No shim they use spring washers that go over the shoulder for tension purposes. Hardware store should have them. Dennis Carpenter has the bolts and probably the spring washers. 54 is the same as 52/53.
  21. 54vicky
    54vicky
    they also call them wave washers.the proper bolts are drilled for a wire to keep them from loosening.when you tighten the proper bolts the shoulder will not allow over tightening
  22. buymeamerc
    buymeamerc
    from s.c.,usa
    SHOULDER BOLTS ARE CORRECT
