Hot Rods Ardun head question
Discussion in 'The Hokey Ass Message Board' started by gbritnell, Apr 8, 2016.
  1. gbritnell
    gbritnell
    Do Ardun heads use the same amount of head bolts as in the flathead block?
    gbritnell
  2. Stu D Baker
    Stu D Baker
    from Illinois
    I know zip about Ardun heads, although I really like the look. That said, I would think they need to fasten exactly the same as the flathead, i.e., utilize the existing bolt pattern in the flathead block?
  3. 32 Barn Car
    32 Barn Car
    from Oregon
    On mine it looks like less . Compare a flathead head gasket to those of an Ardun .
    tartar_sammich and Fedman like this.
  4. Fedman
    Fedman
    32 Barn Car,
    Man that is a beautiful sight!
    When the Ardun Conversion is added, what is the approximate H.P. increase?
    I have always been curious to what it added to a stock Flathead.
    Thanks!
  5. 32 Barn Car
    32 Barn Car
    from Oregon
    The engine was built by Ardun god Cotton Werksman , was far from stock , 284" with a Merc crank , Howard cam , a mag and 6 Stromberg 97's .
  6. 1946caddy
    1946caddy
    from washington
    What's done with the existing valves in the block?
  7. seb fontana
    seb fontana
    from ct
    Put them in another engine as the push rods have to go through that space.
  8. k9racer
    k9racer
    Don Orsco from calif had the ardun heads retooled with many improvements in quality.
