Industrial Chassis Inc
Discussion in 'The H.A.M.B. O'Dex' started by ELpolacko, Aug 8, 2011.
  1. ELpolacko
    ELpolacko
    Industrial Ch***is Inc
    3536 W Osborn Suite 5
    Phoenix, AZ 85019
    866-553-8996
    www.industrialch***isinc.com
    Industrial Ch***is has been around since 1995 building quality hot rod and custom ch***is, frame, suspension components and brake kits. We continue today with high quality design and fabrication.
    We are more than just traditional (and modern) cars and trucks, we are also offering machine building services for small to medium manufacturing. Design/build or work from your prints, sketches or wild hand wavings. We also have a starting a line of shop tools including, helve hammers, shrinker stretcher stands and brake bleeding systems.
    Machine tools:
    • Alibre computer design
    • MultiCAM CNC plasma
    • 24" TimeSaver
    • Lennox 45 ton press brake
    • Miller and L-TEC TIG and MIG welding machines
    • Fabrication machine shop services, Mill and Lathe
    • 5' X 12' fabrication table
    • P9 Pullmax, English wheel, planishing and helve hammers
    We are offering bolt in ch***is parts for your 1932 Ford frame
    • replacement brake and clutch pedals for your stock K-member
    • bolt in frame bracing to fit your stock K-member
    • Full X-member kits with provisions for front and rear split bones
    • Fabricated '39 style brake and clutch pedals
    • Engine mounts for SBC and Early Oldsmobile
    • Bolt-in rear spring crossmembers for Model A springs
    • Bolt-in front spring crossmember with engine mount tabs
    We are now offering the Dodge Dakota based IFS kits again
    Kits available now, include custom tailored boxing plates with fool proof installation. Slot and tab location of vital brackets. C-channel boxing plates to add real strength to your IFS. Standard Dakota parts bolt on without modification. Upgrades available.
    Year models available at this time
    • 1953-1956 F100 weld in kit
    • 1957-1960 F100 weld in kit
    • 1961-1964 F100 weld in kit
    • 1965-1966 F100 weld in kit
    • 1947-1955 GM First series bolt-in
    • 1955-1959 GM truck weld in kit
    Coming soon will be
    • 1953-1966 F100 rear four bar kits
    • 1955-196059 GM Truck rear four bar kits
    G31270Oldsmobile1938 likes this.
  2. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    one of best shops around---top notch people
  3. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    We bought our front suspension from Steve and couldn't be happier. Excellent tech support, easy instructions and perfect alignment. Doesn't get any better. I've seen lots of damn fine work come out of his shop!
  4. Mike
    Mike
    The folks at Indistrial Ch***is really know their onions. Solid engineering and spot on craftsmanship in everything they do.
  5. MilesM
    MilesM
    Steve has done stuff to most of my cars. Very talented.
    I have a Dakota kit on my 54 GMC from IC also.
    53FordEffie likes this.
  6. sodbuster
    sodbuster
    from Kansas
    Top notch.......and a great guy!!!
  7. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I've seen this guy's work. AWESOME.
  8. ELpolacko
    ELpolacko
  9. ELpolacko
    ELpolacko
  10. Rick Evans
    Rick Evans
    from Phoenix AZ
    Industrial Ch***is has saved me from certain death by fixing the ch***is issues I inherited when I bought a car sight unseen. I wouldn't trust anyone other than IC with my hard earned money.
    ELpolacko likes this.
  11. amadeus
    amadeus
    I have the New Generation Industrial Ch***is Dakota IFS kit in my 1960 F100, My truck rides and handles superb!
    Steve and the masters at Industrial Ch***is do amazing work! I am saving my pennies and will have them work their magic on my next project soon. If you haven't checked their website you should, their products are premium quality!
    I Highly recommend them!
    Smitty544 and ELpolacko like this.
  12. racinman
    racinman
    Thanks Steve for the help loading my customers Ch***is, and parts! He's a real stand-up guy with a great product!
