Technical 1952 Buick Dynaflow hard to get in and out of drive.
Discussion in 'The Hokey Ass Message Board' started by barry smith, Apr 5, 2016.
  1. barry smith
    barry smith
    from Houston
    Having an issue getting the shiffter in and out of drive, man you gotta really pull down hard to get it out of drive to go to reverse and push up hard to go to park.
    I took the shiffter linkage off the shaft that goes into tranny and it works fine, so guessing it is in the tranny somewhere, any sugestions?
    Thanks!
  2. 1959 F100
    1959 F100
    Check the linkage where it comes off the column, under the hood, has to be a bind there
  3. barry smith
    barry smith
    from Houston
    I did, its fine.
  4. Ebbsspeed
    Ebbsspeed
    How hard is it to move the lever on the trans shift shaft?
  5. That's where mine was hanging up welcome to the world of buicks.Bruce. 003.JPG
  6. barry smith
    barry smith
    from Houston
    Not sure yet, need to get under car to see, it moves fine from the top for a short distance, but i need to put it in drive unhook linkage and go underneath to see if it will come out of gear easy or not, will update this afternoon.
  7. Ebbsspeed
    Ebbsspeed
    Chock your wheels.....
  8. barry smith
    barry smith
    from Houston
    Oh yeah, chauk wheels first thing.
    OK this is what's up, in the pivot arm that Both the steering collum linkage and shiftshaft hook up to is a grease fitting on the bottom, you can only see it while under the car, greased it up and problem mostly solved, the shift shat going to the trans linkage at tranny was allso hitting the frame slightly and causing a slight bind as well.
    Thanks !
  9. Barry, glad you got it fixed. Bruce.
